Quattrodave
Patron
About Quattrodave
    Hertfordshire
  • Occupation
    IT
  • Boat Name
    Seaquest
  • Boat Location
    Great Ouse
3,941 profile views
Quattrodave's Achievements
Proficient
Proficient (7/12)
  • Patron Rare
Recent Badges
170
  1. I have schneider rcbo's never had an issue with them clamping ferrules...
  2. In theory I'd agree with you but depends on the pipe work level and where the leak is... you could end up with the syphon effect and the tank will still empty its self or semi empty its self..... But yes I still prefer a top take off....
  3. I'm not adding an NRV. The current setup has an internal tube from the top of the fresh water tank to the bottom with an NRV at the bottom of the tube. Then externally to a gauze filter, pump, accumulator, square d pressure switch and on to taps / boiler etc...
  4. Afternoon all, Quick question, is it normal or even needed to have a non return valve at the bottom of the water tank pick up tube?
  6. @DucksAreFaster I would assume they wouldn't have been built with a weed hatch you can't remove... I take it you've tried swinging the steering either left or right see if it can get clearance... Any chance of some pics of the offending area?
  7. @wouldiwere123 Any chance of a photo of the inverter and surrounding area please....?
  8. Yet again, another post open to interpretation and misunderstanding. If we had decent, full & clear facts from the outset it would have made it much easier and quicker to respond appropriately....
  9. I'm not sure Tesla's come factory fitted with indicators or dipped beam headlights...
  10. Yes I could just laminate it but the ones the EA used to supply were then self adhesive on the outside so you could stick it to the inside of your window... They were pretty smart pouches... The closeest I've found are 'self seal laminating pouches' or 'cold laminating pouches' but they arn't adhesive on the outside.....
  11. not any more, they won't even print your registration for you 🫣
  12. Weird question.... does anyone remember those self adhesive plastic registration holders that the EA use to supply a few years ago... Any idea what they're called and where I might be able to get some...?? Thanks
  13. What are you trying to achieve and on what device??
  14. My guess would be 4800 Although I do wonder what your trying to do & with what device...
  15. Last year I accidentally (just don't ask🤦🏻‍♂️🤦🏻‍♂️) purchased a Tohatsu 25HP 4 stroke extra long shaft outboard. Bloody nice emgine BTW... if you can wait till the weekend I can send you @Dom Hopking measurements and part numbers if you're interested??
