comfortably numb Posted October 24, 2013 Report Share Posted October 24, 2013 I'm considering buying a wet vacuum for removing water from the bilge underneath the engine. My boat is a cruiser stern so collects quite a lot of rain water there. Not all of the water goes back to the part with the bilge pump so I'm looking for something that will suck out the remainder. I've used one of those 6 litre hand pump things but it's awkward and takes ages. Do any of you own/use them and can you recommend any please? Link to comment Share on other sites More sharing options...
FadeToScarlet Posted October 24, 2013 Report Share Posted October 24, 2013 If you can power it, a 'Charles' wet vac by Numatic. Bombproof, loads of spare parts available, and available cheaper from Screwfix occasionally on sale. Link to comment Share on other sites More sharing options...
Tesla Posted October 24, 2013 Report Share Posted October 24, 2013 Wicks do a cheapo one which works ok. Link to comment Share on other sites More sharing options...
George Kennedy Posted October 25, 2013 Report Share Posted October 25, 2013 I've had this one http://www.argos.co.uk/static/Product/partNumber/4062116.htm for about five years and it cost me £50 from Argos then. I bought it for exactly the same reason as you and it works a treat. The wheels are loose packed in the box for self assembly which is perfect because you should leave them off otherwise the vac has a tendency to roll around which is not good with the deck boards up!!! If memory serves me right, it has a 1200 watt motor. Link to comment Share on other sites More sharing options...
Barry Posted October 25, 2013 Report Share Posted October 25, 2013 I bought one from Wickes a couple of years ago to help dry out my carpets after a flood in my house three years ago. I see they have another model in their catalogue now at a good price I use mine a great deal at home. Its brilliant for clearing up after DIY, very powerful and lifts wood shavings, sawdust, small concrete debris etc which saves my domestic vacuum cleaner that I've ruined twice now. I also use it on my boat and my lady's for exactly the use you propose and it's great for that. For instance recently I've cleaned the bilges under the engines of both boats. In both cases I just poured a bag of cheapo cat litter beside the engine. worked it about with a handbrush, then sucked it all out again with the wet and dry vac. Sparkly clean and dry bilges. I've also, on both boats, and using the sponge wet filter, lifted inspection hatches and sucked the bilges dry. They are a great bit of kit Link to comment Share on other sites More sharing options...
Naughty Cal Posted October 25, 2013 Report Share Posted October 25, 2013 We have a Vax which works fine. We use it loads at home and on the boat for cleaning upholstery and carpets and sucking out bilge water. Link to comment Share on other sites More sharing options...
Pykebird Posted October 25, 2013 Report Share Posted October 25, 2013 After a huge panic last week end I had to replace my wickes,wet and dry. These are the only ones I have used, the last one has lasted me for over 5 years and boy do they get some stick! Not only have I done my bilges, but it has also been used in the yard on several boats that have sunk, (oil and diesel,yuk) not forgetting the mountain of inuit hair, which I could probably knit a new dog from! Now there's an idea...... Link to comment Share on other sites More sharing options...
AndrewIC Posted October 25, 2013 Report Share Posted October 25, 2013 I have an ancient Earlex one, almost all plastic so no rust problems so far. 1000W motor. Made some adapters from standard plumbing bits to take a thin hose or a piece of 15mm water pipe, works a treat. Link to comment Share on other sites More sharing options...
Psycloud Posted October 25, 2013 Report Share Posted October 25, 2013 If you can power it, a 'Charles' wet vac by Numatic. Bombproof, loads of spare parts available, and available cheaper from Screwfix occasionally on sale. We have one of these - I use it all the time to suck out the bilge (usually after I've filled it with water after plumbing). Got ours for £99 in a recetn promotion but think they are now £129. Link to comment Share on other sites More sharing options...
Tim Lewis Posted October 25, 2013 Report Share Posted October 25, 2013 Wicks do a cheapo one which works ok. I also use the cheap (£40) Wickes one which does a really good job. I do recall though that it did say in the very brief instruction booklet that it shouldn't be used in boat bilges! Tim Link to comment Share on other sites More sharing options...
Biggles Posted October 25, 2013 Report Share Posted October 25, 2013 We have a George on the boat. Its a wet vac and carpet cleaner. I use it mostly for wet work and clearing up DIY debris and leaves in the deck drains. Link to comment Share on other sites More sharing options...
blackrose Posted October 25, 2013 Report Share Posted October 25, 2013 You dont need to spend more than about 50 quid for a wet vac that will do the job, and theres not much point spending more if its going to be contaminated with oily water from the start. I bought a 1250 watt model from Argos similar to this a couple of years ago and its very powerful. Argos also have a Karcher for about the same price. http://www.argos.co.uk/static/Product/partNumber/7113873.htm Link to comment Share on other sites More sharing options...
Barry Posted October 25, 2013 Report Share Posted October 25, 2013 That looks very like what Wickes are selling for a tenner less Link to comment Share on other sites More sharing options...
Bimbly1 Posted October 25, 2013 Report Share Posted October 25, 2013 I have had a Draper like this http://www.drapertools.com/b2c/b2citmdsp.pgm?pp_skmno=06489&ipadd= for several years. Still works well and lives in the engine 'ole. Link to comment Share on other sites More sharing options...
