A different type of coal
blackrose
I've just come back from Germany and below is a photo of a block of coal that they have over there. It's about 6" long and they buy them in packs of 20 or so. It's much cleaner to handle then the stuff we have here and I think it's much cheaper too. I don't know if it's suitable for the smaller types of stoves we have on boats, but I brought one back with me and I'm going to try it when I get back to my boat.
This is a picture of a stove in my brother's flat. It stands about 6ft high and has a flue at the back.
Edited by blackrose
I would have thought that breaking it up will make lots of dust and mess, ending up a much messier business than normal smokeless.
N
Is it manufactured?
It looks as if it's been cast from perhaps compacted coal dust or remnants.
Yes, I don't think it comes out of the ground like that! The smokeless coal we buy here is also manufactured from coal dust, powder and binders isn't it?
N
Why would you want to break it up? My brother just puts them into his stove whole and I will do the same when I try it.
Edited by blackrose
Why would you want to break it up? He puts them into his stove whole and I will do the same when I try it.
It's a very large lump to burn on a boaty stove. Only one would fit on my stove though in a wide boat you could have a much bigger stove, perhaps. I am convinced that you cannot burn a single lump of anything on your stove!
N
N
It's about 6" long. It would easily fit into a squirrel or a boaty stove of that size, but not a very small stove. My brother says he just gets them going with fire lighters without any kindling and then they burn for about 20 hours. He burns single lumps.
Perhaps you shouldn't be convinced about things on other people's boats. I've burned single lumps of wood on my stove before. Anyway, I will let you know how this block of coal burns on my stove tomorrow.
Edited by blackrose
It was in a plastic bag in my hand luggage yesterday and they x-rayed my bag twice. I think they were trying to see what it was! laugh.png
I bought some peat (turf!) in Ireland once that looked a bit like that. Maybe its German peat.
.............Dave
Could be. He has no idea what it is - he just says it's coal. It's really hard and heavy.
certainly would be easier to store and handle too ...I hope it works
is your brother up for handling mutli shipping orders?
If it works I'll find out how much it is and whether it could be imported.
It is odd sometimes the different things you see when you go abroad. Sometimes it's the other way around. I have a friend living in Austria who says you can't buy brass compression fittings for domestic plumbing. Everything is either soldered or plastic push-fit.
Edited by blackrose
Looks like lignite brown coal which if I remember was common in Germany when I was in the Army. Used to burn to powdery ash but not sure how clean it is? googled it it is a high polluter they are going to close down the power stations that use it if I have read it right
Edited by peterboat
I would no more buy peat to burn than I would use it in the garden! It is desperately bad for the environment to dug up peat.
N
I would have thought it was just a different shaped brickett like we have just bigger. I remember something similar we put in the stove similar to the one in the picture when I lived in Germany for a short while in the 1980s. The stove took a long time to heat up from cold but it was a great heat reservoir once it was and quite efficient in the amount of coal it burned. The compressed bricks we used were coal not peat certainly.
Edited by churchward
N
Er... we don't actually know it's peat. It certainly doesn't look like peat to me.
Yes, to me it looks and feels just like coal. Too hard and dense to be peat.
Edited by blackrose
N
Yes if you kept on digging it out you could end up with an absolutely massive hole, full of water. Almost as big as, say the Norfolk Broads....
What the OP showed is a "REKORD" lignite briquette produced by these guys:
http://en.brikett-rekord.com/index.php/The_right_fuels.html
from open cast mining near Cottbus, at the eastern end of Germany. Here comes the blurb:
Lignite briquettes are pressed from dried, prepared lignite without the use of binding agents. In contrast to firewood, the factory-made fuel is characterised by its high degree of homogeneity and has a constant quality which is continuously checked by laboratories. Only low-emission lignite types of a particularly high quality are used to produce lignite briquettes.
The handy energy packs feature a substantially longer burning life compared to wood fuels and a very high calorific value. They release heat evenly and in a well controllable manner. Due to their high energy density, there is no need to constantly put on more lignite briquettes and embers last for many hours.
Lignite briquettes require more heat to start burning than wood does and it's best to ignite them on an existing fire bed. The combustion air flows around the briquettes from below through the grate at the bottom of the combustion chamber. They may be used in all closed fireplaces that have a grate and an ash pan. Their use requires examination and release by the manufacturer.
Sounds eminently suitable all round for a narrowboat stove, I'm sure we're all eagerly awaiting the test results.
I see that that drova.lv (in Latvia) charge 270 euros for a 900kg palette, and about 1600 euros to do a 24 tonne lorry delivery to the UK, so if the test goes well maybe one of the coal boats should give it a whirl?
