Hi there folks,
Apologies for being another person looking for information/ history on their new purchase but I have just bought a River class butty by the name of Yeo.
 I know these dustbin boats arent the most revered of all historic craft (in fact, being younger than 1948 they dont even qualify for historic license discount) but im hoping to do right by this boat and put her back to working trim, albeit with a bit of an 'under bluetops' conversion.
If anyone has any information or photos of this boat I would be really grateful as there seems very little online that I can find so far.
She seems to have had some extensive work in the past (im guessing in the late 80s) including a nice mahogany and oak cabin extension and having a perkins 4108 with hydraulic drive fitted. If it were at all possible to find out who did the engine install I would be blown away, the system works right now but I would eventually like to move the engine, rebuild the stern to its original butty shape and reconfigure the system into the rudder in the same way as Hampton has so finding that original engineer would save alot of guesswork and research about the old system.
Secondly, im hoping to use the hydraulic system to power a generator and also two rams which will raise and lower the bluetops to offer headroom below when in use but can be lowered when travelling or wanting to look trad when other older boats are around :)  Has anyone fitted extra systems like these to their hydraulic drive? Id love to chat if so!
Thanks everyone..
Share this post
Are you intending to use your blue tops as a cabin? if yes & thinking of raising/lowering I think you would have a real problem with water ingress  The reason I say this I was contracted to the gas line laying in the towpaths of the BCN & my boat (Josher) was employed as tug, cook boat & general parts carrier, I 'obtained a couple of blur tops to make a shelter for the cooking equipment  & for being watertight were a complete disaster ended clothing them over with a section  of side & top cloths  having them movable I would have thought would increase your hassle factor with them Good luck with your project
Share this post
I can't actually get a feel for what you would be trying to achieve by this?
So with the "blue tops" jacked up (say) a foot above where they would normally sit on the gunwales, you then have a large open gap equivalent to the amount you have raised them by?
What am I missing?
Share this post
Nice boat and the raising the blue tops cabin is a novel idea. You'd need some sort of sliding or concertina type arrangement I suppose.
Or maybe some sort of roller shutter type system like you get over shop windows.
Or a steel cabin? Or if you are unusually tall then perhaps some sort of leg surgery. Or another boat ?
As for being "blown away" by details of the boat I would have thought Pete Harrison may be able to oblige if he's not too busy burning petrol.
Share this post
I'm 5' 10½" in my socks, and with blue tops on part of the hold of a middle Northwich, I had no trouble in standing full height with them set on the gunnel - with my boots on. Blue tops are rain proof, but not hose or bucklet of water proof. Any hydraulic apparatus to gain a few inches will be excessively expensive, and rather ludicrous to boot. Also, even if fitted successfully, almost certainly will be replaced by a future owner. Just a thought.
Edited by Derek R.
Share this post
Thanks for the advice on that, I'm planning to make a steel top with windows and vents that fits under the bluetops so hopefully water ingress from there shouldn't be a problem.
The main thing, as per Alan finchers reply, is the open side section that would be exposed when raised, my plan is to have the steel cabin walls extend into the hold and have a rubber sliding section or skirt that will trail over the lip on the hold to stop rain entering down that face.
Thanks, I'm the same height and can't stand under the blue tops, I'd like to raise them by 8" and am pretty sure the system I'm planning will work reliably and be fun to make, surely that's the main thing.
Share this post
It's a brave idea, but sounds like you are re-inventing the wheel with corners.
I'm missing something here: that you are intending to build a steel cabin beneath the blue tops, but have the blue tops elevate. Does that infer that the steel cabin also elevates? This is getting complicated. I envisage rust, moss, and other winblown debris (not to mention vandals) ingressing the sliding mechanism that runs the length of the cabin, and servicing the space twixt blue tops and steel cabin. How often is it planned to use this mechanism in reality? As the ongoing maintenance costs may reflect an unforseen cost which prospective future owners (and you will sell it on at some point) may view as a white elephant. I hope it doesn't turn out to be a project like the Foxton Inclined Plane. It will certainly give you hours (years?) of 'fun', and as it is your chosen project I wish you well with it. Not much a thread on Historic & Heritage boats can offer much advice methinks! Look to Showmen's caravans for extending body sections (theirs generally go out sideways than upwards, but the basics are similar).
