heating yet again
bigcol
Hi
I have a 57 x 10 ft boat and have a steel stove works a treat 10kw, saloon piping hot windows open etc
but really messy, dust everywhere and using it as our main stay of heating
we also have a webasto thermo top 5kw with
1 x 300x 1000 double in the bedroom cool
2 x 300 x 1000 double in the saloon turned off when stove on
1 x 500 700 double in the kitchen nr the wheel house cold
other side of wheel house bathroom freezing1 x 500 x 700 single will be changing to double soon
I m now thinking the 5 kw is not powerful enough as we are using the stove as our main heating source
when buying price orientated
so thinking of either installing a
1) domestic oil boiler which is a way to go for dutch bargees?
2) or go for the webasto 90 ?
any thoughts?
as I would like the diesel heating to be our main source of heating
and the fire stove to be in case
all the wife does is dust dust and more dusting
Question is
has any folks here installed a diesel domestic boiler on their narrow boat, It seems to be most favourable on a Dutch barge?
and any folks had experience of a 5 kw thermotop, and a webasto 90 are they a lot more powerful?
many thanks in advance
colin
Edited by bigcol
Colin,
We've a Webasto 90 -- - - though have to admit that we (very, very) rarely need to use it - but it certainly chucks out heat when it's on.
We use a solid fuel stove as our main heating - and burn anthracite and briquettes (sometimes a little timber) - but we have never suffered from it being dusty, or causing a mess of any type - - what is causing the dust for you??
[With regard to boilers - - all the boaters I've met that use Kabola boilers, hold them in very high esteem....]
If you're upgrading diesel heating on a barge I'd go for a drip-fed diesel heater like a Kubola rather than a bigger webasto. I've also seen a drip-fed diesel heater inside a stove that looked like Squirrel, but I'm not sure if it was a Squirrel? Anyway, it looked very good and the owner has been living with it for years very reliably, but like most high-output diesel heaters it was expensive to run.
Edited by blackrose
Colin,
i would say ashes from cleaning out a coal fire.
Bubble stove?
http://www.oilstoves.co.uk/appres.php?select=Stoves&select3=All&select2=Oil&select4=All&Submit=+++++Search+Shop+++++
pquinn yes your right,every time we get the poker out and have a ramage, putting more fuel in,and emptying the ash pan
and Bizzard we will give this ago, although we tried this when we first got the steel stove, and manage to set smoke alarms off
has anyone got a domestic oil central heating boiler installed,?
fuel consumption compared to a webasto?
Grace & favour, as you rarely use it , what's the chance of you selling me your webasto then??clapping.gif
col
Edited by bigcol
Hi,
We upgraded from a 5Kw Webasto to a 9Kw just over 5 years ago
The 5Kw was fitted from advice given by the then "marine" distributers
I had at the time stated that the unit would not provide enough heat for the
number and output of rads fitted (8 rads total approx10Kw)
5Kw unit as expected would not cope with its first winter use and was replaced with a Webasto 90
The 90 has been great and heats up the boat very quickly BUT uses around 1 litre of kerro per running hour
The unit is controlled by a room stat so it does not cycle down as it would if uncontrolled
The stat was installed following advice that Webasto heaters coke up if left running at the lower output
they cycle down to when the water temp reaches a certain level
Unit now run for 4500 hours
Regards Ray
Hi
any thoughts?
Question is
colin
Blimy Colin
A 10 KW stove? we have a 4kw Bubble stove that's mostly run on the lowest setting, we can heat our water with it too. Our boat is 60f x 10/6 and it's plenty warm enough, 10kw would literally roast us laugh.png
We've been tempted to go for an Eberspacher D4 as a back up but mainly as it's much more controlable. We find that even with the Bubble stove set on lowest the boat gets too hot so have to either switch off or waste heat by opening hatches, the eber would quickly and easily give you heat when required.
I really wonder about the quality of much of the boat insulation installed what with people seeming to need 5kw+ to heat even a n/b
When we were on dry land a 2kw electric fan heater heated the boat's main cabins sufficiently.
col
Sorry Col, the webasto's staying put (I'm a firm believer in covering options with system redundancy)(As I've mentioned to my present wife!!!)
But with regard to dust.........
However, simple as it may sound, our virtual dust suppression process works extremely well.....
