I'm always going this sort of thing.
There is a vocation somewhere here but I missed it.
On 03/02/2023 at 17:25, magnetman said:
A properly designed wood burning stove with preheated secondary air will burn clean once it is hot enough. 593 degrees C seems to be the figure for this. Once the firebox gets to this temperature and is being fed by air preheated by the stove itself the combustion process consumes all of the volatiles in the smoke.
I've got a diy fire made like this on one of my boats and it has a 2 metre flue. Once it is up to temperature there is no smoke at all.
At the moment it is only ticking over so there is some smoke but if I need more heat I can get it going more.
This a problem with a lot of fires on boats. They are too big. What you want to have is a fire which is properly specified for the space needing heating. Otherwise you get a lot of inefficient burning.
Also if your flue diameter is too large you can't keep a hot flue. A hot flue is one of the key requirements of an efficient fire. If the flue is losing too much heat then the fire will not perform as efficiently.
Does that mean a double skin is better, in this regard?
I'm not sure about that.
I'm slightly biased as I believe in having equipment which can be easily inspected and dismantled so a double skin flue would not be something I would want to have on a fire in a boat. Too complicated to get it apart.
It is an interesting question.
I suppose logically it would make sense for an insulated flue to remain hotter but it's possible that at a certain temperature the insulation would become problematic.
I reckon the best approach is a smaller diameter flue. Single pipe. Decent wall thickness. This stops the flue from cooling down too much. It is an active part of the burning process rather than an afterthought.
I've not yet had flames out the top of the flue !
On 02/02/2023 at 01:47, Alan de Enfield said:
You keep a spreadsheet of your emissions ?
No I use spreadsheets to light the fire
19 minutes ago, rusty69 said:
Excel?
As easy as 123.
My first pc had this on it
https://en.wikipedia.org/wiki/As-Easy-As
According to Wikipedia it is defunct.
I had a Sinclair QL.
3 hours ago, magnetman said:
The one I have was made by someone else with input from me. He did not want to do any more plus it would probably be about a grand retail price so not really going to have much of a market.
These days I don't think many fires are going to turn up which are suitable for canal boats in an emissions sense. The market is too small and the cost of getting defra approval is going to be huge.
Not worth it, sadly.
Another issue is choice supportive bias. I am liable to think it is a whole lot better than it is in reality.
Boatman small and Defra approved
That's good !
I didn't know they had it certified.
http://boatmanstove.co.uk/
Interesting to see the 78% figure.
4Kw is quite a lot of heat to be pumping into a small cabin. This will be without the back boiler.
It is good to see they have defra approval for this one. I think a smaller one maybe 3Kw would be appropriate.
How many clicks between excel and global warming?
About 7 I have not tried it.
I think you might fall into the brand name trap I mentioned. Excel is a brand name.
That's good !
Its easy to upgrade the old ones, baffle plate and a top draft directed down over the glass is all it took
9 hours ago, Steilsteven said:
Hydrogen is very expensive and is already available in similar sized bottles but you can only buy it from BOC at just one depot in the whole country.
If it leaks it releases a lot of co2 to the atmosphere
How does that work then?
Surely leaking Hydrogen is Hydrogen, not Carbon Dioxide!
11 hours ago, Steilsteven said:
If it leaks it releases a lot of co2 to the atmosphere and it's production ( currently ) uses a lot of fossil fuels.
IIRC Hydrogen is H2, my science knowledge isn't good enough so can you please explain where the CO2 comes from.
It's a greenhouse gas 200 times worse than CO2
That however doesnot cover "If it leaks it releases a lot of co2 to the atmosphere".
I am fully aware of its greenhouse status, I couldn't/can't get my head round the release of CO2 from a leak.
The statement didn't say "if it leaks it is a serious Greenhouse gas" or words to that effect, it clearly stated CO2 was released.  Had it said it was a Greenhouse gas I would have understood, but the stement didn't say or imply that.
We have a 4kW woodburner in the living room at home. It keeps an 80m^3 space tolerably warm when it's -1 outside.
^^^^^ This
When I was at school, one of my chemistry books had a chapter entitled "The gas that the Earth lost", which was about hydrogen. My recollection is that hydrogen molecules are light enough to overcome the earth's gravity and escape into outer space, which is why hydrogen is not found in the atmosphere.   No doubt this is the reason for calling it a short-lived greenhouse gas.
Edited by Ronaldo47
typos
Thats interesting coz I did a bit of astronomy at uni many years ago and one of the problems that Mars has is that it is too small gravity wise to hold on to the hydrogen when it gets split up in the upper atmosphere.  The earth on the other hand WAS just able to keep its hydrogen from wafting out into space.
Anyway, Mars is too small, that's for sure.  Maybe I should have paid more attention during the lectures.
One of the other issues is the warming of the permafrost that allows the release of Methane.
All in all, it's looking bleak and still no mention of population control of some sorts.  I suspect it will sort its self out one way or another
I think you are talking about helium not hydrogen, as I understand it we are running out of helium due to atmospheric loss into space
Google found the following article which suggests the climate  impact of hydrogen leakage  could be a tiny percentage (0.6%) of the  impact of fossil fuels at the time of writing in 2006. It assumes the hydrogen is created using nuclear energy.
29 minutes ago, MartynG said:
Since Hydrogen is the most abundant chemical it would seem a shame not to use it.
I think it's the most abundant element in the universe rather chemical.
But the main problem is, surely, that most of it isn't here on Earth.
