What's it like, living on a boat?
LadyG
5 hours ago, Jen-in-Wellies said:
And the bizarre habit of tying a centre rope from the cabin roof tight to the ground. Perfect for introducing a rocking motion as another boat, duck, or floating leaf goes by.
Why on earth do people do this? I have seen boats that are clearly owned by people who know enough about boats to have a very pretty one, moored with nice 45 degree bow and stern lines, and then inexplicably with a centre line for good measure.
Full disclosure, I actually use my centre line for temporary mooring quite a lot, at a lock landing, need a quick cup of tea, or a pee. I take it down to a nappy pin or bollard and then back up to the cabin roof with a quick pull-to-release knot. But then I best believe that the boat is not secure in the slightest, and I wouldn't dream of having a moan at someone passing by at normal cruising speed!
1 hour ago, agg221 said:
I would like to see a definition of the canals as a transport network. If you want to moor up anywhere you like, that's great, but expect that other boats will be moving.
Hear, hear! Hence why I am considering a "please don't slow down on my account" sign. My impression is that the slow down brigade is a vocal minority who just by the nature of the request has somehow gotten their way written into boating etiquette. Perhaps the way to combat it is for those who would like to actually see more of the network to speak up more?
4 hours ago, Tony1 said:
But I do agree with your approach inasmuch as I am coming around to the view that slowing down to tickover should be considered completely optional, and should not be an expectation as it currently is. And thus the moored boats should not consider themselves the victim of impolite behaviour if you pass at say 3mph, which many of them do at the moment.
What it really comes down to is whether your boating is causing an unreasonable amount of nuisance to your fellow boaters. Sometimes if you are on a particularly shallow canal it is fair to crawl past at tickover. But when on a deep stretch of canal or even river, with several miles of moored boats, where passing at 3mph or even faster doesn't cause so much as a wobble, it is a completely unreasonable amount of nuisance to shout at the cruising boat to slow down because you haven't the sense to tie up your boat properly, or because you are under the impression that floating objects oughtn't move, no matter how slightly or harmlessly.
Which really is the crux of my bafflement. Why do people care if their boats rock? Is it spilling their tea, waking them from their nap, or causing some kind of damage?
I do this too. Very useful when single handing and mooring up to Armco, especially with an off shore wind blowing. Lets you deal with the mooring ropes at one end, without the other end being blown across the cut. I even have a short rope to the centre ring, separate from the centre lines, with a nappy pin on it ready to use.
17 hours ago, Jen-in-Wellies said:
If you want disapproval, try single handing a motorised swing/lift bridge with a lengthening queue of traffic on both sides with drivers beaming hate at you.
And the first car waiting has the bride in it, then the electric lift bridge fails in the open position so it can't be closed.  Fortunately when this happened it was at the drawbridge where there is another route across the canal a bit further on so cars eventually reversed back and went the other way.
  • Horror 1
I like the idea of a permanent short rope with a nappy pin, might steal that one. Without doing this it would be very hard to moor up single handed i feel. Since the centre line is very long, I normally put a loop of line through the eye, then back up to the roof, take loop three times round the handrail and then tuck the end of the rope through it. That way once you have the bow and stern lines secured, you just pull on the end, and the whole arrangement unravels itself.
I met a boater who owned a butty, converted to electric power with a pod on the rudder, whose boat lacked centre lines entirely. I have absolutely no clue how I would manage. But he said it was the way the working boats did it. I didnt want to question him so no idea if that is true!
When I was first on the canals boats didn't have centre lines.
Butties when working were normally attached to a motor, not an independent electric motor
Edited by ditchcrawler
Not all that long ago - at least in geological time. I asked our long experienced builder for an attachment - and he fitted a gi-normous D-ring a nd equally large reinforcement, sufficient to lift the boat out of the water... (methinks he felt affronted that I - as a southern customer who (by definition knows nothing about prper boating etc - so we'll give him something solid.)
Over the years it's been very usefull....
Same here. in fact my first ever narrow boat came with the beginnings of the idea, bollards welded onto the side decks about amidships which turned out to be staggeringly useful with a line attached, in the same way that a single centre line is useful.
