Just now, The Gravy Boater said:
So you're saying I should stop burning old tyres on the towpath?
Only if you are in a smoke control area. If you are a member of a protected group you may be able to have special arrangements put in place to allow your long held traditional activities to take place on certain days.
1 minute ago, MtB said:
You must be joking. There is NO WAY I'm putting my postcode into that. The Smoke Nazis will be around in a flash!!
Give me your post code and I'll enter it for you !!
You can pan and zoom around the map without inputting a placename or postcode. But on my phone I just see a blank map with no smoke control areas (and a null legend).
One great thing with Smoke Nazis is they have a limited number of options when it comes to disguising their positions in the battlefield.
2 minutes ago, Alan de Enfield said:
No one has said that -  but I think it will seriously impede those composting toilet owners that want to burn their 'logs'.
But are they 'solid' fuel?
Much the same here. I can find my hovel on the app but no indication of whether it is in a smoke control area.
This is because it is a satellite image and was obscured by the smoke from peoples fires.
Burn more wood !
The moisture content will usually be above 20 percent.
You need to update your website - its still showing as RGx xxx
Really? Where? I've spent HOURS on end removing all references to Reading!
I dunno man... I feel the CRT are planning on curtailing my cultural norms.
9 minutes ago, MtB said:
SW1A 0AA
You posh git.
There were guard boats and police boats last time I tried to moor there.
Edited by matty40s
It isn't up to the CRT to deal with this problem. It is up to councils. I don't think the CRT have any powers on what you burn although if you are burning it on the towpath it is possible you may be infringing a byelaw..
Can you not cut the tires into small enough pieces and get them in the fire? I know the wires are annoying but it can be done.
I have been using a log burner in my house for the last 12+ years.  At the time of installation, I asked the council for a list of DEFRA approved stoves.  I chose one and had a HETAS registered installer put it in.  At the time, the area was NOT a smoke controlled area.  Checking today it's now been upgraded to a smoke controlled area some time in the last few years I guess.
I dont think a DEFRA stove is going to get round the problem.  My boat does NOT have a defra stove.
Im confused now
Is the DEFRA stove the one that takes a whole tractor tyre ?
Surely that was the whole point of defra approved stoves.
As for boats one can use the fact it is moving to defeat the smoke Nazis and the worst of the offences can be deliberately achieved under the cover of darkness when a Ringelmann scale doesn't work.
As I read our councils web site I read you can still burn stuff that isnt properly seasoned in a Defra stove but you can also still be fined if you produce excessive smoke. Even though in theory a defra stove should produce less smoke burning un seasoned stuff??
So yes I think you are correct.
The best way to confirm will be to burn ready to burn stuff that doesnt emit smoke (or very little) no matter what type of stove you have.
Edited by M_JG
And hope there are no smoke Nazis about.
But if you are emitting no smoke or very little why would that be an issue?
And who will decide this and how.  A fire usually "smokes" a bit on startup.  Is this another money making scam?.  Will you need to supply proof of stove?.  Or what yr burning??.
Cost wise, I get all my wood for free...... a massive saving on todays gas prices and a big saving on heating/cooking on the boat.
You can use exempt appliances in Smoke Control Areas (for the fuels specified for each) in this list:
https://smokecontrol.defra.gov.uk/appliances.php?country=england
It's necessary to look at the details.  For example my stove at home is on the list as exempt but in the small print it says that an additional stop mechanism to prevent a vent fully closing is needed.
Edited by alias
