Digital Instrument Panel
Jen-in-Wellies
3 hours ago, nicknorman said:
On one of the older helicopter types I flew with dial-type instruments, the system instruments were rotated so that the needles all pointed to the 12 o’clock position when the readings were normal. That way you could tell at a glance if any of the system instruments were abnormal.
As I pointed out in post #11.
Unless you require extremely precise readings (unlikely in a boat, car of flying thing) digital instruments have no advantage over analogue except for bling value.
Edited by cuthound
Spullung
On 17/06/2018 at 21:16, cuthound said:
I much prefer analogue instruments. You can twist the gauges so that the pointers are upright when everything is normal, so you don't have to even read them,  just glance at them to check that everything is OK.
 With digital readouts you need to actually read each one to understand what is happening, which takes much longer.
With the arduino it would be possible set alarm thresholds for any parameter which could flash a bright red LED, sound a buzzer etc.
Or you could have three LEDs per parameter: yellow below normal, green in normal range, and red above normal. The actual numbers can be logged at suitable intervals and reviewed when the need arises.
Indeed, but it all adds to the complication, analogue meters rule for quick assimilation of information on a boat.
Agree with Cuthound. Needles on dials, aligned so that normal readings are vertical are the quickest for assimilating information and reacting to problems. That is why race cars and many aeroplanes are set out that way. Generally, on an inland boat the pace is a little less frantic than in a racing car with an engine about to blow up, or a flying machine about to turn in to a brick, or fly in to a cumulo-granite cloud. For my own boat I am sticking with moving needles on round dials. This project is for a friend who specifically wants a digital display.
There will be flashing led's and buzzers, as well as further information on the display *HIGH*, or *LOW* against the appropriate item as appropriate. No multi colour LED's, just red. Alternator charge LED is orange.
No data logging. There is limited EEPROM storage on the arduino that is used to store engine hours when it is switched off. This has a limited amount of write cycles (100,000 or so), before it wears out, so it is only updated every 0.1 hours (6 minutes). That should give a life of around 10,000 engine hours and probably something else will break before then. Data logging would require something else to write the log file too, or to read data for a log file. Perfectly possible, but no plans to implement it. I have got serial comms set up with the laptop for debugging, looking at input values and intermediate calculations, but this won't be turned on in the final sketch.
Jen
Jen
8 minutes ago, Chewbacka said:
It would be quite clever if the display were to tell you against engine hours when key service items were due, such as engine oil, gearbox oil, fuel filter, air filter etc.
Now there is an idea. Would need some thought as to how annoying the nagging would be and how to clear it once the service took place.
Jen
Edited by Jen-in-Wellies
Jen
Easy, same as a car, go to the dealer - in this case you - and pay an unreasonably large amount of money to confirm the service.  Good future income.
On 23/06/2018 at 15:05, mrsmelly said:
Oh dear!! does all this mean my dial thingies that all work with lovely needles are soon going to stop working ☹️ Will I no longer be able to see my water temp is exactly where it should be and so too my oil pressure and that my batteries are charging/charged without " Going Digital " :ninja:
No. Go for gauges. Like Mark99:
Whilst I  wouldnt have the old knacker of an engine those gauges are great and can be seen by grown ups without resorting to spectacles ?
Good point. A RPi would be better then. :)
Jen
Jen
You could consider a serial EEPROM if you have 2 spare data lines for I2C interface. They generally have 1million write cycles. Also, the write cycle normally only writes to one page (64 bytes in the smaller EEPROMS) so perhaps there is a strategy where several different memory locations in different pages are used sequentially, to spread the write cycle “damage” around the memory.
A quick update. The veroboard that contains the connections to the outside world, input circuitry, warning LED's and buzzers is nearly finished. Just waiting on a metal oxide varistor to arrive as part of the protection from incoming boat electrics voltage spikes. More details later.
Jen
Pictures of liquorice allsorts and spaghetti. Yum! More evidence that I can't make wiring look neat.
The aluminium control panel arrived today. Made from our CAD file by a local company that specialise in instrument panels. Engraved legends, coloured a nice blue. Very reasonably priced considering the work involved. I've assembled the various components on the back and everything fits! A nervous moment as we had one go to get this right...
Jen
The key switch and horn button are still on the old panel. The photo of the front is out of focus and the lens on my phone is reflected in the lexan "glass" over the display.
  • Happy 2
Appearances are deceptive. It is 16x0.2. About the biggest that can be successfully soldered to 0.1" pitch headers without risking shorts. Heatshrink on the connections just to be sure.
1 hour ago, Tony Brooks said:
Agreed so not RCD compliant re minimum number of strands.
Best let Jen get on with it and stop being supercritical
If I remember correctly the iso std required by the rcd are for device interconnection cables, wires within a device are excluded so put it in a box and all is ok so long as the manufacturer (Jen) is happy.  However the internal wiring needs adequate support for vibration resistance, but then I’m sure Jen will sort that with a few cable ties and some silicone.
added - meant to say it looks good but got side tracked by the above.
Edited by Chewbacka
Correct.
