4 hours ago, Alan de Enfield said:
You have much to learn grasshopper :
Coal ash is incredibly dangerous. Short-term exposure can bring irritation of the nose and throat, dizziness, nausea, vomiting, and shortness of breath. Long-term exposure can lead to liver damage, kidney damage, cardiac arrhythmia, and a variety of cancers.
Coal ash contains contaminants like mercury, cadmium and arsenic. Without proper management, these contaminants can pollute waterways, ground water, drinking water, and the air
I'm hardly a grasshoppper,
  https://www.scientificamerican.com/article/coal-ash-in-soil/
Suggests fly ash is used for crops. Most artiucle I have seen say:
1) The soil already contains traces of the same contamiments and contaminents of fly ash is of a low level
2) If you are worried, then use on soil being used for ornamental plants and other non food plants
3) Use instead of salt / rock salt on frosty paths
Given I don't snort any form of ash I don't suffer any of these ailments. In fact you're far more likely to suffer these if you over indulge.
You do appreciate the difference between 'fly-ash' and the ash from the bottom of your SF stove ?
Fly ash is a fine powder recovered from gases created by the burning of coal.
Ok, so what is the difference of chemical composition between bottom ash and fly ash?
I understood the chemical composition was dependent on the source of the coal.
1 hour ago, Wanderer Vagabond said:
It was a rhetorical question since I'm obviously not going to dump it, but it is getting increasing difficult to get into more and more recycling centres. Leaving a scrap microwave in a spare room at my postal address isn't quite the same problem as having to work around one on the floor of the saloon on the boat. Even the recycling centre at my postal address you have to book a slot and give the car registration of the vehicle you will be bringing the recycling in, not much help when you don't have a car, pedestrian access is not allowed.
Plenty of people must be without a car .  What do they do ?
Do you not have any friends or relatives who have a house and a car who could help you out with the microwave disposal?
Our local counciler is frustrated that the money-saving restrictions on what you can deposit at our local  rubbish dumps,  operated by the County Council, has lead to an increase  in fly tipping, the cost of removal of which falls on the shoulders of the local councils.
Re the toxicity of coal ash, the substantial tip heaps of ash from the old Beckton gas works in East London next to the A13, known locally as the Beckton Alps, were for a while repurposed as a dry ski slope. A chance  testing of the subsoil established  its toxicity and resulted in its closure.
Probably an almost-forgotten use these days. My Dad used to scatter the ashes from our (coal) fire to melt the snow and ice on our section of pavement. I tend to use salt, but have used (mainly wood) ash on occasion.
23 hours ago, Alan de Enfield said:
Thre is no need to handle the ash - out of the fire with a shovel, tip it into the ash-bucket, tip-ash bucket down the outside of the lock gate to seal the leaks.
So it's ok to chuck it into the canal then, as long as it's at a lock? 🤔
I thought that was the last thing we were supposed to do?
"Untouched by human hand"
Not heard of this before, is this a recognised thing to do with ash Alan?  Always learning!
Yes it WAS standard practice (in the "old days")
Leaky lockgates, tip the ash down the outside and the flow of water drags the ash into the gap where it forms a thick paste and stops (or at least much reduces) the flow.
It may well not work on some of the seriously damaged / distorted lock gates of today as the gaps are so wide the ash would just wash straight thru'.
See Phoenix-V post above  and the link :
 Ashing up the gates (narrowboatworld.com)
probably 2 reasons why it is not common now, 1) CRT has no corporate memory anymore 2) it probably doesnt work with ash from smokeless
CRT definitely used it to slow water flow through the stop planks on a recent planned closure on the ponty aqueduct
And pointless if the lock is about to be turned. They do/did it on the Basingstoke after the booked boats had passed knowing the lock would not be turned again until the next booking, not as soon as the boat in front was out of sight.
Not something boaters should do to get rid of their ash on a routine basis, it was done for a reason.
That might have been Bentonite?
Nope it was definitely ash they scrounged it of the local boaters, eventually the planks became soaked and expanded enough the provide a decent seal
On 15/11/2021 at 09:09, Phoenix_V said:
...... 2) it probably doesnt work with ash from smokeless
We use it to do the final seal on the dry dock when emptying it. Smokeless works just fine.
All marina ash is kept in empty blacking containers(most of the boats in Winter have one at the walkway end of the pontoon).
I can second that having used it to stop the windows leaking when raising a sunken narrow boat.
Keith
  • 2 weeks later...
Fly ash is chemically identically to grate ash......to burn coal in a huge boiler,it is ground to powder and blown into the furnaces by steam or compressed air...the  powder coal burns to ash in the furnace ,and is exhausted via a separator..Fly ash is akin to cement ,and is a valuable additive to concrete...............When the carbonaceous material is burnt out of coal ,whats left is a baked shale .....dried clay.........the harmful materials in coal such as tar, arsenic,phenol,aromatics,etc either burn,or go up the flue and are either exhausted into the open air,or in the case of arsenic and tar ,condense in the flue................Consequently ,the harmful material from a coal fire is not the ash,but the smoke................so you saturate the countryside with harmful particulates and gases,and worry about the disposal of a bit of hard dirt.
Edited by john.k
Compared to the real issue of fly tipping (https://www.theguardian.com/commentisfree/2021/nov/24/waste-dumping-uk-environment) a few Kgs of ash is a bit of a minor issue.
58 minutes ago, MtB said:
And further to this, if some other boaters putting ash under hedges is important enough to be posting about, life must be pretty good!!
Every little helps, and to be fair, Maffi historically has done a lot to tidy up the towpaths, and is therefore entitled to be a bit cross when others start dumping their waste where they shouldn’t.
