Brass 'sliders'
frahkn
My back hatch moves on brass sliders. These have become buckled by rust on the steel below.
I don't particularly want to remove, straighten and replace them after treating the rust.
Some years ago there was a topic on here about replacing the brass with polymer sliders (or some such) but I can't find it now.
What are peoples thoughts about replacement sliders, their sourcing, advantages, disadvantages etc?
HDPE. I found a company online who would cut a small sheet into strips. Then drilled and countersunk with holes tapped into the steel underneath with some Sticks Like S*** for good measure.
I have that on the underside of the hatch that runs on the brass
Me too, except the fixed slide is stainless steel not brass...
Tufnol is a resin composite thing and seems to work well. Low friction, long lasting. Seems to have an indefinite lifespan as a bonus. Have washboards and pulley blocks made out of it and they're 40 odd years old.
Mine were stainless steel runners with steel hatch. Changed the runners with the HDPE and had a new hatch made from aluminium. Now opens with one finger.
Tufnol isn't as slippery as HDPE, which in turn isn't as slippery as PTFE -- but which is a lot more expensive and a bit of a pig to work with...
(I think mine are HDPE but I suppose they could be white PTFE)
Edited by IanD
I was told mine was PTFE, we had a lump left over at work and I thought that will be handy one day and it was.
I did it the other way round. Kept the brass runners and replaced the brass sliders on the hatch with HDPE versions. No help for the OP, but it is an option. A friend had access to a machine shop at the time and copied the brass ones using HDPE rod. HDPE has almost as good friction characteristics and is safer to machine than PTFE, while being cheaper to buy.
5 minutes ago, philjw said:
I had some form of plastic runners on a previous boat and although they  were slippery the buckled badly in warm weather.
That may be why on mine the long fixed sliders on the roof are stainless steel, and the plastic ones are strips under the hatch where they can't move or buckle because they're confined...
First, thanks for all the help.
A follow-up question - I have only the brass runners, the steel hatch slides directly on the brass. Would I be better to fit (say) HDPE to both surfaces? Does anyone know of a source of HDPE strips?
Steel  on HDPE or PTFE ( or vice versa) will slide fine.  Given that your steel is rusty , and this probably pitted steel sliding on HDPE fixed over the pits is probably easiest.
N
Fix the HDPE under the hatch to cover the steel (like the photo I showed), a thin strip will be fine, and you could use a suitable glue rather than screws. This will have less friction and means the HDPE is hidden away so less subject to damage. Don't use HDPE on both surfaces, on a sliding surface you want one side to be hard and one soft.
Edited by IanD
As a purely temporary measure I stuck some of these furniture glide strips to the underside of my slide.  Six years on they still work perfectly.  The simplest solution is often the best.
 MUNSKT 20 Pieces Self-Adhesive Furniture Glides Teflon Rectangle circular Self-Adhesive Furniture Slides PTFE Self Adhesive Furniture Moving Slider for Carpet Hard Floor Wood Floors Furniture
 (Amazon)
Edited by koukouvagia
 (Amazon)
https://www.amazon.co.uk/MUNSKT-Self-Adhesive-Furniture-Rectangle-circular/dp/B0CMHB5RDG/ref=sr_1_2?
Edited by MtB
Truncate the stupidly long URL
