Rebotco Posted May 22, 2014 Report Share Posted May 22, 2014 Just finished a cruise on the K&A and sharing an unexpected experience that could easily have become a disaster. Going down the Seend locks, no 17 I think, and sharing with a another narrowboat, about 45 footer. Gone down about 2 ft when both boats began to tilt into the centre. Although boating through hundreds of locks in past 4 yrs, this was a new development for us both! The lock was emptying fast and the tilt became greater, when I realised we were wedged together and slowly crushing each other as the roofs were almost touching. Fortunately my crew man doing the locking heard my yelling to drop the paddles immediately. As luck would have it, these were geared ground paddles that couldn't be instantly dropped in an emergency, and it seemed to take an age for them to both be wound down manually. By this time both boats were hanging in mid-air with the water about a foot below the bottom of the craft which were now on 15 to 20 degree angle. Equally slowly it seemed the top paddles were opened to try and refloat the boats. Eventually we were lifted sufficiently to stabilise and reverse the situation. We both had fenders down, although they were only the 2" pipe fenders, so we lifted them and very cautiously tried again. To everyone's relief this was successful. Fortunately no great harm was done, but it was a most salutary lesson not to take for granted the things you have been doing for years. I don't think any crockery was broken, and luckily neither had anything boiling on the cooker. Its also a good reason to ensure batteries are well strapped down. It has since occurred to me that the refloating may have had its dangers too. If the boats were wedged such that they were unable to rise as well, water could have begun to enter via the drain holes or engine vents on the lower side of the hull. But I don't want to think about that any more! I do wonder if that lock is maybe slightly tapered lower down - but in any event I shall not be leaving my fenders down whilst cruising again. It was only the quick action of experienced boaters that prevented a tragedy, and I do wonder what could happen to new boaters or hirers, who would have to loose valuable time trying to work what was happening and what to do about it. A slow or incorrect response could so easily become fatal. Link to comment Share on other sites More sharing options...
Timleech Posted May 22, 2014 Report Share Posted May 22, 2014 Locks generally are tapered towards the bottom Tim Link to comment Share on other sites More sharing options...
DeanS Posted May 22, 2014 Report Share Posted May 22, 2014 So glad there was no lasting damage. Well done for your quick thinking. Link to comment Share on other sites More sharing options...
Graham Davis Posted May 22, 2014 Report Share Posted May 22, 2014 So it wasn't the lock that was "lethal" but the way it was used. Link to comment Share on other sites More sharing options...
MtB Posted May 22, 2014 Report Share Posted May 22, 2014 So, hands up all those around here who still sees no problem locking with 'fenders down'... I have had an identical incident, prior to which I too saw no problem locking with fenders down. Changed my mind pretty damned quickly. MtB Link to comment Share on other sites More sharing options...
b0atman Posted May 22, 2014 Report Share Posted May 22, 2014 I think the rule fenders up must be given top importance . I shall sort mine out asap. A frightening lesson. Link to comment Share on other sites More sharing options...
Starcoaster Posted May 22, 2014 Report Share Posted May 22, 2014 Sounds pants-shittingly terrifying and I feel for you, but agree on the fender comments. Link to comment Share on other sites More sharing options...
the grinch Posted May 22, 2014 Report Share Posted May 22, 2014 the only place I would ever consider using a fender is on the Nene and only because of the stupidly installed chains at low level Link to comment Share on other sites More sharing options...
magpie patrick Posted May 22, 2014 Report Share Posted May 22, 2014 Rebotco, scary indeed - glad you were paying attention and got it sorted Also serves as a warning: all canals are subtly different and the K and A locks are a couple of inches narrower than say the Grand Union ones - it doesn't take much. No one is expected to know all the possible variants but being alert to the possibility that any new location is a potential hazard is wise. Link to comment Share on other sites More sharing options...
ditchcrawler Posted May 22, 2014 Report Share Posted May 22, 2014 the only place I would ever consider using a fender is on the Nene and only because of the stupidly installed chains at low level I didn't even use them there, but don't rope the boat tight against the side, I am happy for it to keep moving. Link to comment Share on other sites More sharing options...
the grinch Posted May 22, 2014 Report Share Posted May 22, 2014 I didn't even use them there, but don't rope the boat tight against the side, I am happy for it to keep moving. nothing wrong with that Brian its just the way I use them (single rope / forward gear) Link to comment Share on other sites More sharing options...
