Poorly engine
Dottyshirl
OMG travelled from
Sileby on the GU onto the Trent n Mersey ... Suddenly loads of smoke.. Shut the baby off and hope she is ok, waiting for our mechanic to say we can carry on. Loved our two day excursion lol
Edited by Dottyshirl
Also to the uninitiated what you may be describing as "smoke" might be steam, (depending on where it is coming from).
If, for example, water in an engine header tank gets too low, then the combination of the resulting steam, often involving rubber hoses that have a coating of oil on, may look like "smoke".
Don't panic at this stage - often what looks horrendous at the time may have done no lasting harm at all.
Ok, we seem to be losing oil from the engine, no mechanic yet but checking everything you advised, we did an oil check, it was fine when we set off, only two days cruising and hardly any oil on the stick. Hope there is a solution besides replacing the engine..... The guy we bought it from said he had the engine cover on the roof and it was stolen ..... Maybe he had no cover as the engine overheated because it had an oil leak ? (No we did not have a survey ! ) love being on the water apart from being forced aground by some lovely guy who never made eye contact but knew exactly what he was doing to me, we were sharing locks with a gentleman who pulled us back on the water so we were ok lol ...
I see. He 'forced you aground' did he? Not your inexperience putting you in a place to run aground then
Richard
Did he hit you then?
You say engine cover, what engine is it?
We've all ended up on parts of the cut where the bottom is too close to the top at some stage of our boating careers, and it does happen more often when you first start out. WIth a few dozens of miles under your belt it becomes second nature to 'keep it on the wet bit' regardless!
On the engine difficulties, I'd go along with previous posters who suggested the lack of a rocker cover might be the cause of oil loss. Whether somebody just pinched it because they could, or there is some underlying problem, can't be analysed remotely. I wouldn't have thought taking the cover off to cure overheating was an obvious thing to do: lack of coolant is the usual problem, and if there's plenty of that, a blockage in the system or an escape of water would be early suspects.
Since you stopped the engine yourself, rather than it grinding to a halt, the chances are far better that it's not terminal. Hope it works out.
Edited by Machpoint005
Did he hit you then
No but being a lady I did not drive into him and he left me no room ! Bless him. The engine us a Barrus. When I say no engine cover I do not mean an engine part, it is the cover over the engine. Listen.... I am sorry if my ignorance is misleading you, I am trying my best x
Richard
I may be a novice but I am not an idiot, I know what he did, had I kept a safe course we would gave collided as he kept to the centre of the waterway.... Enough energy spent on you lol
Thanks you positive people xxxx
Good luck Dottyshirl,
I only been a boater for a few months and it sure as hell takes a lot of getting used to. I've been aground several times, panicked when seeing boats heading towards me while zig zagging along the cut and had a fair share of engine problems too. Still love it though, every day is a school day.
Please forgive Richard, he's suffering a bit at the moment. Normal friendly service will return soon I'm sure.
Rob
Well said. A shame when people assume newcomers are in some way stupid. Some of the most stupid boaters we have come across have "been doing it for years, you know!"
Good luck with the donkey, hopefully just be a blocked breather, oil filter or similar.
What colour was the smoke, There are three possibilities :- black, blue/grey, or white, and they all mean something different.Was the engine already smoking a bit before the "lots of smoke" occurrence? especially after longish periods of slow running
I have my views of what it might be, particuoarly as it was accompanied by loss of oil, based upon a similar experience with the engine in our boat. I do not want to be pessimistic but it could be worn bores or rings, which will not cause any noise (well not any that is discernable on a noisy diesel) but will produce enormous amounts of blue/grey smoke.
If it is bores or rings , you will not be stranded and will be able to continue your journey with care, but you will not be very popular with the boats you pass (again personal experience)
Edited by David Schweizer
Bizzard's suggestionn prompts another question. Was the smoke coming from the exhaust> or from the engine itself, in whch case any particular place? or was it coming from both?
OK three questions but the answer could be relevant to possible diagnosis
