RLWP Posted September 21, 2016 Report Share Posted September 21, 2016 I quite like the challenge of the latter plus a bit of metalwork Yes, so do I There are also flush mounted sockets with USB cables and plugs on the end that you can just plug into the second ones. They are quite expensive compared to the others though Richard Link to comment Share on other sites More sharing options...
Naughty Cal Posted September 21, 2016 Report Share Posted September 21, 2016 The prices are staggering, given it will actually contain no more electronics than the equivalent item that can be plugged into a car lighter type socket. I fully understand why this is a neater and better solution, but given you can buy the electronics for under a quid, an extra £24 for what it is mounted in seems excessive! As has been pointed out elsewhere, if it is permanently illuminated if powered, it probably needs a switch in line as well, making it yet more expensive, and not quite the compact tidy solution it initially looks. We didn't pay anything like that for them. From memory they were 3 or 4 pound each the ones we bought. They have been installed a while now and perform as expected. No problems from the at all. Link to comment Share on other sites More sharing options...
TheBiscuits Posted September 21, 2016 Report Share Posted September 21, 2016 But are not all usb sockets 5V which is needed for iPhones Everything you wanted to know about charging your iPhone or iPad Source Voltage Current PC USB 5 volts 0.5 amps iPhone Charger 5 volts 1.0 amps iPad Charger 5.1 volts 2.1 amps Note that the good vehicle ones will take between 10V and 30V or 40V and give out a regulated 5V, usually at 1A and 2.1A The socket itself has the circuit built into it - you do not need to feed it 5V. Link to comment Share on other sites More sharing options...
pearley Posted September 21, 2016 Report Share Posted September 21, 2016 This is what we used: https://www.duriteparts.com/durite_0-601-08_usb_two_port_socket_12_volt?gclid=CjwKEAjw34i_BRDH9fbylbDJw1gSJAAvIFqUTgNvGmU8JIPap7vxxTVgZOJrWlGi20dG7clG4RF6ZxoCkrXw_wcB They also do a mount if you wish to mount them under the gunnels. Link to comment Share on other sites More sharing options...
john6767 Posted September 21, 2016 Report Share Posted September 21, 2016 We didn't pay anything like that for them. From memory they were 3 or 4 pound each the ones we bought. They have been installed a while now and perform as expected. No problems from the at all. Yep you don't need to pay that sort of price. This is what I fitted earlier in the year, although I did add a small switch to it so the USB sockets are not permanently powered. http://www.ebay.co.uk/itm/12V-Car-Boat-Dual-Caravan-USB-Cigarette-Lighter-Socket-Splitter-Charger-Adapter-/281944555678?hash=item41a534809e Link to comment Share on other sites More sharing options...
Naughty Cal Posted September 21, 2016 Report Share Posted September 21, 2016 Yep you don't need to pay that sort of price. This is what I fitted earlier in the year, although I did add a small switch to it so the USB sockets are not permanently powered. http://www.ebay.co.uk/itm/12V-Car-Boat-Dual-Caravan-USB-Cigarette-Lighter-Socket-Splitter-Charger-Adapter-/281944555678?hash=item41a534809e Our two in the cockpit are powered through the VHF radio circuit so can be switched off. The one in the cabin isn't switched. But for what little power it uses keeping a small LED lit it isn't worth worrying about. Link to comment Share on other sites More sharing options...
ditchcrawler Posted September 21, 2016 Report Share Posted September 21, 2016 We didn't pay anything like that for them. From memory they were 3 or 4 pound each the ones we bought. They have been installed a while now and perform as expected. No problems from the at all. These are what you linked to when you posted after fitting them, I did link it earlier http://www.seascrew.com/browse.cfm?s=1451601 Link to comment Share on other sites More sharing options...
Naughty Cal Posted September 21, 2016 Report Share Posted September 21, 2016 These are what you linked to when you posted after fitting them, I did link it earlier http://www.seascrew.com/browse.cfm?s=1451601 They came off Ebay ours but are essentially the same as that one. Link to comment Share on other sites More sharing options...
Gordon Munk Posted September 21, 2016 Report Share Posted September 21, 2016 I'm pondering this very issue at the moment These are cheap: http://www.ebay.co.uk/itm/131825300999?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT This might be better: http://www.ebay.co.uk/itm/DC-DC-12V-to-5V-3A-15W-Dual-Female-Panel-Mount-USB-Step-Down-Power-Supply-Module/291485627554?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D39219%26meid%3Df918b0ed949f4544bd7a049182ea82d0%26pid%3D100011%26rk%3D1%26rkt%3D5%26sd%3D182252007302 Richard The first would involve a whole load more faff. The 2nd is great, I have one, it doesn't charge my iPad or iPhone 5 but I have heard they work for others. Link to comment Share on other sites More sharing options...