Share this post
Thanks for your input, I dont think the idea brave or complicated, the steel roof will raise and its exposed side will be covered by the sliding rubber valance that is fitted to the gunwale lip.
I think I was mainly posting to find any history on Yeo and if possible to track down the mechanic who installed its current hydraulic system, it may be better that I PM Mr Pete harrison for these details. Further to that, if anyone has any actual experience of adding extra hydraulic systems to their drive I would be really happy to hear from them.
Share this post
Why not fill the hold with neatly stacked steel barrels welded into place.  Then with a gas axe crawl in underneath them and hollow out the space you want? From the outside you'll have a boat that looks as if it's loaded with cargo even though the depth in the water will look odd. Inside however you'll have a dark gloomy cabin with so many jagged edges that you'll need to carry a complete blood transfusion unit in the back cabin.
Another idea might be to revert to a horse drawn version. Only have a specially made tent in the shape of a horse.  Then at the end of the day you erect your horse and sleep in that.
Being a fan of hydraulics I've always wanted to buy a Thames Sailing Barge and insert piano lid hinges stem and stern.  Then using hydraulic rams I'd pull the sides in so I could get to the top of Napton.  At that point I'd shove them back out again and leave everybody scratching their heads.  Imagine the fun when you turned up at Banbury and asked to use Tooley's?
However a genuinely historical version would be to go the Harbour Master route. I'm sure standing next to a clattering multi cylinder diesel engine just over head height all day has a lot of merit in it.
Share this post
On 12/6/2017 at 17:10, sparrowcycles said:
 I know these dustbin boats arent the most revered of all historic craft (in fact, being younger than 1948 they dont even qualify for historic licence discount) but im hoping to do right by this boat and put her back to working trim, albeit with a bit of an 'under bluetops' conversion.
The 1948 cut off point no longer applies.  The CRT guidance notes say: "The basic structure of the boat should be more than fifty years old. Some later modifications may be acceptable but substantially altered boats will not be eligible for the discount."
You could try registering with National Historic Ships (no cost) which helps I believe.
regards
David L
Share this post
regards
David L
Thankyou, David. Thats a great help, I will do just that.
regards, steve
Share this post
Apologies for this, and please ignore the association with politics - it's the engineering aspect that is relevant. It shows the fascination of seeking complex alternatives to non-problems.
The device is intruiging and fascinating to watch, much like the curling and uncurling bridge in Paddington basin. But the result of the complex arrangement is a device far less efficient than the wheel which is here replaced (or a swing or lift bridge). Inginuity and invention at work - yes, but a practical end result? It looks like hard work to drive the pedals around, and the frailty would show on a rough surface. The fact that it 'can' be done over-rides - dare I say - commonsense?
Share this post
What you need a a few old jcb arm rams conceted to a hydrolic drive run off the engine or a seperate geni.
Put a angled 45 deg lip facing up from the edge of the open part of the hull with a soft rubber or silicone edge (blue tops down cover the lip and edge)
Then inside the open hull a 2 foot sheet of steel attached to the top of the blue tops and on the bottom the jcb rams the jcb rams then sit on the floor,
As you extend the jcb rams this pushes the sheet metal up raising the blue tops the 45deg lip and silicone rub up the side of the sheet keeping it fairly water tight raise till at desired hight, to lower just lower the rams till they stop, it wont be 100% water tight but will be semi cheap to create and get the desired affect.
For any long time the rams are up to make more water tight you could always put grease between the rubber and sheet metal.
