Leaderboard
Popular Content
Showing content with the highest reputation on 17/05/20 in all areas
I would simply get rid of those small side pipe fenders. They don’t do any good, are not necessary, and tend to get ripped off in locks creating a potential problem for other boaters. Quite anti-social in fact. Fenders are for mooring, not to compensate for bad driving!6 points
The weed on the hull shows that the ducks have been on lock down somewhere else. Now that they are able to travel to their second home around your boat it will give them something to eat. You aren't supposed to sleep on board overnight yet, so the rat a tat tat of their pecking in the early hours of the morning won't wake you up. Much cheaper than shop bought duck food. Locally sourced and organic too. ? The fenders attached to the gunwale thing has been torn to shreds by other posters already, but I thought I'd add my bit. When I first got this boat and on its first trip I decked it out with fenders attached to the gunwale eyes with old retired climbing carabiners once I was on to the wide locks of the Trent and Mersey. Thought the krabs would make them easy to remove. Unfortunately I was right! The action of rubbing along the lock sides coming in unclipped every one of the fenders and I lost the lot. Live and learn. I now hang fenders with long ropes from the hand rail while mooring only. Jen4 points
4 points
Actualy old boy they should be lifted at all times when underway4 points
Quite agree. We had a 25Kg Delta on our lumpy water boat. Not the easiest to set and pretty useless if trying to set when the sea bed is getting deeper ie you are moving away from shore. The only need for an anchor on a NB is in an emergency and it must set first time. If near a river bank but being pulled towards the centre, the bed is getting deeper and no chance to set (unless snagged). As the river gets shallower on the other side then the anchor is going up hill and will far more easily set. As its unlikely you will recover your anchor, peeps wont want to spend £500 plus on a Mantus or a Rocna (the best). The best answer is dont get yourself in a position where you need to deploy your anchor! We spent 3 years living aboard and anchoring many many times. I am still crap at anchoring. God help anyone who has to do it first time in an emergency!3 points
The green 'tool' is used to hold several supermarket bags. Thread it through the handles and put the spade end through the slot. It is easier to carry them than the individual plastic finger cutting handles. I'm assuming that it is flexible, we've something similar.3 points
I, and many others, worry about what the police are not doing, such as investigating burglaries and prosecuting shoplifters. Not so long ago we were being told that the constabulary was dangerously under resourced, now they seem to have the time to drive up and down quiet mountain roads and deserted streets at night. Ever been on the receiving end of police harassment? If you ever are, you will change your view.3 points
Help - I'm at a loss to understand how staying overnight on a boat you can visit two days running is any more a threat than the two visits?3 points
Firstly, many thanks for the many PM's and Emails, I've only just gone 'back onto the computer and seen them. It has been a weird couple of weeks with all sorts of 'ailments' rolled into one - I'm still very short of breath just walking 50yards, but it is getting better - so - stand by for the old 'me'. You'll all be boating soon.2 points
More on the Mosel. The line alongside still had steam haulage, the electrification plan having hit problems in the tunnels. One of these things came to a stand one evening in this position on the bridge and we got the full display: the hissing of steam, the clatter of fire-irons, beams of light when the firebox door was opened, then the wailing of the whistle and the gathering of power as the signal turned to green.2 points
Many of you will know George and Helen Smith from their UCC camping boat days. This is their barge a Belgian registered spits which they worked for around 20 years before retiring back to Braunston a couple of years ago. Picture at Conde sur Marne on Bastille day but George wouldn’t stop. Load going to a cement works on the Rhone from Belgium.2 points
2 points
If your small alternator only has the one wire going to the battery, plus of course ground through the case, then it is probably a 6 diode machine that needs battery power to get it going (ie to send some current through the stator to create a magnetic field). Since you had disconnected that source of initial power, and put a low resistance load on the alternator, there is no way the alternator could get going. All you saw was a tiny bit of output from the residual magnetism. When you touched the battery wire on, this supplied power to excite the alternator and get it going. I’m not sure if the alternator would have continued to work having touched the wire and disconnected it again, it would depend on whether the load was much greater than the alternator could supply, alternator rpm etc. The best thing to do would be to leave the starter battery connected and measure both the current into the load and any current flowing in or out of the battery, using a clamp meter etc. Do you have one? For the reasons above I also think you measurement of unloaded alternator voltage is probably false as the alternator probably wasn’t working properly. Again, leave the starter battery connected and wait for the voltage to stabilise after starting the engine and it putting the starter current back in (just a couple of minutes, probably) to properly measure the regulated voltage. The way you did it, at best you are measuring a voltage with a large amount of ripple on it, and that is likely to confuse a digital meter.2 points
