Laundry
little flower
Studio flat size automatic washing machine (3kg load, cold fill, max draw 1.6kw), so I can either run it from shore power or generator. I hang most stuff up to dry and it's generally dry in a couple of days. I also have a small tumble dryer for sheets which are too big to hang up in the boat. I just hang the vent pipe out the window. I don't use the dryer very much but it's nice to have when I've washed my bed sheets and it's wet outside.
laundrette's are so rare now days, and so expensive the ONLY way to go is a proper house size machine, whatever space it takes. I run mine from a quiet-ish Diesel generator, and hose it up to the water tap. It costs a 1 or 2 litres of Diesel now instead of a tenner. I hang the clothes over the stove in the winter bit by bit until it's all dry, and in the summer i go feral and put up a washing line on the towpath trees.
If your having machine problems post here www.washerhelp.co.uk
Washing machine (with hot and cold fill)
We're finding it impossible to buy a new washing machine for the house with both hot and cold fill - they're all cold only now, with the obsession with low-temperature washes. This is a great waste, as we have lots of free hot water, (as do most boats on the move). Are any dual-fill machines still available?
I hand-wash frequently, BTW, being mostly singlehanded, with a washing line and boathook clothes pole, or a line strung lengthways inside the boat, front and back doors open, when moving.
Edited by Mac of Cygnet
Someone mentioned that they have a recent LG model with hot and cold fill.
the short answer is YES you can buy a Hot and cold fill we have one. Its an LG model and it also has a cold wash button which turns the heaters totaly off and washes well with a good detergent without using much power at all so not even a big inverter required if fitted on a boat. It also is direct drive so no belts to slip or break. Look on LG web site, they are NOT cheap :wacko: but what is nowadays that is any good. I thinks its an LG WM something or other. :cheers:
Ive just checked its a 7kg size and the bill was over 700 quid.
Edited by mrsmelly
I've just looked at the specs of 5 different LG models and they were all cold fill. But then I gave up when I found this (from The Telegraph):
Green homes specialist Ethical Consumer (www.ethicalconsumer.org) published a survey of washing machines in January and found that there were no new hot-fill washing machines available on the market.
However that was 2 years ago. Anyone know better?
I had to check cos it was doing my head in. My bill is from 2008 so praps as with all things nowadays he models have been downgraded. I cant seem to find anew one know either. Ours is brill and megga quiet, no bumping and banging and produces steam if you want it to :wacko: Seems I better hang on to it but I bet some company realises the error of their ways and reintroduces a hot fill model before much longer.
You need to think outside the box....
My cold fill washing machine has a temperature setting knob that is set to cold most of the time, the machine is fed through a TRV so I can regulate the temperature of the water going in. the only dissadvantage is that I have to reset the temperature between wash and rinse as you only ever rinse oin cold water.
Edited by idleness
Your link indicates that this model is cold fill only, if you read it carefully, and Appliances Direct, which has the biggest range and fullest specs I've found, states that this model is cold fill only.
Edited to ask Idleness is a TRV a temperature regulating valve like in a shower?
And do cold-fill machines heat to a certain temperature, controlled by thermostat, or do they assume the water is cold and heat for a certain time?
It says Yes for hot / cold fill but cold only is a option...
Hot & Cold Water Inlet Hose option-cold fill only Yes
a cold fill only is marked as..
Hot & Cold Water Inlet Hose option-cold fill onlyYes (Cold Only)
I would suspect that anyone capable of installing a boat plumbing system could also install a hot/cold selector to fil on hot and rinse on cold. Though the point of an auto washing machine would be partly lost if it couldnt be run unattended.
Sadly in weather as we have just had -freezing! No ammount of soap or agitation will do a wash properly so even a "cold" wash may need assistance to get to 20C
Who will be the first to remove the electric heater and insert a coil from the primary hot water loop, use the heater voltage to control the heat exchange coil.
Edited by Arthur Brown
You could always import one yourself, LM? Here
Edit - as an aside - LM, could you design a shoe pod to wash peeps' Jimmy Choos? :blush:
The Sears site quotes them in Pounds sterling
http://www.sears.com/shc/s/search_10153_12605?keyword=the+laundry+pod&intShip=8&i_cntr=1329485926693
shipping (dhl) £20.00 plus Vat of £20.07).
I've bought lots of stuff from Sears (and Macys) no problems
Edited by larkshall
