CompairHolman
Towpath bike punctures
Any one have the same problems we have , when the spring and summer comes and the towpath hedges get cut the path is littered with thorns and basically un-ride-able ?
I just went out and only got 100 metres on the towpath before it was game over for both tyres.
The contractors sometimes blow the path clear, but you can never be sure.
Share this post
A friend of mine who was a regular off road cyclist recommended leaving the thorns in the tyre and riding till past the area of cut hedge, then fixing the puncture, on the principle that fixing a puncture in the midst of the cause of the puncture was asking for trouble.
Share this post
 There are puncture proof ,  and solid tyres [special rims]
Best t carry a brand new spare , check inside tyre for thorns,
Edited by LadyG
Share this post
I use the liquid-rubber (foam) tyre sealant. About £8-£10 for a can big enough to fix a 19" 4WD car tyre.
I drove with it in my motorcycle tyres for several years and despite having several nails & screws in the tyre I never got another puncture.
It will just continue to self-seal if anything penetrates the tyre / tube.
Edit to add :
Aldi had it in a couple of weeks ago as one of their 'specials' £4,99 / can and plenty big enough for 2 bicycle tyres (with loads to spare)
https://www.aldi.co.uk/holts-tyreweld/p/087615239707000?gclid=CjwKCAiAqaTjBRAdEiwAOdx9xnBSqAuE29qd9Ng3umTlcLoBqDbpgxLuGGuQctIESgZU5J04l2wokxoClJ8QAvD_BwE&gclsrc=aw.ds
Holts Tyreweld
Edited by Alan de Enfield
Share this post
I'm on the hunt for some slightly less precious inner tubes for my road bike. I thought I'd try the kevlar types but they have awfully mixed reviews; I was having a look the other day and found this tape, now I haven't used it or even looked that hard at but it looks ok and seems to review not too bad.
https://www.evanscycles.com/panaracer-flataway-tyre-protection-tape-EV154733
Share this post
Get some " Green " slime innertubes. Work well.
Share this post
6 minutes ago, Tumshie said:
And there is this stuff but I think this might be what Alan has already mentioned.
https://www.evanscycles.com/zefal-sealant-spray-00104698
Looks like the same stuff but obviously at an outrageous price (comparing the can size) as all cyclists are very rich and live down South !!!
(The Aldi can is 500ml, the 'cycles' can is 100ml)
Share this post
I suspect anything Evens have to offer is worth a punt as they have an excellent pedigree in the cycling world, I remember using them about 60 years ago.
Phil
Share this post
The Aldi can is obviously better value and probbly a good thing to keep in the shed, I like Aldi and lidl stuff, I find it quite good quality usually. The advantage with a 100ml size is that it can be tucked away in a pouch for an emergency, 500ml can be a bit bulky to accommodate on your bike.
Would you suggest using it before you got a puncture as a preventative measure ?
Share this post
That's what I did, and once in the tyre protected me from Punctures for 'years'.
My father was getting punctures in his buggy as an almost daily occurrence, filled his tyres with 'snot' and he has not had a single 'flat' for over a year.
Share this post
Right - will give that a go and see how we get on.
Thanks Alan 😃
Share this post
Thanks Alan 😃
Squirt it in and ride for 5 miles to ensure the 'snot' is properly dispersed around the inside of the tyre, it will also leave a 'puddle' which is always at the bottom of the tyre so when a thorn enters it will be into the puddle, (obviously any puncture is going to happen at the 'bottom' of the wheel) and the 'snot' then seals around it, leaving the rest of the puddle to continue sloshing around until the next thorn enters ……………………………….
Share this post
Edit to add :
Holts Tyreweld
I confidently bought a tin of this for my wheelbarrow wheel, it turned out the tyre didn't exactly have A puncture, more the tyre had committed hara kiri,  it was almost osmotic in the way it oozed out
Share this post
works ok on my bikes.
I had the same problem with a wheelbarrow tyre, had to throw it out of the kitchen door, tried again outside, same thing happened, tyre and wheel still outside the kitchen door
Share this post
7 hours ago, Chris G said:
Schwalbe Marathon tyres?
Another vote for schwable marathon plus......I have done 1500 puncture free miles on mine. They are a bit heavier than a standard tyre and a bit tight to fit but well worth it.
Share this post
For mountain bike
1 Zefal puncture resistant tape, goes between tyre and inner tube
2 Kenda puncture resistant tyre K847 with K Shield. I use the semi slick tyre but full knobbly tread is also available.
3 For belts and braces I also use puncture resistant inner tubes.
Rarely get a puncture although thorns can occasionally get in through the side wall, this can be mitigated by using high tyre pressures.
For Road bike 700c
1 Continental puncture resistant hybrid tyres 700c, various types available to suit your requirements. I use hybrid tyres but full road tyres are also available.
2 As above Zefal puncture resistant tape.
For 20 inch folding shopping bike
1 Schwalbe Marathon Plus (superb little tyre only downside is that tread is not best suited to muddy towpath conditions)
2 For belts and braces approach I again use the Zefal puncture resistant tape.
Even with all of the above I still get the occasional thorn inflicted puncture.
As mentioned above I find high tyre pressures help reduce punctures.
Eta
For the road bike I chose continentals because of a greater choice of tread pattern for their puncture resistant tyres when compared to the Schwalbe marathon plus, however if you are happy with the Schwalbe tread pattern then I would pick the Schwalbe over the Continentals.
Whatever you choose I would say that you can only ever going to increase the puncture resistance and cannot ever make the tyres puncture proof (solid tyres are another discussion and not one I would join in)
Edited by reg
Share this post
41 minutes ago, Señor Chris said:
If you want completely bomb proof, get the Marathon Plus.
I like this idea, not my thread but thanks the recommendation.
Share this post
2 minutes ago, reg said:
For mountain bike
For Road bike 700c
I've just been looking at some of these suggestions and realise how woefully inadequate my tyres are so I'm going to up grade mine.
I didn't start this thread but the advice has been really helpful, thanks.
Share this post
I have continental gatorskin tyres on my bike. They are pretty good. I think I have had one puncture in 3 years,probably 1000 road miles.
Share this post
Another thing that I have considered trying are the
GAADI two ended inner tubes, these can be removed without removing the wheel, particularly useful for electric bikes.
They are expensive though at circa £11 each but may be worthwhile if fitted  justto a wheel with a built in electric motor, saves all the hastle of disconnecting cabling and, usually, associated cable ties.
Share this post
Phil
Whilst agreeing about the quality of Evans stuff, aren't they the company that went into administration and were bought up by Mike Ashley of Sports Direct?
Share this post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
