I have used Gunk for decades. Nastily odorous brown degreaser. Worked really well.
I need to clean under the engine so I bought some Gunk Ultra.  It came, pink, like Jizer, but not the same smell.
Absolutely useless waste of money. Washing up liquid, the cheapest I could find, is far better at degreasing.
So don't be misled, Gunk is not what it was though they still sell it in the tin can but not Ultra so its not the same stuff.
31 minutes ago, bizzard said:
Paraffin is as good as Gunk was.
My experience too. Gunk was probably paraffin at ten times the price, with colouring and scent in it.
1 hour ago, jonesthenuke said:
Same problem as Creosote. Ban the nasty chemicals and the product becomes useless (e.g Creosote vs Crecote et al)
Ahh yes, whither the Nitromors of yesteryear :(
You can still buy  'proper' paint remover containing dichloromethane but have to be registered with the HSE to purchase and use it as a tradesperson.
I bought a pack of "Ultragrime Pro" wipes from B&Q to clean underneath my engine. I didn't expect much, but they turned out to be brilliant. As effective as paraffin, but far easier to use.
Which of these was it?
https://www.amazon.co.uk/dp/B072K3XYQR/?coliid=IF33DXR552AVT&colid=1MPSKA67E9V0E&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
OR
https://www.amazon.co.uk/dp/B08VW93JDP/?coliid=I3LR7XMJ8R0VCO&colid=1MPSKA67E9V0E&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
The first one (blue pack). I ended up cleaning all sorts of other things too, but still only used half the pack.
Thanks, that one appears to offer better value but it wasn't clear what the difference was or whether the red one was better in some way.
I've never really understood why so many boat engines are covered in oil and dirt? Oil leaks, clumsy topping up or changing of oil, or just years of neglect?
A BSS inspector was once visibly relieved when I lifted my deckboards to reveal a clean, dry engine room. "You've no idea the amount of filthy crap I have up deal with" he said.
So were they "tough on grime, tough on the causes of grime"?
I bought some similar wipes from Screwfix to clean up after a recent battery explosion. I used some old towels first and then went over everything with the wipes. Expensive but much easier than using cloths and rinsing them out.
Edited by blackrose
I think the red ones claim to have some sort of textured surface. The blue ones feel like normal wet wipes, just thicker and more robust.
Not much good on the cause; I needed a spanner for that.
Bought a pack of the blue ones to try out. £10.61 on Amazon after ticking the 15% discount box, 6 month subscribe and save although I'm sure I'll be deferring it for some time to come.
Thats why you see 205L blue drums of Methylene Chloride  behind the sheds at Braunston. It was the active content of Nitromors and used neat I would think it would be excellent for removing any number of layers of paint
I believe Gunk was based on a coal distillate (so smelt a bit like creosote) but was water soluble unlike paraffin.
Good point, I think you're right! I vaguely remember it being claimed to be water soluble on the tin, but finding it not so when actually used.
Unlike the supposedly water-soluble cutting fluid we used in the machine shop when I was an engineering apprentice and looked like milk once mixed with water, and which I always thought was forming an emulsion rather than dissolving. I gave up arguing about it with my boss at the time though, as he always knew better than me. :)
Cutting fluid is certainly an emulsion, what do Bosses know.....
Useless fact of the day:
Cutting fluid is a  really odd emulsion.
Emulsions are an oil and water mixture.  In most emulsions the tiny drops of oil are surrounded by the watery substance.  In cutting oil it is the other way around.  Tiny drops of water ( and corrosion  inhibitors and other stuff) are surrounded by the oil.
N
You can buy pure dichloromethane without a licence for use as a solvent for welding plastics. It is sold under the brand name "plasweld" and is available in small (57ml) bottles from shops that sell plastic model kits, and larger bottles on-line. I think the regulations only prohibit its use in paint strippers for non-commercial users.
Edited by Ronaldo47
Typo
18 hours ago, ditchcrawler said:
When I started Offshore we used barrels of Jizzer for deck cleaning etc. later we changed to Citraclean, that smelt lovely
We used that for degreasing in the nuclear industry. Smelt lovely and made the mechanics smell good. Well, better than normal but one didn't go around sniffing them.
