Short distance as in feet or long distance as in miles?
Google maps has a reasonable distance tool if you want miles.
Edited by Loddon
7 minutes ago, doratheexplorer said:
Still confused about what you want to do?  Do you want to measure metres on a map?  Or do you want to measure the width of a room, say?  What device and operating system do you have?
The width of the canal. Android phone?
Then you don't need an app as such.  Go to google maps.  Turn on satellite view.  Use the measuring tool to measure from one side to the other.  I can't see any more accurate method without a tape measure.
Perfect?
I used Google Earth once to measure canal width to see where I could turn my 55ft boat to save a lengthy return trip, although you can not tell if you can use the full width. Probably uses the same images and measuring as Google Maps.
Handy for showing tne width, but a shame it doesn't show the depth. ?
You need Google Marine for that. It’s not been launched yet but don’t think some bright young thing hasn't thought of it...
Edited by WotEver
Google earth regularly updates images and you can look at them all through the history button. Great for seeing how an area has changed. Some areas have images from 1945.
Imagine the effort that must go into wrapping all that onto a sphere and blending all the edges seamlessly together, instead of just showing it flat like it really is :D
if its distance you have travelled you could use the app Strava  used for cycling running and walking
it will also show you the profile of your route
5 hours ago, buccaneer66 said:
If you are using Google Earth click the planet icon in the tool bar and you can pick from google moon, google sky and google mars.
Just how far do you think the OP is travelling? :blink::wacko:
If you want to know distance travelled, Nicholsons has 'lollipop' for every mile of canal.
If you cruise long days, you may need to take off your socks and shoes so you can use your toes as well as your fingers.
and Jake the Peg can count up to 25...
Where can I get a Nichollson's Guide to the Canals of Mars? ?
  • Love 1
You could try the works of Edgar Rice Burroughs there may be a guide in his Mars series.
Where is the measuring tool on Google maps?
Depends what device you're using.  The easiest way is with a laptop.  Right click anywhere on the map and a menu will appear.  One of the choices is the measuring tool.
On my phone you press and hold to drop a pin, then pull up the menu which appears at the bottom and choose 'measure distance'
Edited by doratheexplorer