How do you know that? I'm 36 and I've done a lot seen a lot and went through some serious crap before the age of 13 so.....she has an opinion, you certainly do so she is due hers as you are yours. Just because your older does not mean yours should be listened to any more than hers, in fact yours are perhaps more deeply entrenched due to age so perhaps it is you who is less able to open yourself up to conflicting opinions and your ability to see both sides...note i said perhaps.2 points
I am just waiting to see if I can get a local CRT number that might work better, but yes it should be an official request. When I have been emailed with a request asking if anybody is available and I am I usually sort out meeting with the boater directly so we have contact before the day and I turn up at the right time and place and are expected2 points
, And you know what they say. We end up similar as when we were born, outspoken and naughty, often tyranical and irrational, height and size deminishes as well as the brain, No hair, no teeth, can't see much, , often need nappies again, can't walk far, start crawling again and burbling and bubbling at the mouth.2 points
Well no. The UK government (in their wisdom - we voted them in) have decided we are not in a total lockdown and are relaxing the rules. I agree with the relaxation as this virus is not going to go away and locking us up for another month or two is just going to delay our exposure later in the year. The only advantage of a total lockdown is to delay our exposure until they get a better handle on how to treat us, but at the cost of peeps dying for all sorts of other reasons. The summer is coming. Transmission will be less while we are outdoors and as the NHS has lots of capacity, now is the time (for me) to relax the rules. It seems from all the studies out there that less than 10% of the population has had this disease so locking us up is not going to achieve herd immunity. Letting it spread slowly is I think the best idea today. The big problem is that the government advice/laws are so confused that no one really knows what to do and the SUV brigade can flout what we think the laws are. I just hope they find the medical solution to treat the worst cases to stop people dying as soon as possible. That is to me the best cases scenario.2 points
Wow we are all allowed a viewpoint...i get that, its a discussion but id love to see you stand in front of her and say all this stuff folks, i couldn't hurt someone feelings like that....you all need to have an argument or something cuz there is some serious attitudes towards her here. If i was sat in my house and a dog came up to the windows jumping at them barking or scratching at them id have a thing to say and so would you I'm sure....so if it is true and I'm sure it is i know emma and her mum as im one of these (ex) youtubers we've met (and yes i always worked very hard not a jobless uneducated bum) then they have every right to complain. Don't like watching don't do it and try not to rip her apart as she may be on this forum. This is supposed to be a place for knowledge and celebrating a common passion. If that was my boat and i was there and that happened to me id be polite the first time asking them to please stop there dogs jumping at the windows... the second again id ask poltely but as my pride and joy was being potential damaged and my health put at risk id let them know they are pushing there luck the third. You all discussed in depth about how its dangerous to travel and against government guidance etc but for this its her fault she should move....they are not in front of the house, they do not engage with the home of these people, they are just trying to live there life and keep safe. Honestly sometimes i wonder where all those lovely people on the cut are that I've met and would do anything to help others.......not here obviously. (No not true I've met a few on here and they were perfectly lovely).....try it!2 points
So now you don't lke teenagers or anyone who does not agree with your moral code/ethics/ethnicity/ religion/or wearing socks with sandals., pathetic. I am glad she has overcome all the negative and spiteful comments on here, but has had to turn off comments. I don't usually watch her stuff as it's not my style, but I subscribed and gave her a thumbs up, for courage in the face of adversary! Keep going girl, don't let the old gits on here get you down.2 points
Very true - 'flat water' use can be very demanding, requiring the anchor to instantly set and to take the shock loading of 20+ tons of NB being pulled to an almost instant stop. Lumpy water boaters do not use the anchor as a brake. Lumpy water boaters generally plan to anchor, will choose a suitable place, lower the anchor and as it hits the bottom will slowly pay out more chain whilst engaging reverse to help to set the anchor properly. If it doesn't set 1st time, you can haul it back in motor forward and repeat the operation.2 points