Rebotco Posted October 25, 2013 Report Share Posted October 25, 2013 We're not on shore power and have only a 1200 Watt inverter, so choice was severely restricted. In the end bought one of these for under £40 cos its only 1000 Watt and all plastic. We've found it ideal for the bilges as well as more usual vacuuming the boat. http://www.coopersofstortford.co.uk/coopers-of-stortford-the-beast-professional-vacuum-cleaner-prodst09078i/ Link to comment Share on other sites More sharing options...
smileypete Posted October 25, 2013 Report Share Posted October 25, 2013 (edited) Got an Earlex myself, works very well, UK made and good spares availability: http://www.tlc-direct.co.uk/Products/EXWD1000.html Cost a bit more than the china sourced jobs, but sometimes come up for less on Ebay for an 'open box', or £20ish used if someone local is selling. http://www.ebay.co.uk/itm/EARLEX-WD1000-WET-DRY-COMBIVAC-1000W-1-8M-HOSE-12L-WET-CAPACITY-DAMAGED-BOX-/400582642881 If going for a Numatic 'Charles', consider spending a bit more for a 'George' if you have carpets that can be cleaned with it. There are also 12V wet or dry vacs, maybe they could be grafted onto some sort of bigger canister or have some sort of ingenious automatic drain fitted. THAT REMINDS ME, if you have a gulper near the back of the boat consider putting a valve or two and a hose to the bilge so it can be used to suck water out of the bilge instead. If the gulper is below shower tray level it might not even need a valve, just a tee and a hose that goes right up then back down again before going to the bilge. cheers, Pete. ~smpt~ Edited October 25, 2013 by smileypete Link to comment Share on other sites More sharing options...
bag 'o' bones Posted October 25, 2013 Report Share Posted October 25, 2013 I bought one from Wickes a couple of years ago to help dry out my carpets after a flood in my house three years ago. I see they have another model in their catalogue now at a good price snip Don't bother, the new model is hopeless. We bought one for clearing up during a house refurb the supplied filter sock blocks up far to easily and an absolute bitch to remove for cleaning . The wet and dry filer is an optional extra which we were not prepared to waste more money on! The Karcher 2100 is a good basic wet and dry. Its no longer available but newer models use the same type of filter like this one: http://www.ebay.co.uk/itm/KARCHER-Cartridge-Filter-Wet-Dry-Vacuums-A-2100-and-A-2199-Machines-6414552-/121198608110?pt=UK_Vacuum_Cleaner_Bags_Parts&hash=item1c37fffeee They are technically disposable but you can clean them under the tap for re-use. Link to comment Share on other sites More sharing options...
comfortably numb Posted October 25, 2013 Author Report Share Posted October 25, 2013 Many thanks boys and girls. As usual a fantastic response. I will have a ponder and let you know what I opt for. Having spent a load of dosh on the boat recently and with more to come, I will probably opt for one of the cheaper ones. Link to comment Share on other sites More sharing options...
frangar Posted October 26, 2013 Report Share Posted October 26, 2013 We have a machine mart stainless bodied one that I haven't killed yet! Seems to work well. If you register for the email club then you get "vat off" days a few times a year which is a handy saving Cheers Gareth Link to comment Share on other sites More sharing options...
mrsmelly Posted October 26, 2013 Report Share Posted October 26, 2013 Many thanks boys and girls. As usual a fantastic response. I will have a ponder and let you know what I opt for. Having spent a load of dosh on the boat recently and with more to come, I will probably opt for one of the cheaper ones. Hi Just a thought but you say " My boat is a cruiser stern so collects lots of water " as though thats a given fact. I agree that many cruiser sterns take in water but have you tried modifications to stop the water getting in? My boat is a cruiser stern but designed correctly so water does not get in, perhaps its possible on yours? Tim Link to comment Share on other sites More sharing options...
smileypete Posted October 26, 2013 Report Share Posted October 26, 2013 Don't bother, the new model is hopeless. We bought one for clearing up during a house refurb the supplied filter sock blocks up far to easily and an absolute bitch to remove for cleaning . The wet and dry filer is an optional extra which we were not prepared to waste more money on! Wickes used to sell a rebadged Earlex but doesn't any longer. cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
davidc Posted October 26, 2013 Report Share Posted October 26, 2013 just bought a Titan 16 litre from screwfix 49.99 I also have vacs my bilge's as I have also a cruiser stern no problem at all, it also has a blower connection Link to comment Share on other sites More sharing options...
comfortably numb Posted October 28, 2013 Author Report Share Posted October 28, 2013 I ended up buying the Titan (from Screwfix). I've tried it out and it does the job well. Not sure about its longevity though as it isn't as robust as some of the more expensive ones but so long as I take care of it hopefully it will last. It's not as if I'm going to be using it every day. Thanks again for all your help. Link to comment Share on other sites More sharing options...
John V Posted November 1, 2013 Report Share Posted November 1, 2013 (edited) Have got a Wickes elcheapo which has been in constant use for many years now and it refuses to die. It has been filled with rusty water so many times that the "I'm full" valve sometimes jams and water has been seen pouring out the motor vent holes. It now looks so disgusting I have to keep it hidden and only bring it out in the dark Edited November 1, 2013 by John V Link to comment Share on other sites More sharing options...
