Leaderboard
Popular Content
Showing content with the highest reputation on 26/08/21 in all areas
  2. I keep an old leaky smelly air bed for guests, they don't stay long.
    4 points
  3. As a general rule, never go for the electric version of anything that heats up. Heating stuff demands a lot of energy, canes your batteries and 12V heating energy is feeble. Kettles are a good eample. The 170W kettle performance will be pathetic. Use a kettle on a gas ring.
    4 points
  4. The Yonne agin. The locks get wider, yet more primitive, on the way towards the Seine. The freight barge seen leaving is pushing another, occupying the full length of the lock when inside. To moor up on entering from above, the bow is brought to rest against the vertical bit of wall just before the lower gates, which involves some fine calculation on the steerer's part, being 2 x 38.5 metres back from the point of contact. These boats are built of thinner metal than narrow boats are made of, and they had 500 tonnes of grain on board. On this pair the captain and his wife took turns up at the bow end, communicating through loudspeaker connection as they made their way on.
    4 points
  7. 30k seems cheap to me, it’s a boat I’ve seen a few times, and I’d love it.
    3 points
  19. 10/10 for spot the mooring. It was indeed that one -I had a jolly pleasants nights kip there after they had all left for the night 😀
    2 points
  20. I sent Jason a link to the thread and told him he can't afford it 😃 - he's too busy with his yacht repair business in Mallorca anyway though. A couple of views of Jason and Mike Carter at the bottom of the Hanwell thick taking two joeys for a job on the river. Johnny Dakin is on the hopper behind. Also coincidently we saw Silverlit at St Symphorien last week - Silverlit won the tug of war between the two at Brentford as I recall. Tam
    2 points
  25. I've got an inflatable mattress as a guest bed. They're all much of a muchness and really only suitable for the occasional night.
    2 points
  26. Today in 2006 on the Voges canal. Lots of duckweed about so pleased we’ve got keel cooling. The crew had a walk between the locks.
    2 points
  28. On this day 2016 Sunset cruise on the Witham On this day 2014 Sunset cruise to Torksey Lock On this day 2012 Newark
    2 points
  31. At over 10 amps draw, I bet the socket and plug will get hot and suffer a shortened life, quite apart from the effect that current draw would have on the batteries. I would suggest that you probably only have one domestic battery on a boat that size, so stick with the kettle on the gas.
    2 points
  33. It looked freshly dumped of you know what I mean!….had the same at norbury last year….one bin was full…bags were dumped on the ground yet loads of space in some of the other bins…I just put some gloves on and had it tidy in 5 mins. The reality is some people including boaters are scruffy arses that can’t be bothered and hope someone else sorts the mess out.
    2 points
  34. For hair?, I know you didnt have a lot up top, but Mrs Hound had a fine bob.
    2 points
  35. The fact that both sides are complaining about too much coverage of the other side's views suggests to me that the BBC is generally pitching things about right.
    2 points
  41. I suppose I shouldn't comment on this post but as the seller I have no idea what it is worth as it is a unique craft so I am starting with the insurance valuation. I am more concerned that it goes to a good home rather than ending up as a liveaboard in London so price is not critical. As far as the hull goes there is always the possibility of find a thin bit or bad rivet on a 90 year old boat but on the last survey all readings were 5-6mm bar one which was 4.4. As the hull and superstructure is all steel no water gets into the boat and any that would drains to a single point so internal corrosion is not a problem. After the last survey the boat was blasted, molten zinc sprayed and two packed by debdale; an expensive process but it really lasts. I know the engine is strange but to turn the original propeller it would have needed a heavy engine to give the right torque characteristics but as the engine had already been located under the stern deck this would have led to too much rear draft. The 4litre 6 cylinder engine is indirect combustion, high torque and with a heavy flywheel ticks over slowly and has proved totally reliable over twenty years. If anyone wanted to sacrifice some of the accommodation I am sure it would be great with something like a K2 in it.
    1 point
  42. I hate drinking tea out of a flask so we got one of those 12v kettles for use on long car journeys. You have to keep the engine running of course while it boils but it took so long for about 3/4 of a cup it only got used once. The other thing I can't do with is toast made under a grill - it's just not the same as done in an electric toaster. Does anyone here run an electric toaster off the inverter and/or has anyone tried one of those gadgets that toasts bread on the gas hob?
    1 point
  44. And that kettle can live on top of your stove when lit
    1 point
  45. They probably want to move out into the country and do not realise that they could cruise the boat to the countryside
    1 point
  46. The bins might have been full when the arse left it there. Biffa bods only empty the bins, they don't clear up the carp dumped in the bins area but not in the bins, do they?
    1 point
  47. So the walkers Bikers Better by waterist should have a toll booth to enter the tow path and pay their way like boaters who pay license and mooring fees
    1 point
  48. White Heather.. today...purring along.
    1 point
  49. Well at least they fixed my boat which is better than the two other firms I contacted that said they would help but never turned up. And a spare boat
    1 point
  50. Cheers Zen, after 2 days RCR turned up with the replacement gearbox, only to find out that it was the drive plate that was broken. Which was what I had suspected in the first place. So another 2 day passed and they fitted a new drive plate. All OK now elbows crossed.
    1 point
