Everything posted by nairb123
hydrogen boat with UK fuel cell completes testing
nairb123 replied to nairb123's topic in General Boating
Makes storing a generator on the boat look a bit lame. Wonder what the BSS examiner thought. -
Sorry if it's already been posted... Form an orderly queue for installation. https://bridgeclassiccars.co.uk/worlds-first-hydrogen-boat/?fbclid=IwAR1qtvZ6abw2bXFV2fcU2ALudNIh4s1uGU4PkpM9LN_WOAdjyCNmamI9Dco .......
Yup, I think you are right. I have been on the system some 30(ish) years and know I am well into the autumn years of being on the canal. I now hope for 2 or 3 years of splashing about. Any more is a bonus.... But I still wonder if there will be any boating left in 20/30 years time.
Thanks for the replies. Its a petrol gen. Its stored with a cover in the engine room when I am not there. And because its not a gas tight environment that is the issue and why the bss examiner will fail the exam I guess. The gen is an eu20i which is not the lightest to carry up the path. So the option is to put it in the car every time I leave and bring it back each time. The boat does have a gas locker in the front with drain holes etc. But I was told that petrol cans should not be carried in the locker. Which is where I used to store them when travelling about. But these can easily be stored off the boat at other times. What will we be using to charge the batteries when diesel engine are banned on boats.....
I have a generator which I run on the bank or on the back of the boat when necessary. Is it legal to store the generator on the boat when the boat is not being used?. Apparently, it's an automatic fail if one is found on the boat during a BSS test. I dont know if it is ok to store the generator in the cratch during the test, but I take it off the boat during the test anyway. Ta Nairb
These carbon monoxide detectors (Kidde 7DC0)
I and others had convinced me that I was living in a death trap. One that I have lived in, and used as a holiday home for the last 28 (ish) years without any noticeable issues. I expected to see the co monitor to give a reading, maybe a worrying one, but so far with the morso running and cooker on for 25 mins there has only been a zero reading. I did put the monitor near the generator just to check, and it did beep until put in fresh air again. So it does seem to be working. It will be interesting to see over time how representative these past days are I have joined the converted. Maybe I will get one for the bedroom as well. -
In my house in the defra multi fuel stove, there is an opening at the rear of the stove at the lhs at the bottom. It cannot be closed, and so the stove can only be shut down a certain amount. It gobbles fuel and runs the flue hot. There is reduced control over the fire. In truth, it's probably more expensive to use with the gov approved fuels than to have the gas fire heating on. I did modify the stove so its much better to use. Of course it's now no longer a defra stove but can be put back as one within 5 mins. I also found that burning smokeless fuel removed the smoke issue, but it won't pass the councilman's inspection as is. But the fuel lasts much longer.
Wait for a foggy day, they won't see the fire........
For me, it's all about the cost. At the moment, I get all my wood for FREE. So to change to a gov approved source of fuel will cost about £150 quid a month (estimated at the moment). That might be almost the same as having the central heating on. I will need to see this working to know. If cost is not an issue, MP's etc, then fitting the correct stove and using approved fuel is a NON issue. A narrow boat on the other hand has other more difficult problems. Defra approved stove on a boat???. Anyway, at the moment it's the house that's in the firing line
It would seem that after all the interesting discussions in this forum/thread about the levels of smoke and for how long etc what it actually comes down to is......... If you have a defra (or some approved) stove, and it's correctly installed and are burning an approved fuel (https://smokecontrol.defra.gov.uk/fuels.php?country=england ) then, when the council comes to check your house for smoke infringement you are in a better situation. Its a bit like the tax man - if you have the right bit of paper, then they move on to the easier target - for now.