I'm still happy to police myself, which is largely how the country used to run itself when I was a lad.2 points
The rule is designed to deter long distance travel which in itself offers opportunities for virus transmission eg calling at service stations. If people can't sensibly make the two way journey in a day they should stay at home. If people are allowed to stay overnight on boats then staying overnight in holiday homes or caravans etc should be allowed too. Staying in holiday homes etc also may involve long distance travel and potentially brings the virus into area that are otherwise relatively free of it. Staying overnight on a boat may involve a need to use communal toilet facilities which is another means of spreading the virus . People need to be given simple rules - they may appear illogical in some circumstances .2 points
The idea of a curtain twitcher would suggest someone who has an unwarranted interest in their neighbour's activities even though they may have no impact on their own life. This isn't anything like that. The idea of one rule for the 'rebels' and one for the rest in this situation just doesn't wash. Play the game ffs or else it will keep spreading2 points
Can't see how it would be possible for staff to check the overnight properly. Torchlight through the windows at midnight? Now people can get to their boats guess some are going to take the proverbial. At the end of the day though, staying out at second home is against the law so the police could prosecute if irrefutable proof. Marina, just like other businesses, should have stated distancing and sanitation policies/guidance in place before reopening, eg one off - one on the jetty, Not dismissing the Q; someone staying over on their leisure boat at the moment is simply claiming to be more important, more privileged and more entitled to put everyone else at greater risk than the rest of us.2 points
1 point
She is 14, she is a child, I imagine only she and you would disagree. If you think she is an adult, to be treated as an adult, I would want to keep kids far away from you.1 point
Completely agree. Blue makes pump out toilets stink. Our shareboats always had smelly toilets because people couldnt resist using the stuff. When we got our own boat the previous owner told me he never used anything and the toilet didn't smell at all. The manual suggested the same. So we didn't use blue and didn't have any smells. Still true after 6 years. Even when I cut a hole in the waste tank to fit the sensor for a level gauge the tank didn't smell much. The only thing I ever put in the toilet is Leesan descaling acid to remove limescale from the macerator pump, and I do that before a pump out. PS Definately worth fitting an MCS level gauge. The boat came with a "tank full" warning light, so we always pumped out as soon as practicable after it lit up. Since fitting the MCS level gauge, it has become obvious that the "tank full" warning lights just before the tank is 50% full. The MCS gauge soon paid for itself in the reduced number of pump outs needed.1 point
1 point
1 point
Thirded re the fenders. The weed is quite prolific, but I shouldn't worry about it ... an hour with a garden hoe will shift most of it, and the rest will come off as you cruise and rub the bottom and sides. It's really not worth spending a fortune on antifoul paint on a canal boat. No idea really re the green tool (good name for an unpopular superhero perhaps) - maybe for lifting mooring spikes?1 point
Yep you are meant to lift the fenders up for locks which is not easy when attached like that.1 point
And a distinct safety hazard if you leave them resting on the gunwales.1 point
Much the same as a cabin cruiser with single skin. Some you can some you cant. In true sandwich construction ( laminated both sides ) though there is more strength in it. And as the roof is often curved on a NB then then that adds strength and ona curved roof you can laminate one side and still keep strength. and to add more, even if flat roofed then more laminations will do the job. For this curved roof i would go three lam`s of 450grm. If a flat roof maybe three 600grm that would give a thickness of around 5.5mm. There will be the frame timbers inside also.1 point
The chain and warp is fine for most situations (unless on a very deep river) but I'd suggest getting an anchor that is likely to work rather than one that is bought because it folds flat to make easy storage on a NB. Danforth anchors are notoriously difficult to 'set' and can take 'miles' of dragging before the flukes start to dig in. On a NB you will (probably) only be deploying your anchor in an emergency, (ie, engine failure 200 yards before a weir) and you need to deploy, set and hold 1st time, every time. An interesting article : The Danforth is in essence an improved version of the 19th century Admiralty pattern and stockless variations thereupon. Superior steels and economical access to them permitted radical changes to the age-old designs, but the Danforth does not represent a clean break away from these types. It offers better holding power, and attempts to dampen the rotating impulse (which results from the