matty40s Posted May 8, 2014 Report Share Posted May 8, 2014 (edited) On a boat today where there us a very strong ammonia smell in the kitchen, especially round the fridge?? Doesn't appear to be any spilt chemicals. Loo smells of blue only. Any ideas?? Fridge is an old Electrolux rm 212 3-way.no smell inside, but very strong from rear. Edited May 8, 2014 by matty40s Link to comment Share on other sites More sharing options...
magnetman Posted May 8, 2014 Report Share Posted May 8, 2014 Garlic? Link to comment Share on other sites More sharing options...
furnessvale Posted May 8, 2014 Report Share Posted May 8, 2014 On a boat today where there us a very strong ammonia smell in the kitchen, especially round the fridge?? Doesn't appear to be any spilt chemicals. Loo smells of blue only. Any ideas?? Isn't ammonia the active ingredient in fridge cooling systems? You won't see any liquid spill as the ammonia evaporates, hence the smell. George ex nb Alton retired Link to comment Share on other sites More sharing options...
RLWP Posted May 8, 2014 Report Share Posted May 8, 2014 How old is your fridge? Some of them used to use an ammonia based working fluid Richard Link to comment Share on other sites More sharing options...
Tony Brooks Posted May 8, 2014 Report Share Posted May 8, 2014 I strongly suspect that one does so I think a leaking fridge. Don't know if its a new fridge time or if you can still get new units to fit to your cabinet. Link to comment Share on other sites More sharing options...
matty40s Posted May 8, 2014 Author Report Share Posted May 8, 2014 Thanks gents for swift conclusion that I suspected, fridge out!! Link to comment Share on other sites More sharing options...
Beaker Posted May 8, 2014 Report Share Posted May 8, 2014 If it's leaking enough to smell it, I would imagine your fridge to have packed up totally by now. Link to comment Share on other sites More sharing options...
Ally Posted May 8, 2014 Report Share Posted May 8, 2014 Our fridge smelt of antiseptic when it dumped it's coolant...nothing to see, it presumably gassed away. It was a new one, so probably a different chemical. Link to comment Share on other sites More sharing options...
Neil2 Posted May 8, 2014 Report Share Posted May 8, 2014 Do you have a cat litter tray? Link to comment Share on other sites More sharing options...
bizzard Posted May 8, 2014 Report Share Posted May 8, 2014 Could have been a tomcat marking his patch. Link to comment Share on other sites More sharing options...
cereal tiller Posted May 8, 2014 Report Share Posted May 8, 2014 Could have been a tomcat marking his patch. Does the boat have a Bird in a "Gilded Cage"? CT Link to comment Share on other sites More sharing options...
Grace and Favour Posted May 8, 2014 Report Share Posted May 8, 2014 Can we be sure it wasn't Matty 'marking his territory' during the night? Sleep "walking"?? Link to comment Share on other sites More sharing options...
bizzard Posted May 8, 2014 Report Share Posted May 8, 2014 Tomcats can get quite affectionate towards fridges being at a convenient height so its not wise to name a tomcat Electrolux. Link to comment Share on other sites More sharing options...
Proper Job Posted May 8, 2014 Report Share Posted May 8, 2014 If your fridge is 12v rather than a cheapo 240v job, it may be cost effective to get the coil repaired and the system re-gassed Link to comment Share on other sites More sharing options...
bottle Posted May 8, 2014 Report Share Posted May 8, 2014 Good point PJ but from first post, Fridge is an old Electrolux rm 212 3-way.no smell inside, Link to comment Share on other sites More sharing options...
BargeeSpud Posted May 8, 2014 Report Share Posted May 8, 2014 From left field, but it might be an idea to check & clean up the electrical contacts at the junction where the fridge is wired into the electrical system or where the wires connect to the fridge itself. I know it sounds odd, but in the past I've had duff sockets in the house that have smelt of fish because of crap connections, so maybe this could be something similar? Link to comment Share on other sites More sharing options...
