1 hour ago, Tam & Di said:
The lack of 'style' is particularly noticeable when compared with New Dawn above, which has plenty of sheer, good side decks for easy movement when crewing, and dollies fore and aft which are unencumbered by bulwarks and are easy to use. But it obviously costs more to build - you pays your money and takes your choice.
Tam
It was built as a live aboard for use on the Leeds & Liverpool and other Northern waterways.
Tam
I don't like the shape of New Dawn either but as you say you pay your money and take your choice.
This is the only replica barge I have ever really thought looks right:
Edited by Naughty Cal
I didn't say I actually like New Dawn - it was only as illustration of what I saw as lacking in Mjölnir. I see it said now that it was built for residential use; there is always a compromise between 'boatiness' and living space in that case, and it has not been given sufficient consideration to 'boatiness' to my mind. I'd agree that Angell Hardy II is preferable to both, and answers all the criticisms I gave
Tam
I have noticed that at least 3 widebeams are now at Tattenhall Marina on the very northern end of the Shroppie. Don't really see the point as their cruising range is very limited unless they use the Manchester Shop Canal.
31 minutes ago, TheBiscuits said:
I see where you went wrong there!  Floating flats is more likely.
But, as Thor says, hey'll be within reach of the Shop Canal for all their retail needs.
I'm adding the Manchester Shop Canal to my list.
The Trent & Misery
The Grand Onion
The Leicester Suction
Kennet & Avon Calling
Yes there are more and yes I am bored.
Anything over 11ft wide isn't going to be able to pass under the M53 bridge to join the Ship Canal at Ellesmere Port.
Probably more that the ones on the North Oxford or the two in the marina at Alvecote
The Trent & Misery
The Grand Onion
Wey and Barren Canal.
  • 2 weeks later...
18 minutes ago, TheBiscuits said:
Whoever called that blue one "Graceful Swan" has a warped sense of humour!
Perhaps that's the serving hatch for bread and crumbs.
7 hours ago, Dalesman said:
A Dutch barge on the Leeds & Liverpool
I do like those Tjalks. Bugger all head room in them though even for a shortie like me!
  • 2 months later...
An interesting, if old idea, regarding headroom.
I expect it's range will be limited by it's length to width ratio.
Bod.
13 hours ago, Jerra said:
Can you have a widebeam narrowboat?   That's what the article says it is.
I think the term is used to denote a boat which follows the lines of a narrowboat but which has a broader beam, as opposed to Dutch barges, tjalks and other broad craft.
No. just as you can't have a narrowbeam wideboat.
It's about time that someone came up with a name for such craft rather than wide beam, after all narrow boats are only called narrow boats because they appear slender when compared to other craft. Wide boat would be more appropriate as such vessels did ply the southern waterways in horse boating days and were similar in appearance  to narrow boats only wider.
Keith