MHS Posted May 22, 2014 Report Share Posted May 22, 2014 Fortunately my crew man doing the locking heard my yelling to drop the paddles immediately. We have always told our crew, that if we sounded the horn, this would always indicate to drop all paddles asap. Haven't had to do it yet, and don't fancy having to. 1 Link to comment Share on other sites More sharing options...
Rebotco Posted May 22, 2014 Author Report Share Posted May 22, 2014 Locks generally are tapered towards the bottom Tim That does somewhat surprise me, as I've never heard that before. It does make some sense from an engineering point of view. Any idea of the source of that information? Link to comment Share on other sites More sharing options...
blackrose Posted May 22, 2014 Report Share Posted May 22, 2014 So, hands up all those around here who still sees no problem locking with 'fenders down'... I can't see any scenario where my widebeam would get stuck in a lock due to having the fenders down. Link to comment Share on other sites More sharing options...
GUMPY Posted May 22, 2014 Report Share Posted May 22, 2014 Sounds to me like operator malfunction! 4 pipe fenders at 2" each is 8" or being generous 3 as the middle ones will overlap, that's 6" wider than the two boats need to be and you are surprised? K&A is somewhere I would definitely refuse to share locks with someone if they had fenders down. Hopefully you will learn from this experience and lift your fenders when not moored. Link to comment Share on other sites More sharing options...
MtB Posted May 22, 2014 Report Share Posted May 22, 2014 I can't see any scenario where my widebeam would get stuck in a lock due to having the fenders down. Very blackrose-centric POV. MtB Link to comment Share on other sites More sharing options...
John V Posted May 22, 2014 Report Share Posted May 22, 2014 I can't see any scenario where my widebeam would get stuck in a lock due to having the fenders down. Love it !!! Link to comment Share on other sites More sharing options...
David Schweizer Posted May 22, 2014 Report Share Posted May 22, 2014 (edited) I had a similar experience on the Caen Hill flight many years ago when the boat i was locking down with had pipe fenders, we wedged solid in one lock and it took half an hour to un-jam us, Our boat is 7ft wide and since then, not wishing to repeat the experience, I always ask other boats to lift their fenders before entering the lock, explaining the problem. If they refused, I would refuse to lock through with them. So far we have not had a problem. Edited May 22, 2014 by David Schweizer Link to comment Share on other sites More sharing options...
junior Posted May 22, 2014 Report Share Posted May 22, 2014 I thought fenders were only supposed to be used for mooring? Link to comment Share on other sites More sharing options...
ditchcrawler Posted May 22, 2014 Report Share Posted May 22, 2014 We have always told our crew, that if we sounded the horn, this would always indicate to drop all paddles asap. Haven't had to do it yet, and don't fancy having to. That is what bothers me with engine off in locks, no horn I had a similar experience on the Caen Hill flight many years ago when the boat i was locking down with had pipe fenders, we wedged solid in one lock and it took half an hour to un-jam us, Our boat is 7ft wide and since then, not wishing to repeat the experience, I always ask other boats to lift their fenders before entering the lock, explaining the problem. If they refused, I would refuse to lock through with them. So far we have not had a problem. There is a notice on that lock now telling you to enter singly I think its 38 or 39 Link to comment Share on other sites More sharing options...
MtB Posted May 22, 2014 Report Share Posted May 22, 2014 I thought fenders were only supposed to be used for mooring? They are, but plenty of peeps on here say otherwise as they have yet to get hung up in a lock. MtB Link to comment Share on other sites More sharing options...
n.b.Goldie Posted May 22, 2014 Report Share Posted May 22, 2014 They are, but plenty of peeps on here say otherwise as they have yet to get hung up in a lock. MtB They do say otherwise but fail to explain how they help or what purpose they serve whilst underway. Anyone care to explain? Link to comment Share on other sites More sharing options...
MtB Posted May 22, 2014 Report Share Posted May 22, 2014 They do say otherwise but fail to explain how they help or what purpose they serve whilst underway. Anyone care to explain? Julynian (IIRC) says he likes the way they trail in the water..... (Somebody shoot me, now!) MtB Link to comment Share on other sites More sharing options...
billS Posted May 22, 2014 Report Share Posted May 22, 2014 (edited) Well, in Blackrose's case, what purpose is served by taking them up? Edited May 22, 2014 by billS Link to comment Share on other sites More sharing options...
Athy Posted May 22, 2014 Report Share Posted May 22, 2014 That does somewhat surprise me, as I've never heard that before. It does make some sense from an engineering point of view. Any idea of the source of that information? Observation. Link to comment Share on other sites More sharing options...
