Kristian Posted January 21, 2010 Report Share Posted January 21, 2010 Hello all, I will be doing my own hull blacking later this year, have you lot got any recommendations about which type of 9-12" roller sleeves to use? Will it be the foam type or the furry emulsion type? And how long do they last when using hull blacking, just trying to work out how many I may need. Thanks Kristian. Link to comment Share on other sites More sharing options...
OldGoldy Posted January 21, 2010 Report Share Posted January 21, 2010 ........... have you lot got any recommendations about which type of 9-12" roller sleeves to use?Will it be the foam type or the furry emulsion type? And how long do they last when using hull blacking, just trying to work out how many I may need. I use a furry one, in fact a 7 inch one which is not too unwieldy to handle and fits nicely between the rubbing strakes, and follow with a 3in brush in the other hand to remove any tiny bubbles. I only use one per blacking and trap the whole thing in water (in the roller tray) between coats (shake well to remove water from inside roller before starting next coat!). It's only a cheap kit that I buy (around £1.79 - £1.99 from Wilko) then bin brush, roller and tray when finished. Link to comment Share on other sites More sharing options...
Pie Eater Posted January 21, 2010 Report Share Posted January 21, 2010 Hello all, I will be doing my own hull blacking later this year, have you lot got any recommendations about which type of 9-12" roller sleeves to use?Will it be the foam type or the furry emulsion type? And how long do they last when using hull blacking, just trying to work out how many I may need. Thanks Kristian. I have never seen anyone using 9-12inch rollers, most people use the small 3 or 4 inch rollers. The furry type rollers are good for the first coat as they get into any pitting on the hull. Additional coats could be done with foam rollers. I usually a six pack of each type and have some left over. You can make them last longer by leaving them in water overnight. Steve Link to comment Share on other sites More sharing options...
Liam Posted January 21, 2010 Report Share Posted January 21, 2010 The other tip is to wrap clingfilm around your rollers and brushes when you've finished for the day. If you make sure you they are well wrapped, and don't have air trapped in them, they're fine to use after a bit of dipping the following morning. We usually go around the boat first getting into the bits and peices with a brush, such as the welds on the bands and where the side plate meets the base plate.. and then go over it all with a roller. Link to comment Share on other sites More sharing options...
mayalld Posted January 21, 2010 Report Share Posted January 21, 2010 Hello all, I will be doing my own hull blacking later this year, have you lot got any recommendations about which type of 9-12" roller sleeves to use?Will it be the foam type or the furry emulsion type? And how long do they last when using hull blacking, just trying to work out how many I may need. Thanks Kristian. Foam every time. Oh, and put aside any norty thoughts you have about doing the job double quick with a big roller. Mini-rollers are what is required, and you will need lots of spare sleeves, cos they disintegrate, Link to comment Share on other sites More sharing options...
nb Innisfree Posted January 21, 2010 Report Share Posted January 21, 2010 We use small ones short haired ones and as we use bitumen based blacking we can store them in a jar of white spirit overnight and then they last for years. Link to comment Share on other sites More sharing options...
DHutch Posted January 21, 2010 Report Share Posted January 21, 2010 Depends a little on both the paint, and the substright, but we use 4inch coarse foam rollers, two people one each side, two coats. Four rollers. But have some spare because some done last as well and theres nothing worse than being on your last one and it start breaking up half way thought the last coat. Daniel Link to comment Share on other sites More sharing options...
Chris-B Posted January 21, 2010 Report Share Posted January 21, 2010 I normally leave the Roller at home and go the yard in the Bentley ok cOAT ! Link to comment Share on other sites More sharing options...
richardf Posted January 21, 2010 Report Share Posted January 21, 2010 I normally leave the Roller at home and go the yard in the Bentley ok cOAT ! I hear you gave your blacking a close inspection the other day Chris - come on, tell all........ Link to comment Share on other sites More sharing options...