We determined the two processes that caused dust were
1// Clearing the ash
2// Loading with new fuel
So we came up with two ways of avoiding dust:
Ash
I (had) fabricated a second ash can, and a caddy into which the (full) ash can would fit, and a lid that sits over the whole thing . . . so emptying the ash is now a process that goes:
Open bottom door, remove ash can into caddy - place lid on - put the spare ash can in the stove, close bottom door.
Take full caddy outside and leave it on the bankside to cool.
Coal
We open our bags of anthracite (25Kg) outside, and decant the contents into the very cheapest small binliner bags, each hold about 1 / 1.25Kg.
Knot each little bag.
We then keep a supply of these 'pre-packs' in the scuttle near the stove .
To load the stove , - open fire-door, put pre-pack in, close door.
Very simple - very clean
Edited by Grace & Favour
When I was working out how big a diesel fire I needed, I used the table supplied by Refleks. In your case, as a rough-back-of-an-envelope calculation, you need to heat 50’ x 10’ x 6’ = 3000 cu feet or about 85 cu meters. According to the table a 5KW heater will heat 83 cu.meters of an insulated boat and 50 cu.meters of an uninsulated boat. For a 7KW heater the figures are 117 and 70.
On these figures, I’m not surprised that the OP’s boat is a bit chilly when relying solely on the Webasto.
Edited by koukouvagia
Ash
Coal
thats a good idea.must try it myself.
this is also what i do.
eta.i also use an ash carrier.i dont know how people manage without them.
Edited by pquinn
Check the rads are balanced properly otherwise you won't get the expected output from the Webby.
Briefly when all rads are full on the temp of the pipe returning from the rad to boiler should be the same on each of them. Easily done with an IR thermometer or a Mk1 hand will get close enough with expericence.
5kW will do up to 19-24 ft2 area of double rad which is a fair bit, and 5kW of rads should heat the cabin areas alone fine if reasonably insulated and the windows are DG.
BUT 5kW isn't sufficient for cabin and wheelhouse year round, to heat a large single glazed wheelhouse to normal temps might need another 5kW when the weather is bitterly cold. ohmy.png
So depends if you want to use the wheelhouse as extra living space year round, or just stop using and heating it when the weather is cold.
Echo other comments about stove management, spare ash pan, check chimney and baffle plates in particular are clear. Running the stove hot before refueling may warm up the flue and get a better draw. If the fuel is really dusty maybe even consider spraying it with water to keep the dust down.
ETA with your doubles, do they have fins between the two layers or not? Ones without fins will give about 200W ft2, ones with about 250W ft2
cheers, Pete.
~smpt~
Edited by smileypete
Robo thanks for the link and Pete, I now know I have double rads with double fins.
say I didn't have the stove at all and just the webasto I think the main saloon will be warm but heat will be lossed through the bedroom. and in the depths of winter would not keep the boat warm, WE WOULD HAVE TO USE THE STOVE
But your right! the wheel house is single glazed, and have the stairs to forward (kitchen saloon and the bedroom),
but also stairs aft from the wheel house to the bathroom which is like a freezer
so yes we have to use the whole boat including the wheel house and of course bathroom.
We have got a door separating the main cabin from the wheel house and when shut, does keep in the heat. a lot more
but when the wheelhouse and bathroom is sealed of with the door and we want to pee etc its like having a outside loo!!! lol plus when we do shut this backend off the dogs keep whinging and whining wheelhouse is the fridge, then down to the bathroom freezer
I do like the idea of making ready coal bags for the stove,
Ray ! I haven't really thought about consumption as I didn't think my 5kw used much, but will have a look at the spec
buy you've spent if you have logged up 4500 litres thats £4500! on fuel.
saying that we need to be warm, and surely its force economy to run a underpowered heater
I have just looked in the ceiling void, yes its spay foam insulated but only just over a inch,?
I have come to the conclusion through this and dba forum, that I couldn't afford the consumption of a domestic oil boiler on the boat
2.7 plus litres per hour! how do folks in houses afford to run their heating!!
I'm thinking buy the wood and coal, open stove door very slowly, put pre packed bags in and buy my loving wife a new hoover and more dusters for xmas lol
Funny how I was all set up to buy a domestic boiler, through dba and this forum I'm now doing a u turn
but will look at a webasto 90, hopefully that will just replace the 5kw heater, and use the same wiring fittings and diesel supply?
