rusty69
MIFI anyone?
Perhaps they're trying to get rid of them...
Tim - this type (looks suspiciously like the Netgear variant -of which I have two) is usually unlocked and yes they take a standard SIM. The price is good 'cos a decent MiiFi goes for £30 ++ in eBay and as often battered.
Seem strange to me that the Vodafone 'botched' version of an older and less powerful model (R216) goes  for more money.
(It's botched 'cos Voda put their own software on the dongle which slows it down, even though it's prettier than the base Huawei set).
Share this post
10 minutes ago, mrsmelly said:
do you just need any old sim thingy with that then?
Don't ask me Tim,I haven't read the small print. I expect it is unlocked to any network, will take a standard sized sim card of the mobile broadband variety or apparently the  three networks allows use of their standard sims in these devices these days.
Smallprint
Suggest if anyone actually wants to buy one, then they read up the detailed spec of the device and their sim card first.
Edited by rusty69
Share this post
51 minutes ago, gbclive said:
Seems good value - however, no option to plug in an external antenna?
So how does that work then with no external aeriel. Signal is notoriousy poor in a narrowboat anyway isnt it......i want to find a solution to this thats affordable and that is an option.
Does anyone have one that can review for me?
Share this post
It will work in a strong signal area within a metal boat. Our Huawei one in poor signal areas would only work with the mifi in the window or cratch. Obviously if there is no signal at all, an external aerial will make no difference.
If you are dependant on internet, chuck a bit more money at it. I picked up a teltonika router and poynting aerial for about 130 quid off ebay....second hand of course
Share this post
So its basicly a wireless home wifi system that will allow multiple devices to feed off it....sorry im rubbish with all this tinternet stuff....we have 20gb on a sim allowance and our phones at 30gb mobile internet so lots of data but phones struggle....
Looking for a booster of some description i guess.....is that what it is?
Share this post
No.its just like your phone without the phone/app capability.
If you struggle with internet on your phone and its in a window and acting hotspot, then this device will not improve matters.
You either need to find a supplier who's signal is stronger in your area, or get the signal into the boat better with an external aerial.
I think you had another thread going on this that suggested a booster device too iirc
Share this post
Yes i did get involved in that thread just wondered if this was an alternative was all. Apologies for my lack of understanding with this....the price drew me in i must say!!!
Share this post
No problem. Try placing your phone in hotspot mode (if your provider allows this).Stick it in a window and connect another device to browse via the hotspot. If it improves , this is what the mifi device will allow you to do with a dedicated data sim (or perhaps a three sim).
If it doesn't then you need a different provider or an external aeriel and router/mifi that will accept one, or move the boat elsewhere.
Share this post
Ive got a white huwaye thingy that works well. It doesnt have aeirial connection but theres a good o2 signal here so I just lay it on a table and it works well. On my all portholed cave, sorry boat getting a signal was bloomin hard work. The Argos offering is good at thirty quid innitt?
Share this post
Probably,if you don't need an aerial connection. What we need is some reviews from someone who actually has one.
Share this post
Well, is does - but NOT if it ain't got an (usually two) aerial socket. Plenty of adequate kit available on fleabay at similar or less prices. I looked at Tp-Link's website and couldn't find any mention of antenna sockets. So be warned.
Share this post
My Huawei Why-Fi E5330 hanging in its Meccano cradle in the window, no need really it would work on the floor or anywhere.
Share this post
you might improve things further in a poor signal area if you used plastic to hang it rather than metal
Share this post
They are the blue and yellow flexible plastic plates, only the little holders at the bottom are steel strip.🙂
Share this post
I assumed that you had built it from proper meccano not the rubbish plastic stuff ;)
Share this post
There was red flexible Meccano plastic plates available 60 years ago.
Share this post
I have two!
I ended up with a spare due to a warranty failure after nearly 3 years
Excellent piece of kit way better than the Huawei with the two antenna ports that I also have.
No problems with signal inside the boat better than the Huawei in the same place.
prices were between £60 and £70 originally so this is a goOd deal.
If I didnt have two I would get one as a spare at this price.
ETA
No external antenna ports but it doesn't need them, it will also do 5g wifi instead of 2.4g, and finally it has a high power wifi mode so coverage in the boat and outside is excellent.
ETA2
Out of stock
only place I can find stock is Cambridge and Witney.
Edited by Loddon
Share this post
12 hours ago, Mike the Boilerman said:
Does this device do anything a mobile phone set up as a wifi hotspot doesn't?
No. But you can fit it where it gets a good signal, and connect it to a charger permanently.
i used to find it irritating to have to keep retrieving the phone from its good signal location, (to make calls or other things), and have to keep connecting it to its charger.
Also, for some years, most phone sims limited the amount of data per month that could be used by tethering, whereas you could get larger monthly data allowances on data sims.
Maybe not the case now that Three offer unlimited tethering - although, when I had their previous unlimited tethering offering, they throttled the speed between 3pm and midnight, so I dumped them as soon as practicably possible.
Share this post
4 hours ago, rusty69 said:
I wonder if the WPA2 security on these devices is still ok, or not what its KRACKED up to be.
Got a feeling most people will not get that.
Share this post
 I wouldn't want to hang up an expensive posh mobile in a window where it could get damaged and for all to see
Nor stick it up a pole as some do (?)
A MiFi is a lot cheaper
          More compact
          Easier to charge
          less desirable
         has socket(s) for an antenna
        can be had for £15 - £30 on eBay
Share this post