This was a brand new Hancock and Lane boat in about 1983 and I didn't ask for them. They just put them on and they were brilliant for boat handling, although an appalling trip hazard!
And perfect for attaching your spring lines.
I do this as well.
I don't have a roof rail, so my solution for a 'quick-mooring' device was to use a length of rope attached to the centre line ring with a rolling hitch in it, and a nappy pin on the end of it.
The rolling hitch means I can adjust the length of rope leading to the nappy pin, so I can hook it onto the armco then tighten it up as needed.
It's brilliant if you need a quick stop, or when you're trying to moor and the wind is blowing the boat away from the bank.
I haven't suggested centre lines aren't useful, I was merely pointing out that  they weren't always standard fitments as the largely are today.
I first recall seeing one on a boat I hired in 1988.
Before thatif the boat I was hiring had raised hand rails (not integral handrails), I used the boathook hooked around the raised handrail to hold the boat whilst waiting at locks etc.
I must be getting old I had totally forgotten doing that.
Ah now that's interesting. Maybe the advent of solid handrails led to the need for centre lines.
The H&L boat I mentioned earlier in the thread had them newfgangled solid style handrails, hence the sidedeck bollards to tie some lines to.
Possibly, also around that time the average boat length began to increase from 35-45 foot to 50-60 foot  which may also have played a part.
On 23/09/2022 at 08:40, David Mack said:
If you want real disapproval, try single handing a motorised swing/lift bridge with a lengthening queue of traffic on both sides with drivers beaming hate at you, then going hard aground when the boat is half a length from the open bridge, and too far out from the side for you to be able to go ashore and close the bridge while you get unstuck!
Best I've managed so far is jogging back to the motorised bridge, pressing the button down so the bridge just started to move, then noticing that my loop had slipped off the bollard, and promptly abandoning the half open bridge to rescue the boat with a running jump
Although that got more laughter from the adjacent pub than motorist anger
The other day a woman at work said to me "I bet you're laughing now aren't you, living on your boat with this economic crisis starting while all of us are going to be in the shit?"
I just thought, why would I be laughing? I've still got bills to pay the same as you. Ok no mortgage payments but I've got mooring fees and river licence, and the latest I've heard is that my mains electricity at the mooring is going from 20p/kWh to £1.20/kWh from the end of October. At least households are protected by the energy cap. As someone living without proper residential status I don't benefit from that.
I'm just glad I've got no dependents. Imagine having a screaming wife and a couple of miserable unappreciative kids and you've got to pay for all their shit. No thanks.
Edited by blackrose
On 23/09/2022 at 13:21, agg221 said:
I am increasingly coming to the view that I would prefer guidance on passing moored boats to change.
On our last trip out over the August bank holiday weekend, (Venetian-Chester-Market Drayton) we noticed at lot of boats moored during the day at widely spaced intervals, often in ones or twos, but apart from Chester to Beeston there was barely a stretch with no boats moored boats in sight. Realistically, to make a difference to speed, we are slowing down a couple of hundred yards in advance, and then it takes another couple of hundred yards after passing before we are up to cruising speed. The impact on overall journey time was about 2hrs, which makes a difference.
I would like to see a definition of the canals as a transport network. If you want to moor up anywhere you like, that's great, but expect that other boats will be moving. We don't all slow to a crawl when passing a parked car, and the same applies if that's a motorhome parked in a layby. Perhaps there could be some reasonable exceptions to that - say the hours of 8pm to 8am it is expected that you will slow down, and maybe even create explicit 'slow down' zones for visitor moorings. Anywhere else and you could reasonably expect boats to be passing during the day at up to 4mph and if you are choosing not to move that day, you need to moor appropriately. If you really don't want the movement, perhaps you should take an offline mooring in a marina?
Contentious - definitely. Will it happen, no. However, it's a thought.
Alec
I'd be tempted by that too... for narrowboats. I'm not trying to bash widebeams, but I must say that when a 65x12 widebeam goes past at a normal cruising speed, especially in a fairly narrow section, the resulting displacement of water can be a challenge even for well-deployed mooring lines if the ground conditions for pinning are less than ideal.
