Just seen this on Facebook.
https://www.facebook.com/groups/73933281285/permalink/10156542111901286/
CANAL & RIVER TRUST TO TACKLE ‘IMPROPER’ MOORING AND MAKE WATERWAYS SAFER
The Canal & River Trust is reaching out to boaters who have moored their boats in a way that could be dangerous or cause problems for other boaters or waterway users.
The charity regularly receives feedback from boaters about craft that are poorly moored, blocking facilities, or making it unsafe for boats to navigate. The Trust is addressing the problem by promoting more considerate mooring and shared use of the waterways, letting those who are moored inappropriately know there is a problem, and ultimately acting against persistent rule-breakers.
Matthew Symonds, national boating manager at Canal & River Trust, said: “While the vast majority of boaters are considerate neighbours, every boater has a story to tell of a badly, or simply dangerously, moored boat. Whether it’s someone moored up for days on a water point, to boats blocking the sightlines on bends, there are many examples of poor mooring etiquette. This can at best be frustrating and, in some instances, can be dangerous for the moorers and others.
“So we're going to be stepping up our efforts to contact all boats that we see moored inappropriately. Much of the time a boater may not realise that the way they’re moored may be causing a problem, and we think a polite reminder of good mooring practise will result in them moving somewhere safer, or where they won’t be affecting others.
“Being by the water makes you healthier and happy and we want everyone to be able to enjoy the waterways safely”
From Monday 10 February 2020, the new “Improper Mooring” process will be applied where a boat is moored in a way that affects safety or impedes other boaters or waterway users. It will be recorded by the Trust’s Licence Support Team and, initially, a letter will be sent to the boat owner highlighting the problem. The boater will also receive a booklet including extracts from the Trust’s boat licence terms & conditions, bye-laws, the Navigation Rules, and Boaters’ Handbook to help them understand how they can moor more appropriately.
The Trust intends the process to serve as a prompt for the boat owner to moor appropriately and to help and educate boaters that may be new to the water or unaware of the issues caused by poor mooring.
If a boater does not address their inappropriate mooring the process will allow the Trust to take action that could ultimately result in the revocation of the boater’s licence.
If, after the first letter, there are further instances of poor mooring, then the Trust will send a formal reminder which clearly sets out how T&Cs and/or byelaws have been breached, and that this could result in the termination of their licence. Should there be no resolution or a repeat of the behaviour, a second reminder will be sent, detailing the circumstances, the action the boater needs to take, and issuing a final warning. A final letter will be sent if the problem is not addressed, or if it is repeated, informing the boater of their licence being immediately suspended.
In these circumstances, the boater will be directed to remove their boat to a specific location where it must remain until investigation into the mooring conduct is concluded and they have been contacted with the outcome, which could be licence termination due to serious or persistent breach of the Trust’s terms and conditions.
The process is aimed at preventing persistent poor behaviour or serious instances and as such will focus on more acute issues. Rare or singular historic instances will be considered but the Trust hopes that the initial informative letter will help address these instances.
The Trust has identified the following examples of improper mooring, which are found in the Boaters’ Handbook, navigation rules and relevant byelaws. It is not an exhaustive list and the local environment will always be taken into account:
Mooring in a lock, lock approach, or in a lock flight; blocking services that the boater is not using; mooring near a bridge or under a fixed bridge where inappropriate; mooring near a weir; mooring near a sharp bend, on the outside of a bend, or by a blind spot; mooring in or opposite a turning point/winding hole or on the approach to it; mooring at a junction; mooring to the bank on a tidal river; mooring on a canoe landing place; mooring in a stretch marked for an angling match; mooring where there are signs that prohibit mooring.
Not a bad idea. Been a boat on the water point here in Kintbury all week! Although someone already suggested enforcement are unlikely to do anything as they are already overstretched dealing with unlicensed boats and boats not moving enough etc...
paging @matty40s ...
A bit early for April Fools day
So they are now suggesting they control mooring on Tidal Rivers, I think they are going a bit above their authority.
Actually implementing the ByeLaws - really !!!!!