The final option rather than the rubber seal it to put a clear plastic to the inside edge of the blue top and just on the outside of the hold lip but in enough its covered by the blue tops when down cut to the right hight for your rams fully up so you get a strait clear plastic outside window keeps it water tight and lets light in threw your port holes in your sheet metal, a bit like what you got on vw camper van roofs but made of clear plastic like what you get on boat canopy covers.
Share this post
Thanks mate that's basically what I'm planning, I have two ex BW dredger rams and am planning to make an EPDM rubber lip that will extend past the upstand in the hold when extended upwards but can fold in when dropped down.
Let's see how it goes!
S
Share this post
Hi there folks,
Thanks everyone..
And why not? Go for it - I'm about to lavish a lot of attention on a 1972 hire boat, probably go back to original livery (although without the company name) replacement authentic Lister ST2 etc. It's what we do!
regards
David L
I didn't know that - I'll bear in in mind for Lutine's lap  of honour on her 50th birthday (not sure what I'll be doing a lap of though)
:clapping::lol::clapping:I want one! Half a dozen in fact, there'd be a rental market in Frome for those! :lol:
Share this post
I'd just like to say what a pleasure it was to meet "sparrowcycles" in the flesh today, actually out boating with "Yeo".
This boat had previously looked a completely neglected basket case, with no sympathy at all to its historic boat origins.
Although much bigger things are clearly planned, already the boat looks many many times better than it did, but not only that, it moves - I had always assumed it didn't.
Well done indeed!
Share this post
Well done indeed!
I bumped into Steve on his way down, boating through with the Bantock butty Violet - I'm not sure if I've seen two motorised buttys travelling together before. Yeo looked quite impressive and is obviously in good hands.
Share this post
Well done indeed!
Thanks, Alan. It was good to meet you all in the flesh too and to see Sickle and Flamingo in action. It's been fun trying to stay ahead and not slow you down today!
There's plenty more to do on Yeo, if anyone knows of about 7 blue tops going spare I will be on the market soon once I take the extended cabin off.
3 hours ago, stagedamager said:
Violet got stuck in Napton yesterday so the book of Face tells me....
Haha yeah it was another victim of the deformed lock there.
Thanks, Stuart. I have had to tow violet a few times, some people who know their buttys do give a funny glance when they see that. It was good to meet you by the way, I like the work you have done.
Share this post
I don't know if they are still there but there were some blue tops at the back of Union Canal Carriers, bottom Lock Braunston.
The owner of Kew has blue tops on his boat, worth asking if he has any spare?
http://hnbc.org.uk/boats/kew
Edited by Ray T
Share this post
I suggested this to Steve yesterday, and apparently he has already approached Union Canal Carriers who are not interested in selling them.
A shame, because given UCCCos origins, it ought to be supprtive of restoring them to a working boat of the type where they actually belong.
However I gather Steve has a hopeful "plan B"!
Share this post
Thanks, I have asked at ucc but will try the owners of Kew!
Share this post
Wayne's a dab hand with fibreglass. Perhaps he could take a mould off an existing one and make some new copies. Might even flog a few to other boatowners.
Edited by David Mack
Share this post
Malcom Braine has (or had) some for sale!  About 2 whole sets if I recall.
Google “Canal and River Services” at Weston, Staffs and talk to his son Ian...
Paul
Edited by Paul H
Share this post
I'm glad to see that you are restoring a 1970s hire boat. I am concerned that a whole generation of boats will be lost. Hire boats were really important in the 60s and 70s in helping keep canals alive and good examples need to be preserved. I have a hankering for an ex Willow Wren wooden top. I know where there is a good one but its not for sale. I did see ex Middlewich Sycamore on our travels at Easter - it still has the bull bars on the front to stop the wooden cabin getting bashed on the Llangollen lift bridges. Sadly all of these boats must be getting a bit thin.
Share this post
