Pirateringo
How noisy inside boat when engine running?
3 minutes ago, Pirateringo said:
When my engines running the inside of my boat is very noisy. Is this normal? I always thought it would be quieter
Depends on...
  • The engine make.
  • Whether the engine is air cooled or water cooled.
  • The engine location.
  • The engine’s mounting method.
  • The soundproofing around the engine.
Share this post
How the shaft is isolated from engaging movement/vibration. How much stuff like widows and cupboard contents are rattling and so on.
Share this post
An Isuzu should be pretty quiet compared with say a Lister. Looks like you need some sound proofing.
Yup, that too :)
Share this post
Made a big difference to the sound of the engine under way inside the boat when I fitted a Python Drive.  Also, sitting up the front of the boat I can barely hear it when it it running at around 1000 rpm out of gear.
 Engine is 42 HP  Vetus with standard exhaust and no sound insulation except under the deck boards.
Share this post
No, in the sense of adding absorptive materials. Yes, in the sense of investigating the mechanism(s) of sound transmission.
I suggest the exhaust system as a first port of call.
Share this post
Until the OP can give us an idea about what the noise is then I would suggest trying to  stop sympathetic vibrations from things like doors, windows, crocker & cutlery. Also loose parts of the fit-out. What cause that vibration is, as above, open to question. I think exhaust noise makes itself apparent far more outside the boat than in.
Its a four cylinder and one that is usually flexibly mounted so if the noise is worse in gear than neutral I would suggest shaft alignment unless they have an Aquadrive/Pythondrive type coupling.
Edited by Tony Brooks
Share this post
I agree with all of your post but given the inexperience of the OP it is worth making sure the system has no leaks, and the muffler (silencer), if present, actually has baffles!
Share this post
I was surprised how noisy our (ex-hire) boat was with an Isuzu 42 when we got it. Flexibly mounted with Aquadrive. At cruising speed difficulty to hold normal conversation on back deck, and very noisy inside.
One of the first jobs was sound insulation (foil faced foam sandwich type with lead like layer in the middle), followed by hospital silencer. Whilst it's not silent by any means, you can easily hold normal conversation on back deck at cruising speeds without raising voices, and when idling can't hear it at all at front of boat (inside our out). There's been times I've accused the wife of turning it off, only to find it still running when I venture back there! Really surprised how much difference it made, and surprised all boats don't have this.
Share this post
It doesn't seem as loud on the deck as it does inside. It's like a deep rumbling and the vibration is quite noticeable. Thanks for all the replies
It could of course be the OP's 1st boat and he has only recently purchased it, with expectations of noise levels being similar to 'being sat in a car
LOL this made me laugh. It is my first boat. But I've been on a few trips on boats and never really noticed the vibration and sound like this.
Share this post
I don't think it's exhaust related unless that could increase vibration? The noise when I'm at the tiller doesn't bother me it just seems excessively noisy inside. Might be me expecting something else
Share this post
If Vibration is a problem did you have the engine mounts looked at for the survey ?
It is not uncommon for one or more of the engine mount rubbers to 'delaminate' or become detached from the metal, even for one to fail completely.
WITH THE UTMOST CARE.
With the engine running - Take a vey long screwdriver (or mooring pin) and put one end in / tightly up to your ear.
Take the other end and 'dab' it onto the engine mounts and all over the engine.
The engine could be out of balance if one cylinder is not firing
WATCH OUT AND STAY CLEAR OF ROTATING PARTS
You will feel the source of the vibration in your ear bones as soon as you get close to it.
Edited by Alan de Enfield
Share this post
And, if I remember my medical training correctly, your ear bone is connected to your brain bone - is that how it works?
Share this post
If the mounts are loose, worn or otherwise broken that would allow the shaft to bang about in the stern gear. Even it they are not that sounds horribly like shaft noise to me unless it does it just as markedly in neutral.
Edited to add:-
still need to know if its the same in and out of gear because a low rumble in gear could be a gearbox bearing.
Share this post
7 hours ago, Pirateringo said:
isuzu 42hp
Same engine in our 69 footer.  In the rear cabin, you can hear it, but I wouldn’t say it’s noisy.  Down front, you can’t hear it at all...
Share this post
I’m usually steering so unaware of the noise inside.
On the odd occasion when I’m inside and someone else is steering I’m surprised how noisy it is.
 if I trust the steerer I can sleep through the noise
Share this post
Ours is noisy but the engine is on oak blocks not rubber and its a bloody old tractor engine.
Edited by ditchcrawler
Share this post
Hmm it was from the front I experienced the noise. I'm guessing there's something up.
Share this post
Edited to add:-
Hi Tony will find out when I'm back at boat ?
Just now, Goliath said:
It’s what it sounds like from the outside anyway.
Its not too loud outside in my opinion, certainly no louder than others I've heard
Share this post
8 hours ago, WotEver said:
Depends on...
  • The engine make.
You forgot 'how good is your hearing'
Share this post