That make a lot of sense. I was expecting values of between just above zero and maybe less than 15 or so. In a house, a value of zero makes more sense due to its volume. In a confined space of the boat, I expected to see A number. But it's sitting here near the morso and shows zero, and so far has done so where ever I put it. Panic over. -
1st one fitted. -
I have only just gotten round to unpacking it. It came with the new bss last year. So I have no example to go by other than buying another. Being a landlord for years I used to have a spare lying around. But I'm not a landlord any more otherwise I would have tried 2 or 3 of these things. Yes............ zero is good. Having been on this boat for 28+ years, it's not killed me yet as far as I know. -
Yes, zero is what we need. It's just for some reason I was expecting a small amount from the morso 1410. But maybe there is none in the cabin. Plenty from the genny exhaust which is expected. If zero is showing, then it might be true. The device is brand-new. Maybe I should stop fretting. -
I finally set up my Kidde 7DC0 carbon monoxide detector. With new batteries. I was expecting a small amount? but the detector sits there showing zero. I have put it at floor level and at head height......... still zero. So I held it in the exhaust from the generator running on the bank. Beep loudly giving a high reading. When it had setteled down I put it back in the cabin with the log fire running and it still sits there at zero. Am I lucky or is the NEW detector faulty. Is zero normal - and good Ta Nairb
I have to say in my case I have a defra stove that WAS approved by the council, and it was hetas installed. BUT I dont have any approved wood or smokeless fuel. SO I am going to get done over if they demand to see the wood supply(a whole shed full of dried wood). There it is................. no amount of protesting about "how much smoke and for how long". They need to make money, and enforcing the "rules" will make them a few quid. They will be able to shout "eco" and be smug. Also, having a stove is a bit like having a narrow boat. Its wot the rich have, and It's good to kick them. I know in my area there are several "do gooders" that will take much delight in chasing down the "smoke polluters". It's like it everywhere. I agree that over time the whole country will become a "Smokeless zone" At the moment my boat is outside a smokeless zone, so it's difficult to see any action being taken for a while. But my house is now in the cross-hairs of some council official. And the person who reported me will be taking daily walks pass my house, waiting for the next infringement.
I completely agree with this. There is money to be made from a smoking flue or chimney. No other concerns. No intelligence or facts of starting a fire. If there is smoke, it's a fine. Fear will drive a lot of people from using stoves. And the (few)brown shirts that live amongst us will have their day until the next issue that gets their attention. It's a shame that there will be nowt to stop it.
In Nottingham, West Bridgford. Outside the inner city council. I will have been reported by a local I suspect.
For what it's worth........... I have had a letter from the council saying I have been reported for smoke out of the flue at my house. I have been using a multi fuel stove for almost 14 years (ish). This has never happened before. I think the council smells the chance of making money from a fine. Its a £300 quid fine a time for where I am. Towards the city centre its £1000 quid a pop....... each time.
Hope they filter out the PM2.5 emissions, else there will heaps of bodies in the surrounding towns and villages.
I have had the morso 1410 in the boat for the last 27+ years. Its done well, being used loads when I lived on the boat and regularly when no longer a live aboard. The top plate has become quite thin and suffered from having a cooking pot/kettle on it........ I was wondering how easy it would be to replace the top plate. The rest of the stove seems ok. I would need to replace the flue collar as well. Do these things come apart ok after many years of use. The alternative is to get a new stove which will satisfy the latest smoke regulations...... if possible. I do like the old morso 1410. Its been a good stove over the years.
Hope you are right. Altho I expect the communists to have a different opinion if elected. I will be at the farm later this evening so if there is a smog around the Congleton area in the morning you can blame me........
Yes, I completely agree. I think the huge problem is................. if it (smoke) can be seen then it's a problem. If I were to pump carbon monoxide straight out of the top of the flue, nobody would see it. I have a 2-stroke motorcycle. Almost certainly puts out less pollutants than the 4x4's that hurtle past on the dual carriage way. But the motorcycle leaves a blue smoke trail. Their time (2-stroke bikes) will come too and be banned. On a good note. When they finally ban Diesel engines, I will be long past giving a toss. Perhaps it will be back to horse-drawn boats.
I have to say it's been an interesting lesson as to why Hydrogen is not going to be saving the planet just yet and maybe never any good on a narrow boat. I'm sure it will find a valuable use in some applications. I have actually learnt something worthwhile. Meanwhile, I wonder how quickly the local councils will start to implement the fines for smoke and how they will do it. How do you measure and average of 3g of particulates/hr. Or is it just down to the council worker with their clip board making a subjective decision. I have worked out that the boat is moored well outside of a "smoke less zone" so should be free from hassle for a few years anyway. The house is different.