presence of more than one fluke) by employment of several tricks including the retainment of a dedicated stock (located in front of the flukes rather than at the end of the shank). However, rooted in its past as a symmetrical anchor, it still suffers from a number of setting and behavioral issues. Because the flukes lie flat on the seabed before setting, the process of encouraging it to set depends on the tip of a fluke achieving an initial ‘bite’ – and on hard sand or grassy seabeds, this is not a given. It can skate along the surface without setting at all. This initial setting issue then implies other problems later. Some manufacturers of the type even admit to this problem, advising users to set the anchor at a very short scope in order to lift the shank and thus exert a vertical pull on the crown of the anchor, the hope being that the flukes will then be angled downward. This tacit admission that the anchor will not set reliably at sensible scopes must inform its consideration as a general purpose anchor required to handle wind veers, changing depths with tides, and the myriad of other real world ramifications. The Danforth types’ behavioral problems include an inability to reliably handle force veers. Rather than remain buried when a sideways or reversed pull is applied, they tend to twist and pull out. Similarly, if the anchor is dragged once set (e.g. in soft mud), it has a strong tendency to trip on one fluke or the other, rolling and again popping out. Once this has happened, the anchor is unlikely to re-set itself. There are a number of other issues, including a reduced strength and durability. Even with good quality construction and high tensile steels or aluminium alloys, the geometry of the design does not lend itself to a rugged build. The flukes are flat plates with little reinforcement possible, and the tips are easily damaged. Furthermore, if the force on the anchor is unbalanced, e.g. if one fluke gets stuck but not the other, it is very easily bent and destroyed. Finally, the aforementioned issue with accepting changes in the direction of pull has consequences should the anchor be very well set in hard ground such as clay. The large flukes may be sufficiently well stuck that the shank bends before the anchor will re-align itself, a common mode of failure. Such a fragile anchor so vulnerable to destruction in the course of normal usage has little to commend it to the role of a vessel’s primary anchor. Because the Danforth types are flat, they tend to be easily stowed, and are therefore popular secondary anchors. Additionally, they do without doubt hold well in simple circumstances, and so are reasonable solutions for secondary anchors (to be used where the anchor may be set once and not expected to handle more than a unidirectional pull). Nonetheless, there are other modern solutions which are superior for this purpose and avoid the drawbacks, including the Spade which has a demountable shank and is also available in aluminium – indeed the alloy version has been independently tested to out-perform the best aluminium Danforths on a weight-for-weight basis.1 point
Yes (to the first sentence). The “no overnight staying” guidance is intended to prevent mass migration from the cities to holiday homes in beauty spots, which would risk them becoming overburdened. I can understand that. There is already one rule for the plebs and another for the privileged, viz all the politicians, police chiefs, royalty, prime ministers et al who have scuttled off to their second homes (and got caught). So the moral point isn’t valid. There is a valid point about not spreading the virus irresponsibly but unless you can provide some insight I’m missing, there can surely be no increased risk of spreading the virus by sleeping on one’s boat overnight, vs 2 visits on consecutive days. In fact it seems obvious that the former is lower risk. Only fascists want to apply the law regardless of common sense (although let’s bear in mind there is no such law).1 point
We've all been there. Although some people are less likely to admit it than others ...1 point
I may have detail wrong, but Ponts et Chaussées with responsibility for bridges and roads was reorganised as the Conseil général de l'environnement et du développement durable (the general council for the environment and sustainable development) in 1991, with responsibility for the majority of navigable waterways taken on by the newly formed VNF. The river Somme, the waterways of Brittany, and the river Lot are managed independently. I really enjoyed the Morgan-Grenvile books too. Tam1 point
Hey, welcome back Alan! That's two weeks you've been away. Boy did we miss you during the virtual BCN challenge week (Alan was on our team - Barnier's Stern Gland - but pulled a sicky on day one!!!!!!!).....Alan, go and read the pm thread (20 pages of it) and the main log page to cheer you up....it was quite funny. Anywho, great to see you back nearly fit again!1 point
Quite disappointed that a moderator is continuing the non fun arguments on this thread.1 point
1 point
1 point
Ed Shiers at 4 counties marine. https://fourcountiesmarineservices.com/ Also the "go to guy" for travelpower issues.1 point
Isn't it like a lot of things, money and enthusiasm to create something and nothing to maintain it1 point
1 point
1 point