Chalky Posted May 8, 2014 Report Share Posted May 8, 2014 I know it sounds odd, but in the past I've had duff sockets in the house that have smelt of fish because of crap connections, so maybe this could be something similar? I'd second that. We had a strange fish smell in the bathroom at home that we couldn't trace until the shower packed up. The smell was the shower isolator switch overheating due to a poor connection. Link to comment Share on other sites More sharing options...
Tony Brooks Posted May 8, 2014 Report Share Posted May 8, 2014 Look, the OP says its a 3 way Electrolux. Those are absorption fridges and as far as I am aware ALL absorption fridges use ammonia as their refrigerant. By far the most likely fault is a leak from the unit at the back and as I said new/exchange units may be available. I am not sure they can be recharged by a fridge engineer although I am sure one of our members who knows about such things will soon confirm or deny that. Link to comment Share on other sites More sharing options...
Stormbringer Posted May 8, 2014 Report Share Posted May 8, 2014 (edited) As TB and others have correctly stated already, the smell of ammonia is the primary symptom of an absorption fridge leaking it's coolant. Once the fridge is out there may be a slight amount of yellow staining if the leak is in a visible place, but not always. I'd be surprised if you can get a replacement cooling unit and they are not rechargeable or repairable unfortunately. If you are particularly attached to your 3 way, you might find a replacement on eBay, or via a caravan breaker. Cheers Andy..(caravan engineer) Edited May 8, 2014 by Stormbringer Link to comment Share on other sites More sharing options...
Graham Davis Posted May 8, 2014 Report Share Posted May 8, 2014 If you need one from a caravan breakers I can heartily recommend Blaenavon Caravan Breakers (http://www.caravanbreakers.net/) as I have recently needed to use them for some bits, and they are very reasonable. They also have spare toilet cassettes! Link to comment Share on other sites More sharing options...
tommytelford Posted May 8, 2014 Report Share Posted May 8, 2014 If it is an ammonia leak I would advise removing the offending item as soon as possible as it is dangerous to breath it in and it is also very corrosive to metal surfaces. The general rule is that if you can smell it it is already at a dangerous level Link to comment Share on other sites More sharing options...
ditchcrawler Posted May 8, 2014 Report Share Posted May 8, 2014 If it is an ammonia leak I would advise removing the offending item as soon as possible as it is dangerous to breath it in and it is also very corrosive to metal surfaces. The general rule is that if you can smell it it is already at a dangerous level Its not quite that bad. I use to work for Birds Eye Foods and that was the refrigerant that we used in the cold stores. The compressor houses reeked of it and my eyes would stream walking by the door sometimes. As for corrosive you are dead right, we use to have a real problem pulling drive flanges off the shafts of electric motors as the ammonia would creep between the flange and shaft. Link to comment Share on other sites More sharing options...
Hawkmoth Posted May 8, 2014 Report Share Posted May 8, 2014 Its not quite that bad. I reckon it is. I've also worked on ammonia plant. It's nasty stuff, and it's explosive in the wrong ratio. That's why ammonia fridge plant rooms have auto detection and and shut down of all electric sevices. Bob Link to comment Share on other sites More sharing options...
matty40s Posted May 8, 2014 Author Report Share Posted May 8, 2014 fridge is out of the boat everyone thanks. now looking for replacement at a decent cost. Link to comment Share on other sites More sharing options...
ditchcrawler Posted May 8, 2014 Report Share Posted May 8, 2014 I reckon it is. I've also worked on ammonia plant. It's nasty stuff, and it's explosive in the wrong ratio. That's why ammonia fridge plant rooms have auto detection and and shut down of all electric sevices. Bob The Lower explosive limit is 15% that is higher than carbon monoxide and requires a very high energy source to ignite it, I don't think you would want to be anywhere near the place at that concentration . Link to comment Share on other sites More sharing options...