RLWP Posted September 21, 2016 Report Share Posted September 21, 2016 The first would involve a whole load more faff. The 2nd is great, I have one, it doesn't charge my iPad or iPhone 5 but I have heard they work for others. Yes, the first one would need wiring into a USB socket, which is a bit of a faff. Good to hear about the second one Richard Link to comment Share on other sites More sharing options...
Paul C Posted September 21, 2016 Report Share Posted September 21, 2016 Its more that the LEDs are piercingly bright at night time, than the worry of power draw. When I installed mine (4x), I put it through a spare circuit on the circuit breaker board so its possible to turn them off if needs be. But since the idea was they stayed on through the night (charge phone at night....) I angled them away so the LED wasn't too bad. I suppose you could snip it off or put a piece of tape over it if you wanted complete blackout conditions. Link to comment Share on other sites More sharing options...
Naughty Cal Posted September 21, 2016 Report Share Posted September 21, 2016 Its more that the LEDs are piercingly bright at night time, than the worry of power draw. When I installed mine (4x), I put it through a spare circuit on the circuit breaker board so its possible to turn them off if needs be. But since the idea was they stayed on through the night (charge phone at night....) I angled them away so the LED wasn't too bad. I suppose you could snip it off or put a piece of tape over it if you wanted complete blackout conditions. We cant see ours at night with where they are located. We also tend to charge our phones overnight. Link to comment Share on other sites More sharing options...
rustydiver Posted September 21, 2016 Author Report Share Posted September 21, 2016 (edited) Thanks I've bought one off the round ones to try ill wire it inside the cupboard to hide it. To try it out. O tend to charge mine at night. I've got a spare 12v cable in the front cupboard where the auto tracking satellite dish wires are which I don't use. Edited September 21, 2016 by rustydiver Link to comment Share on other sites More sharing options...
WotEver Posted September 21, 2016 Report Share Posted September 21, 2016 As long as they're big enough to supply a couple of amps with negligible voltage drop they'll be fine. Considering their intended use they should be. Link to comment Share on other sites More sharing options...
rustydiver Posted September 21, 2016 Author Report Share Posted September 21, 2016 Just noticed one is 2.1a which should be fine for the phone ? the other us 1a which will be fine to change my ⌚️. Didn't cost much so not a lot lost but I'm always wary off buying stuff off eBay these days. Link to comment Share on other sites More sharing options...
ditchcrawler Posted September 21, 2016 Report Share Posted September 21, 2016 As long as they're big enough to supply a couple of amps with negligible voltage drop they'll be fine. Considering their intended use they should be. What would happen if say there was only 10 volts on the input do you think? Link to comment Share on other sites More sharing options...
TheBiscuits Posted September 21, 2016 Report Share Posted September 21, 2016 What would happen if say there was only 10 volts on the input do you think? It would draw a little more current, and still output 5V if it was a regulated one. Your batteries on the other hand might need replacing! Link to comment Share on other sites More sharing options...
Paul C Posted September 21, 2016 Report Share Posted September 21, 2016 What would happen if say there was only 10 volts on the input do you think? Its pretty obvious.....at 10V it would still charge the phone up. The danger is when it goes below 5V, then the phone will start charging the boat batteries up!!! Link to comment Share on other sites More sharing options...
Phil Ambrose Posted September 21, 2016 Report Share Posted September 21, 2016 I fitted a couple of USB charging sockets last year for phones, kindles, tablets etc. Got mine from Vehicle Wiring Products, they work really well. They e-mailed me a PDF file of the full spec and dimensions before I bought them so I could check them out. Phil Link to comment Share on other sites More sharing options...
WotEver Posted September 21, 2016 Report Share Posted September 21, 2016 What would happen if say there was only 10 volts on the input do you think? I'm unsure. The specs generally state 12-30V so the regulation could be a bit iffy below 12V. It's unlikely to do any harm but it could be that they'd deliver less than 5.0V. Tony Its pretty obvious.....at 10V it would still charge the phone up. The danger is when it goes below 5V, then the phone will start charging the boat batteries up!!! So how long will my iPhone power my fridge? Link to comment Share on other sites More sharing options...
Paul C Posted September 21, 2016 Report Share Posted September 21, 2016 So how long will my iPhone power my fridge? It depends if the fridge interior light stays on when the door is closed - can you nip and check? Link to comment Share on other sites More sharing options...
matty40s Posted September 21, 2016 Report Share Posted September 21, 2016 It depends if the fridge interior light stays on when the door is closed - can you nip and check? You can get an App for it from the Apple store. Link to comment Share on other sites More sharing options...
