centre-line mooring
spadefoot
Went for a stroll up to the wharf this morning. Total of 21 boats, 17 of which were moored using an additional centre-line, some tight, some slack. That's approx. 75% of moored boats, some hire boats, leisure boats, live-aboards, shiny boats, hippy boats. A real cross section.
So, there must be some on this forum who also moor like this. Own up, do you? And why?
We occasionally do.
Yesterday because of the high winds we certainly did.
If we are leaving the boat for a couple of days I do tend to have the additional safeguard of the centre line attached to the land/ground/earth.
Martyn
We used to leave our unattended boat with a slack centre line on our home mooring as a little insurance against one or both of the other lines becoming detached/breaking. Unlikely yes but possible.
Never used it at right angles to the baot, but frequently use it as a spring, running backward or forwards half the length of the boat or more, in conjunction with a second spring the other way if desired.
I can see using it slack as an form.of insurance does no harm, if often unlikely to help much, and can see that if you had a light boat in a secure and non-level-dependant, low traffic mooring it could be used to stabilise roll. In most uses I have seen it however its unlikely to do anything other than harm.
Daniel
I often see this and cringe. I also see boats with Pram hoods fitted ohmy.png I am assured by Mr Cameron that legislation will soon be in place to ensure offenders are arrested and charged and taken through the court system swiftly.
Tim
Illogical really: If 2 lines will part, then what's to stop a third unless its considerably thicker rope etc? The insurance against the mooring lines parting is to learn/know knots properly and check the condition of the rope frequently - and of course double them to tie the knot on the boat but that doesn't add security it merely means to untie requires being on the boat, not the bank.
The only time I'll do it is waiting at lock landings etc (and I try to avoid using lock landings......that's another subject though) or if its really windy and single handing and a stop is needed eg nip to loo, turn kettle on, etc. If its not windy then I stop the boat in the water and do the necessary.
I used the centreline as well as normal lines recently when on the Llangollen, but only because at the visitor mooring I was on had rings spaced to the exact distance between the boats t-stud and dollies. Using the centreline as a spring enabled me to stop the boat moving backwards and forwards with every passing boat.
I don't normally use the centreline for anything but holding the boat.
Tim
As i pay my dues, i had a word with my MP and he has assured me that they are going to deal with all the CMers, licence dodgers and general p takers and pump out users first ... so i will be safe to enjoy my lovely warm, dry pramhood cover for a very long time to come :P
Rick
Ideally you need either a T-Stud amidships on the toe rail / gunwale either side or a T Stud either side at the aft end of the forward well deck (by the break in the cabin). then you could rig springs for long term mooring or when the mooring rings are in the wrong place (always in the wrong place in my case!).
I did start off using a centre line, however as pointed out above if slack its only going to work when the other two have already broken and if too tight then loads more problems!! If I feel the need to rig extra lines I take the centre line off the roof and secure it on a lower point of the hull when needed.
<Third time of trying to post this....>
Given that like most simple things it took me no more a minute to tie the extra (centre) line off I don't really see it as illogical. We used to moor on a commercial water way with large tankers and sand barges passing that would create quite a pull on the lines sometimes. Even the CRT work boats there are bigger than you see on other canals. I took the view that if a bow or stern line gave because of a weakness I'd missed in the lines then the centre line would prevent the boat swinging right out into the waterway and give one of my neighbours a better chance of getting the boat back to the side to re tie it.
It would perhaps have been illogical on a narrow muddy ditch with narrow boats pootling along however where we moored I felt it offered additional insurance. I didn't do it anywhere else or if we were actually on the boat. I also didn't tie it tight as I only made that mistake once and the heel when Humber Pride passed was quite alarming!
Sea sickness prevention. Two centre lines spread-eagled, one staked down on the near bank, the other stretched way out over the water and staked down on the opposite bank, to arrest rolling. mellow.png
As i pay my dues, i had a word with my MP and he has assured me that they are going to deal with all the CMers, licence dodgers and general p takers and pump out users first ... so i will be safe to enjoy my lovely warm, dry pramhood cover for a very long time to come tongue.png
Rick
Yow
How ya doin Rick?
Tim
It's another modern practice that I fail to see the point of on most waters on our system. I can't see fore and aft lines failing at the same time unless by deliberate intervention. None of the old time boaters do this either, a good enough reason for me. I sometimes use the bulkhead rings rather than the tee stud if that makes life easier in terms of mooring ring or bollard spacing, likewise at the stern end I'll occasionally use the shackle on the gunwale on the anser pin. I prefer to take the line back to the boat to tie off with, preferring to use the boatman's hitch if possible. I see this centre line use often on hire boats, perhaps they are advised to do so during the see-out.
Cheers
Dave
When we were untied outside the NIA last year it was only when the scrote tugged on the centre line and the boat rocked a little we realised what was happening. I got out just in time to see him pedalling away and dragged the boat back in by - you've guessed it, the centre line.
We were tied up with the centre line because of awkward bollard spacing but I see nothing wrong with using as many or as few ropes as we wish.
It's nobody else's business, pure and simple.
I had to moor temporally with the bow and center line while waiting for Harecastle tunnel. When one of the boats coming out went by the heal was quite alarming. I don't think I would want to be exposed to the draw of a large commercial passing in case it rolled over, I think I would rather it swung out, but its something I dont have experience of. When on the Middle level I had to moor with the center line and always worried about level changes pulling the boat over.
Interesting discussion, but nobody has stated why you should not moor up with the centre line??
If you moor with a centre line tied tightly you will often find as another boat passes it will heel, sometimes quite alarmingly. This is because of the height of the tie off point used to tie the boat against the bank/towpath and the resulting way the forces are exerted.
Edited by MJG
Only ever used for holding the boat and when moored whilst I am operating a lock. Using a centreline for anything else is in the same category as hanging a rope on the tiller.............
On one boat I did have a cleat on the gunwale that was useful for mooring.
Edited by Loddon
