Leaderboard
Popular Content
Showing content with the highest reputation on 18/09/23 in all areas
  1. What actually seems to annoy you is that people dare to give their opinon on the subject matter at hand rather than a direct answer to the specific question you asked. I suspect that's a function of the way your brain works. Unfortunately for you the rest of the forum membership doesn't work the way you want it to. You assume that's their fault and respond by showing your frustration far too readily and with a posting style that I think grates with many members. What I think most contributors to this thread will have experienced is that you asked for advice on fenders, they gave you plenty, and then had it rudely thrown back at them. Largely because they didn't take the initial question in as literal a sense as you intended. No one here will be bothered if you choose a long button rather than a tipcat. But they will have noticed how you've used negative descriptions of other people's boats in the course of the thread as a means of justifying your own preference.
    9 points
  3. He might.... I reckon you were on a train going through Neath, where the railway crosses the Neath Canal, the River Neath and the Tennant Canal in very quick succession - technically all three are navigations, none are used now.
    5 points
  14. Maybe real boating is where you do more mooring than moving, only moving a few hundred metres over the course of 1-2 month, often mooring on lock landings or sanitary stations???
    3 points
  18. She certainly doesn’t…..
    3 points
  20. Andy Tidy's video from the recent Pelsall gathering springy
    2 points
  21. Hello!! I just joined the forum so there are so many things I don't know yet, I hope to have the help of the boards, and I really want to get to know you all on the forum.
    2 points
  23. @IanD make sure you're out of the Yorkshire region before @Midnight gets there. Based on his track record there's going to be three breaches, a collapsed tunnel and a landslip preventing him getting back to his mooring! 😁
    2 points
  25. Look at this one I encountered moored at Linslade today, forcing me into the offside bushes. I’m going to write a strongly worded letter to my MP. Disgruntled of Tunbridge Wells.
    2 points
  26. The decompressors are the 3 levers that are connected together with the rod, not the oil caps! I think you are out of your depth with this problem. Is there another boater near you who could maybe help? Where are you?
    2 points
  28. These are the ones I use: (Use the right size, image is just to show the type, Mikalor do nice ones...) Be careful tho, 'cos you can't half get 'em tight!! I also use a little bit of exhaust assembly paste, really helps to stick the parts together...
    2 points
  32. Thank you for explaining how things look from your perspective but I think part of the reason why you may get what you think of as adverse comments is because of how others on the forum "see" you. Since you joined, there have been many instances of topics where you have given us the benefit of your wide knowledge at great length and this gives the impression that everyone else is wrong. I am sure this is not what you mean but that is how it comes over. This and the fact that you seem to be so knowledgeable on so many subjects does perhaps make those of us with lesser knowledge of many subjects react a bit to your posts.
    2 points
  35. Experiencing wide beam rage right now. This one turned at Woolfhamcote and is now crawling west slower than the 3 boats following it can go on idle. We cracked in the end and moored for lunch. Cheers Graham
    2 points
  36. If you want to go back 100 years and use a horse move to Wales. Horses go faster than our speed limits 🤪
    2 points
  37. That looks like the bleed point in the body of the pump. We painted all our engines green when on the fleet, and about that shade as well. The college training engines were also painted green. I don't think the colour is of much importance in this case.
    2 points
  38. This is curious as there is no way I can think of to genuinely test a leisure battery for capacity and sulphation without a right load of faffing about over about a ten hour period. Generally cheaper to buy a new battery than pay someone to carry out a meaningful capacity test giving a result you can actually rely on. "All singing" one minute testers are little more than theatre, used as a tool to sell batteries, as in. "Oh look, the printout says your battery is goosed, you need a new one Sir. We just happen to have a row of them of the shelf here Sir." So I'm not sure what went wrong at Streethay, or what it was that their "all singing" tester would actually have been measuring. Did it print anything out? What did it say?
    2 points
  40. Surely that post by @Ray T was answering queries and comments by @Tonka and @Goliath ?? Not sure why it warranted that response or the little dig at other posters.
    2 points
  41. That makes two of yous😂
    1 point
  43. Vessel interaction is a very interesting topic. The famous Marchioness disaster on the Thames involved a degree of interaction. Canal boats are a bit like tiny ships in confined waters. https://maritime-executive.com/blog/vessel-interaction-have-you-considered-the-possibilities
    1 point
  44. We have just crossed the puddle banks again and there is a similar structure at Bridge 97 at the west end of the embankment. The cut out for a gate is more obvious. It is facing away from the embankment too which supports the flood gate idea. Cheers Graham
    1 point
  46. I love doing things like this when supposed to be doing other things....
    1 point
  48. I'm sure that is why they are there. It is a sign post which may be used in future rather than a sign post the sign on which has been stolen or otherwise gone missing.
    1 point
  49. This post cannot be displayed because it is in a forum which requires at least 10 posts to view.
