Made my brain hurt doing this. It is the best I can do but it appears the rope is held by strings attached to the chimney base or hand rail.
Edited by Ray T
Very interesting pic Ray. I've always disliked placing my stern line on the slide hatch or on the roof, this looks like a more convenient place to store it.
I doubt my modern line will form a nice loop like in your photo though. Far too floppy.. And it's black not white. Nor does the line in your photo appear to be the stern line...
(Should I give up now...?)
MtB
MtB
Possibly a tow line from a horse?
I does look as though the boat is moving, a spare tow line perhaps?
Unless it is a "posed" photo, I doubt we will ever know.
Edited by Ray T
I would assume that is the strapping rope for stopping the boat in the lock. Once out of the lock they would let it trail in the water to clean it self then hung up to dry as the picture shows.
Darren
great bit of information Ray - love the photos, did you take the black and white ones? you will have the copyright brigade after you if not - lol - (Only joking guys) ;@P
"The Amendment also provides several trial protections, including the right against self-incrimination."
Edited by Ray T
If a picture is available on the Internet (public domain) it can be used as an illustration in a discussion, under the 'fair use' rules. As far as practicable , copy right or ownership should be acknowledged as a courtesy.
This is of course completely different from using such images and pretending they belong to you.
I didn't know that, thank you Ray
Anyone at Hawne Basin on Monday morning would have seen Andy on Dove demonstrating the use of the cabin rings as he turned out of his mooring.
Richard
Just make this clear (due to reading the above wrong the first time), I used the backend line to get out of the mooring. :)
Andrew
I don't care which line you used, it was beautiful to watch. I can see I have a lot to learn about handling a boat using lines
Richard
Richard
Agreed, yes it was beautiful to watch.
That was a most elegant departure, Andrea steering and Andy on rope .
Working boats do have a form of bow thruster, it's a great long pole . No electricity or hydraulics , usually powered by beer and meat pies.
I was most impressed by the teamwork , Boris would have argued about the best way to do it and then let go of the rope at the wrong time and probably fallen in just to put the icing on the cake.
Edit , Cobbett bow thruster is an excellent thing , in a crowded basin with a tricky wind blowing especially so.
Edited by madcat
Because Dove's bow would only be two inches in the water?
Richard
And therein lies the point. Making the very short couple between the prop and the dolley worked because there wasn't much drag from the un-ballasted bow. I doubt it would work so well on a leisure narrowboat.
Worth a try though
Richard
I did try it, when pulling away from refuelling at Hawne. Yes there was a slight turning effect but not as much as had been visible on Dove. Edited by nicknorman
Do you use the trick of reversing against a line from the stern bollard? It's a neat way of putting the bow out
Richard
Richard
No, the trouble with that against a concrete jetty is that it graunches our shiny tunnel band paint. Instead I used fwd with the offside dolly tied. There was certainly a turning couple, but I suspect if there had been any significant "onshore wind" it wouldn't have worked
The delay in obtaining the results is not good.
It is time to change the system so that the results are available quickly. Each boat should know its nominal placing to date within 30 mins of finishing, and the running placings should be available throughout the afternoon/ evening as the final boats come in.
That means each boat must do its own scoring and that means that they need to be given the answers to questions on arrival & be trusted not to phone them to not-yet-finishers. It also means the log needs to be redrafted to be much more user friendly.
A big increase in trust will be required.
It is a bit early to require all competitors to be online for the finish but that day will come and make it much easier to administrate.
Perhaps early finishers should be called upon to help? The present system may have served well in the past but it now needs improving.