Col
Blimy Colin
It's not the biggest stove of boat owners on this forum. I can't remember who it is but one forum member has a 20kW stove!
I replaced a 5Kw Ebersplutter with a 7Kw Hurricane. A simple job only needing room to put the larger heating unit in place. All of the piping remained the same except a bit of extending to reach the input/output points on the Hurricane.
The extra heat output is excellent, and the Hurricane doesn't mind turning on and off as often as needed.
The whole system is controlled by time and temperature, just like a "normal" house, it even has a hot water only valve so that the hot water is controlled even if the heating isn't needed.
Bob
By boat is 57 x 12 with a double glazed and insulated wheelhouse I have a wisphergen that produce 5kw it heats rads to 70 c it also produces 72 amps at 12v as well. My multifuel stove takes over from the wispergen when I get home from work it does room heat plus heats the rads It is dusty and labour intensive but I have a lot of free wood so I use it. In the bedroom I have a bubble stove It works well and in cold weather or if the boat has been unoccupied for a while I light it it is clean and quick. All of these work in tandem so maybe you just need to have a backboiler on your stove to help your diesel central heating like I have done?
Peter
Hi
any thoughts?
Question is
colin
I think I said on another thread that we have installed a harworth heating pressure jet boiler in Bison which is 70ft. The boiler is brilliant and runs on a standard domestic Y plan setup for heating and water. It is quiet and heats the boat up really quickly via 4 column radiators. The boat is based at kegworth and you would be welcome to have a look if interested. I have no connection to harworth but they did give excellent service. The whole setup is on 240v but it uses less power than my old Mikuni. 240 v circulating pump from Wilo is also really energy efficient.
PM me if you need any further info
Andrew
thanks for your posts Andrew I've Pmed you
and Bizzard were are being more careful and slower opening the door does make a big difference simples!
also looking at the stove woodburner hoovers any good?
But been looking at domestic boilers most of the week, and it seems that the consumption of domestic boiler heating fuel is a minimum of 2 litres per hour, pricing for domestic heating oil is 56p per litre,
This is a lot less than being 95p per litre for red diesel for marine boat use
Our boat has 2 x tanks which are 75x65x50 cm which in total for the 2 tanks is 290 litres? I think I worked this out right?
I'm coming to the conclusion that a domestic boiler will be expensive to run, especially on red diesel
Thinking I couldn't afford the domestic boilers consumption, I thought of exchanging my 5kw webasto for a 9kw webasto,
but unless someone tells me its a bad idea, I'm thinking of buying a 5kw air heater on top of the 5kw existing thermotop
and running this with outlets into the wheel house bathroom and kitchen.
this will mean I would have 3 options
for less money of exchanging existing webasto, I could have another webasto Air heater,ie heating the cold spots directly and instantly, and also if one breaks down I have another. yes I may have the usual reliability issues that go's with these units. but I will have 2 diesel heaters which mounts up to 10kw if used together which don't think will ever happen unless its freezing out there
I could then choose having the 1)messy option stove, and 2) the air heating, or air and 3)central heating,
For some reason I'm thinking that most folks are thinking I'm nuts, any thoughts
Col
Edited by bigcol
Ray !
Is this what other boaters do? and where can you buy kerosene, is this paraffin?
Am I right, its easy as putting the feed in a Gerry can of kerosene, I be nearly halving the cost of my heating fuel?
Is there boat safety rules for kerosene or insurance issues?
I'm going to do a search on the forum
many thanks Ray
col
Edited by bigcol
Ray !
many thanks Ray
col
We ran our bubble stove last year on Kerosene, or heating oil?. It's thinner than diesel 28 sec but burns much cleaner. When we originally added it there was a lot of Red Deisel already in the tank, but as we continued to add we had to slightly adjust the flame as the mix in the tank became neater. When the tank ran out we completely filled with Heating oil. It was 10p a litre cheaper than fully rebated Red at 72ppl when we last bought it locally in Feb 2012, delivered to our warehouse bunded tank in Dorset it was just 62ppl We quite often drained some of that off for our boat stove tanks, it's a lot of faffing around though.
I agree with Raymondh it does burn well and cleaner and the flame on the BBle stove was the best ever. I'm tempted to go to the local garage again and fill up 10l containers. It's only a mile away as well. Having Red delivered to the boat is great, but heating oil does burn much better in our Bubble and would be cheaper.
