Leaderboard
Popular Content
Showing content with the highest reputation on 29/06/24 in all areas
  5. Just Giving page in memory of John
    4 points
  9. https://www.justgiving.com/page/john-sloan-1719664855235?utm_medium=fundraising&utm_content=page%2Fjohn-sloan-1719664855235&utm_source=copyLink&utm_campaign=pfp-share
    3 points
  12. The boat Jack was a horse boat. The running line went from the T stud through running blocks and the mast to the horse. The running line was released slowly when the horse started the tow so to ease the strain of starting from stationary. The T stud was removable. Another picture.
    2 points
  14. Today I had a serious professional welder fill in the deepest pits on the old girl, I brought a boat surveyor to tell me would it be plausible and he said it would. Actually there was not many 2mm deep, but we did them all, I'm not grinding the weld off (he did long runs over 3 or 4 at a time) overplating would have cost a small fortune, so this may help others with pitting, this old girl was built in 1979, so not bad considering.
    2 points
  15. most are mature age people who choose to have an old boat for a range of reasons. Frequently because thats what they have done for 30 plus years, and have no desire for a modern boat. They do not carry , do not play at carrying, are careful with their boats, and act in a fashion not dissimilar to the owners of other craft. Personally I do not own a waistcoat a bowler hat nor a red neckerchief, and I did not wear such items even when I was making a living on the boats.
    2 points
  17. People don't swim in the Thames anymore, they just go through the motions.
    2 points
  22. So, last six months I've been suffering, stiffening up. Anyone over the age of 65 who has just done eight locks on the Calder and Hebble will be lucky to walk away without some muscular strain.... So, booked a Thai massage in Sowerby (therapist has good understanding of English), mostly relaxing, mostly. Immediate results, taken five years off the body stiffness. I'll be booking in again. There is a chiropractor next door if you need manipulation:)
    2 points
  25. A few things which can confuse matters. In some languages the same word is used for brass and bronze. This means it does not always translate back properly to English. There are several copper alloys colloquially known as bronzes. Bronze should really only be used for a copper tin alloy. Tin is very close to copper electrochemically, so whilst it could come out preferentially to the copper, the rate at which it did so would be very slow. It works more by forming a continuous hard oxide coating across the surface which means the metal is protected from environmental attack. Aluminium and silicon do the same but are more sacrificial. Zinc is highly sacrificial because although it is not quite as reactive as aluminium, the oxide it forms is not very protective so it keeps dissolving. If you add tin to the zinc and copper, it forms a tin oxide skin over the surface which is highly protective, giving a cheaper, stronger alloy than ordinary bronze. This is naval brass (sometimes known as naval bronze) which if alloyed properly is very good in marine environments, being what it was specifically developed for in the 1930s. Alec
    2 points
  29. DZR is usually what you want for underwater fittings. Is the size not cast or stamped on the boss somewhere? Where is the FMM 595 mark?
    2 points
  30. Surely bronze contains no zinc, only tin, unless it is so-called aluminium bronze. Brass is the stuff that loses zinc.
    2 points
  31. There are online prop calculators that will make a stab of what you want. You will need waterline length, hull type (displacement or planing), engine power and max RPM, gearbox reduction and the largest diameter the prop can be allowing for sufficient tip clearance, but I feel the results need treating as a guide rater than gospel and experience is always helpful. Just Google "marine propeller calculator" and play with a few.
    2 points
  33. After many years researching canal history, I have come across very few deaths or serious injuries mentioned, either in canal records or in newspapers. I suspect the standard of training was higher 100 to 200+ years ago, and management that had actual experience of what they were managing.
    2 points
  36. Outside the Greyhound in 1968:-
    2 points
  38. 50yrs, well before my age for drinking. That’s back in another century. what I will do is go this evening and see if it still tastes the same as it did the other day. Can’t say fairer than that.
    1 point
  39. I've recently bought a sailboat and learning. Some of the seacocks are frozen. Can't really justify the cost of going down the bronze route. Trudesign make a plastic assembly, more in the right cost ballpark and not noted for being crap.
    1 point
  40. I think that is where aluminium bronze comes in because it is cheaper. Copper and aluminium, probably plus other metals. More resistant to corrosion than brass, but as aluminium is still used as anodes, it will still corrode, but more slowly than zinc. I am sure it is sued in props and the aluminium part is conveniently left of the documentation. I don't think it would cause a problem for most inland craft.
    1 point
  41. I'd not be expecting anyone to identify a number, what I mean is I would hope he is interested enough to help identify your needs, and suggest a product.
    1 point
  42. I'm pretty certain T. Norris are no longer there. But prop specifying is as much an art as a science in my experience. One has to balance several competing and conflicting aspects of performance so yes a prop calculator is a good start but don't expect ANY new prop to feel exactly the same as the old one in every respect.
    1 point
  43. The Victoria Propeller Calculator at vicprop.com is fairly simple to use and is I believe the one which has previously been discussed on here. One thing to bear in mind is your engine size vs boat size and where you use it. The calculator generally assumes you want the best transmitted power but if you have a relatively shallow boat with an efficient hull design and a relatively large engine you can easily lose the ability to go slow enough on a canal so some derating is needed. I agree with Bee that this is where knowledge is needed. I also agree that dezincification would be surprising as most props are made of bronze, which is a copper tin alloy or naval brass which is copper tin zinc where there is enough tin in the alloy to be protective. A zinc copper brass would be possible, but not generally used as it would be vulnerable to corrosion. Alec
    1 point
  47. I had the same with a marina I was with so I left the marina. Their "Engineer" total rubbish. A good restaurant will allow you to bring your own wine, but expect to pay "corkage".
    1 point
  48. If they are going to allow other tradesmen to work in their marina they are entitled to take reasonable steps to ensure that the tradesman is insured and not a risk to the marina itself or to the other boats moored there and is not going to cause undue disturbance to marina staff, other moorers or neighbours. It follows that they can make a reasonable charge for verifying the tradesman's status. Whether £50 per day is a reasonable charge in the circumstances is a matter that could ultimately only be determined by a court. The easy answer, as suggested above, is to have the work done outside the marina.
    1 point
  49. This post cannot be displayed because it is in a forum which requires at least 10 posts to view.
