Just seen this on fb. Does anyone know more about it??
I'm surprised if it's as reported it hasn't had more "airtime".....although some of the other articles by The floater" are a little..... shall we say....sensational
"Stuck in a tunnel - for nearly a day
A 20-hour nightmare jammed in a low tunnel was the start of the cruising season for a boat leaving Hawne Basin on the Birmingham Canal Navigations, as Peter Underwood reports.
While making their way towards Netherton, and just after entering Gosty Tunnel the boaters found their boat, suddenly and without warning, stopped dead when it became jammed solid by a large log against the tunnel wall.
Although only 500 yards long Gosty Tunnel is notoriously narrow, and shallow with a very low roof in places and travel through it is painfully slow at the best of times.
http://www.thefloater.org/the-floater-april-2017/stuck-in-a-tunnel-for-nearly-a-day"
Are you suggesting that it's a crap report?
Were the people and their boat successfully extricated? If so, how?
It says they were rescued in the report after another boat came along and found them and then phoned Hawne Basin who sent a boat in to help them...
Edited by frangar
It's certainly narrow and low and not much fun but I wouldn't say Gosty is shallow - we went through it in our three ft deep boat okay. It's just very very slow progress.
A nasty place to get stuck all the same.
I can easily believe they got jammed by a log - we came through a month or so ago and there were several large logs along the side between Gosty tunnel and Hawne Basin with several already floating in the canal. We definitely hit 1 or 2 going though the tunnel and thought at the time it would be quite easy to get jammed in there.
Was it a trunk call they made?
Will make for an interesting entry in the ships log.
Perhaps they'll want to leaf it out.
Perhaps they were flushed out? What an in convenience!
we did this canal trip from bumble hole down to the basin and back, recently...
what a place people are friendly and the little café was stunning ...great breakfast.
on the way down to the basin we we`re grounded 4 / 5 times very shallow,and crap around the prop..
Edited by canalsteve
We got stuck in Gosty Hill Tunnel for a couple of hours once, broken down with a fuel filter problem. The tunnel profile made it rather interesting to pole ourselves out but we managed it eventually. By the time we got out it was too late to go to the pub so we moored overnight just outside the tunnel.
Given the staggeringly slow progress through I experience with my 2' 8" draft boat I'm inclined to agree this indicates shallow water, as suggested by others too.
Isn't Gosty Hill tunnel the one where the middle section has a lower roof because the tunnel sank due to mining subsidence? If so, wouldn't that middle section be deeper than usual? Going through there last year aboard Nuneaton on the BCN Challenge, I don't recall any difficulty with depth. I think we'd have drawn three feet or just under at the back. We had most of our large crew huddled near the bow as ballast in case the mast might otherwise scrape the tunnel roof, but as I remember it we fitted quite comfortably.
11 minutes ago, mark99 said:
Terrible especially if you are scared of gosts.
Or even gorsts.
Anyway, we draw 2'8" static and I don't recall it being particularly slow, but inevitably fairly slow due to the need for the water to get past around the boat - the tunnel is pretty narrow. IMO with the clearance issues, it's probably not a tunnel you would want to romp through! Although according to our boat builder, you don't need to bother steering through it as the boat will rattle through without any risk of superstructure touching. I didn't want to try it though! But it would be interesting to set it off in gear and then retire inside until the outbreak of daylight!
Edited by nicknorman
22 hours ago, frangar said:
Sadly that link doesn't work for me...poss because I'm not a "friend" of the person concerned.
Having never met any of these people I couldnt possibly be a " Friend "
