21 minutes ago, Derek R. said:
Indeed. 20hp is quite adequate for most canals and rivers, even for 70ft boats.
Gardner 4LK engines are selling for between £4,000 and £14,000, and second hand BUKH DV20's can be had for less than £2,000.
I was thinking of a dv36, as rivers can be a bit excitable
You planning on shooting some rapids? We've done the tidal Trent with 20hp in a 62ft boat and kept up with others of the same length with 36hp. They were giving it all they had too. A lot depends on prop size matched to engine torque and rpm, along with hull shapes and length x breadth ratios. Never done rivers in flood though, something to steer clear of.
Fmc beech, been for sale for a very long time, needs 3/4 - 2/3 of bottoms replacing,
It's not had any major work sence ken ward died.
Was at 15k then 22k then slowly coming back down.
I offered 5-8 4 months before buying towy
14 minutes ago, billybobbooth said:
I ment to play with and have in a boat
It doesn't appear to have a reversing gear.
Getting a two stroke hot bulb twin engine to run backwards to stop the boat must be a right palava, if possible at all.
Edited by Mike the Boilerman
Add a bit
37 minutes ago, Tim Lewis said:
So if it's a hard conversion with cloths over the posh bit I can think of at least three bits of permanent infrastructure it'll struggle to get under.
Edited by zenataomm
No natural light in the attic
23 hours ago, Mike the Boilerman said:
Gearboxes are for wusses....
. . . and those who don't like running into things ?.
  • 3 weeks later...
A full length Josher for "offers in excess of £10,000"???
What on earth is going on here then???
Malvern
Quote
A detailed Hull survey is available for inspection and must be read
before any offer can be made.
But it also says last survey (and blacking!) is 2014....
Malvern
It may be resting on bricks on the bottom of the canal!?