Edited by Alan de Enfield
I suspect it is just going to encourage an increase in boaters/the public sending photos and complaints of boats they don't like in to CRT. Doubt CRT are increasing staff on the ground in any meaningful way...
I'm curious about this 'specific location' naughty boats must be removed to by their owners...how would that even work. Presumably there will be more than 1 location around the system??
Proposal "Any wide boats causing problems on the K&A must move their boats to Carlisle"
Do you want to bet there won't be many of those "specific locations" in London or on the western K&A ...
 Great minds ...
Give 'em a shovel and get them to dig out to Kendal at least ...
Add -
also wide boats mooring on a canal which is really not broad...
If it stops plonkers mooring on lock landings and on water point whilst doing their " washing " or washing their poxy boat I am all for it!!
Dont get me started on short boats that moor near a winding hole that are clueless as to how much a complete boat needs to manouvre!!
Why do you say that? There are some tidal stretches of rivers that come under CRT jurisdiction.
Should be pointed out that workboats and maintenance boats are specifically excluded from the requirement :
Vessels to be
properly moored
28. Any vessel (other than a dredger or other vessel engaged in
works of maintenance of the canal) moored at any wharf or
elsewhere in any canal shall be securely moored head and stern
with good and sufficient ropes or other efficient apparatus and
shall be laid as close to and along the side or front of such wharf
or other mooring place as conveniently may be and shall be
moored in such a manner and in such a position as not to cause
any obstruction to the navigation of other vessels.
ETA I suppose if the maintenance boat is moored and unused it doesn't really qualify for the exemption being fair.
Edited by magnetman
marked how exactly?  and how am I supposed to recognise that the match is imminent and not in two weeks time?
I hope it will improve things in a few cases. Last time I complained about a boat being permanently moored opposite a winding hole, such that I was unable to turn my 67ft boat there, CRT's response was to put up a sign restricting the max length of boats using the hole to 65ft. The continuous moorer was still there 12 months later.
  • Sad 1
C&RT have no control over mooring on rivers, the Landowners on each side will (normally) have the riparian rights to the centre of the River, C&RT are responsible for the MNC. (Main Navigable Channel)
The EA can have input into moorings on Rivers (even C&RT Rivers) if the moorings would affect flow, flooding etc etc.
Probably all those fishists sitting on their boxes :D
For the big organised competitions they stick notices up every few hundred yards tied to trees/ fences etc about a week before the match, with the date on the signs.
Will the converse apply to angling in a stretch marked for mooring ?
Vessels to be
properly moored
I would read that as only excepting such boats while they are actually "engaged in works of maintenence".
Mooring a workboat in a lock while fixing the lock is fine.  Leaving the same boat tied up on the waterpoint or the swingbridge landing for 3 months when not doing work there is not.
You know it wont - C&RT have already put out notices that 5 metres should be left between moored boats to allow Maggot-drowners to get between the boats
Not strictly true for a variey of reasons
1 - CRT terms and conditions apply on rivers - e.g a mooring where the boat may lawfully be kept OR engaged in bona fide navigation
2 - A boat can still be an obstruction to navigation on a river
3 - CRT own moorings on rivers (e.g Avon Street in Bath)
With regards to tidal waters, in Gainsborough CRT own pontoon moorings that are actually on the ABP bit!
Edited by magpie patrick
I suggest they start in London. How many boats are moored on the outside of a bend? I guess at least a couple of hundred all the time and often double banked.
River Brent at Brentford is tidal above the lock and Cart control the moorings there, at least on the towpath side.
so there is at least one place
... for winter moorings where the boats can realistically be expected to stay put for 4 months ...
I don't see the relevance of that in C&RT saying they can make people mooring on a River move their boat.
I understand that that is not a C&RT responsibility to monitor, but is an EA responsibility.
I know that C&RT do own moorings on Rivers but I do not see how they can claim they control "mooring to the bank on a tidal river"
On the Trent (for example) there are a number of 'Farmers' moorings, when I enquired about putting in a mooring I was told it required EA approval.
If it's obstructing navigation it's the navigation authority's problem