Liam Posted January 21, 2010 Report Share Posted January 21, 2010 Didn't get wet did you Chris? Link to comment Share on other sites More sharing options...
steelaway Posted January 21, 2010 Report Share Posted January 21, 2010 I have never seen anyone using 9-12inch rollers, most people use the small 3 or 4 inch rollers. The furry type rollers are good for the first coat as they get into any pitting on the hull. Additional coats could be done with foam rollers. I usually a six pack of each type and have some left over. You can make them last longer by leaving them in water overnight. Steve Hi The professionals use the 12" furry rollers. So do I, foam are no good because they are not strong enough for bitchumen. I store the roller in the paint tin and fish it out with the handle when needed - always good to go. Alex Link to comment Share on other sites More sharing options...
Dalesman Posted January 22, 2010 Report Share Posted January 22, 2010 I always go to this place for bottom blacking..! Link to comment Share on other sites More sharing options...
Timleech Posted January 22, 2010 Report Share Posted January 22, 2010 Hi The professionals use the 12" furry rollers. So do I, foam are no good because they are not strong enough for bitchumen. I store the roller in the paint tin and fish it out with the handle when needed - always good to go. Alex We use 9" furry rollers. The foam are too soft and tend to disintegrate especially with tar based paints. Keep them under water overnight, shake off the water before starting again. Some rollers will shed hairs to start with, it's trial and error on that but I don't remember that problem recently. Tim Link to comment Share on other sites More sharing options...
Pretty Funked Up Posted January 22, 2010 Report Share Posted January 22, 2010 I found the foam ones useless, mohair style finishing rollers worked the best by far. Hold loads of paint and no bubbles at all. Link to comment Share on other sites More sharing options...
Chris-B Posted January 22, 2010 Report Share Posted January 22, 2010 I hear you gave your blacking a close inspection the other day Chris - come on, tell all........ Yep tis true Richard Walking down the gunnels )(sic) of Baldock..foot decided to go into space and brain told hand to let go of the rail !! FIRST full scale immersion of the year... fekkin cold..... Didn't stay in long enough to check the blacking though..... Chris :lol: :lol: Link to comment Share on other sites More sharing options...
Chertsey Posted January 23, 2010 Report Share Posted January 23, 2010 Interesting - does no one else use a brush? I wouldn't attempt it with anything else. Link to comment Share on other sites More sharing options...
OldGoldy Posted January 23, 2010 Report Share Posted January 23, 2010 Interesting - does no one else use a brush? I wouldn't attempt it with anything else. I've only ever used the 'thinner' paints such as Key's Imperial No. 1 (now defunct) or RapidPaints Bitumen, and have both brushed and rollered them, the roller to cover the large areas and the brush for 'corners' much as one would for emulsion. Comastic and Intertuf, I've only ever seen brushed, presumably because they are much thicker paints. Like most things, it's down to personal choice. Having carpal tunnel syndrome, I could not even consider using those thick paints or brushing the whole boat. Link to comment Share on other sites More sharing options...
Bob the welder Posted January 24, 2010 Report Share Posted January 24, 2010 I always go to this place for bottom blacking..! oooooooooooooo i wish .bob Link to comment Share on other sites More sharing options...
sueb Posted January 24, 2010 Report Share Posted January 24, 2010 Yep tis true Richard Walking down the gunnels )(sic) of Baldock..foot decided to go into space and brain told hand to let go of the rail !! FIRST full scale immersion of the year... fekkin cold..... Didn't stay in long enough to check the blacking though..... Chris :lol: ;) Funny how the brain does that. I gave up gym at school when I should have done a somersault over a horse. Head down, bum up and I let go Sue Link to comment Share on other sites More sharing options...
Smelly Posted January 30, 2010 Report Share Posted January 30, 2010 Interesting - does no one else use a brush? I wouldn't attempt it with anything else. We used brushes second time round and managed to get quite a bit more on, thickness wise, than with rollers. We were at caggy's and Ralph and Gordon derided us for using a roller first time round as it went on too thin for their liking. With experience I'd agree. Sorry for gravedigging but I'm thread hunting. Link to comment Share on other sites More sharing options...
