The bolts at the rear of our prop shaft recently sheared off. We went to buy some new bolts for it and were told we needed 60mm high tensile M11 bolts. They didn't have any, so we have fitted M10 for now and she is running okay. I cannot for the life of me find any M11 bolts anywhere online or elsewhere. Does anyone know where I can get them, or what I should do?
Thaks
Tom
They do exist, but they are a special, so will be vastly more expensive than either an M10, M12, or 7/16"
Check with your local nuts and bolts supplier - they will probably have to buy a thousand to supply your handful, and will charge you accordingly....
Thaks
Tom
Depends how much you trust the person telling you this. I'm inclined to agree with RLWP. Far more likely to be 7/16" imperial bolts.
Are you related to Tom Vek?
MtB
I've never seen an 11mm (M11) bolt. I wouldn't say there's not one. I too would go with 7/16 easy to get and much better fit than 10mm.
When I was in engineering screws/bolts such as these were always described as "b*stard size" for obvious reasons, go with 7/16 it will do the job.
Phil
Thaks
Tom
M11 bolts exist, but this is not a recommended size, so only really big users will be able to get them easily. (Automotive companies have their own reasons for using non-preferred sizes!)
As has already been said 7/16" is close (11.11 mm) so may well fit. If not I'd either stay with 10mm and keep an eye on it or enlarge the holes to take 12mm which is another preferred size. The drive force should not be transmitted by the bolts, but by friction between the two halves of the coupling. The bolts are only there to clamp the halves together and produce enough friction.
N
N
Some couplings, especially older ones, rely on the bolts to locate the coupling halves together. Ideally these should have 'fitted' bolts with precision shanks. Modern couplings generally have a locating spigot and corresponding recess on the two halves, so loose fitting bolts are perfectly OK.
If the OP's coupling doesn't have this locating spigot he really should try to find the right size of bolt. I agree, much more likely to be 7/16" than M11.
If it really is M11 (I would be amazed), then he could get some 7/16" bolts skimmed down to that size, there should still be enough strength left in the threads.
Tim
This has been really helpful so thank you everyone. I will get some high tensile 7/16" bolts and try fitting them on instead of the M10's which may only be stainless anyway.
Persumably I can use locking nuts and tighten as much as possible to stop this happening again?
Yes Locking nuts, and plain washers either side, but do check the alignment of the coupling- the two halves need to be parallel before the bolts are tightened. If not there will be a cyclical variation in load and the bolts may fail from fatigue, especially if they are very tight.
To check pull the coupling up by hand (no bolts) and insert a feeler gauge at the top, from the bottom and from either side. The gap should be the same all round within a thou or so. If not the coupling is out of line.
If there is a flexible coupling the test still applies- everything will last longer if it's all in line (except possibly needle roller bearings in a propshaft).
N
  • 7 years later...
4 minutes ago, Gew said:
Old Volvo cars use M11 for their head gasket bolts.
7 years older now too. ??
7/16" looks like 11.11mm, so fairly close to M11.
Clearly the bolts exist, they're building a new junction onto it this year and they've got to make sure it holds together:
https://www.essexhighways.org/highway-schemes-and-developments/highway-schemes/m11-junction-7a.aspx
Maybe the bolts are made in Harlow, after all they say this new junction is:
"supporting business growth in the area"
Hardly ever been on the M11 myself, I'm from south of the river guv.
16 minutes ago, WotEver said:
I wonder if the M10 bolts lasted the last 7 years, or if he ended up with 7/16...
According to his profile, the OP joined on 10/4/13, last logged in to CWDF on 11/4/13 and posted twice, so I doubt we shall ever know. Life is full of these little mysteries!
Jen
The ones they'll be sourcing at the moment, will be "lockdown" bolts.
