Tesla Posted April 5, 2014 Report Share Posted April 5, 2014 Dear all, Please note that we have installed a new feature today called Member Map. Available to members only, it allows you to set, update or delete you location, manually or using location based info. If you are concerned about broadcasting your exact location then it is best to set it manually and be as vague as you like. If you post your location it will also be shown under your profile. Please note that there is an issue with the mobile version at this point so you will not be able to access this festure unless you are accessing the full site. Hopefully it will be the inspiration for many mini banters.... Please find the app here or on the tab at the top of each page. Bernie Link to comment Share on other sites More sharing options...
Barry Posted April 5, 2014 Report Share Posted April 5, 2014 Sounds like a very fine idea Link to comment Share on other sites More sharing options...
Jo_ Posted April 5, 2014 Report Share Posted April 5, 2014 I'm in! Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2014 Report Share Posted April 5, 2014 (edited) Dear all, Please note that we have installed a new feature today called Member Map. Available to members only, it allows you to set, update or delete you location, manually or using location based info. If you are concerned about broadcasting your exact location then it is best to set it manually and be as vague as you like. If you post your location it will also be shown under your profile. Please note that there is an issue with the mobile version at this point so you will not be able to access this festure unless you are accessing the full site. Hopefully it will be the inspiration for many mini banters.... Bernie ???? We are already able to set a location under our profile, how is different and where is this feature accessed? Ed ah right, I see the new tab now. Edited April 5, 2014 by The Dog House Link to comment Share on other sites More sharing options...
Tesla Posted April 5, 2014 Author Report Share Posted April 5, 2014 UPDATE: mobile version now working also...BEER TIME... Link to comment Share on other sites More sharing options...
MtB Posted April 5, 2014 Report Share Posted April 5, 2014 Right, I've confused it by trying to enter my two boat locations! It ignored the second place name I gave it... MTB Link to comment Share on other sites More sharing options...
bigshorty Posted April 5, 2014 Report Share Posted April 5, 2014 I'm in Link to comment Share on other sites More sharing options...
DHutch Posted April 5, 2014 Report Share Posted April 5, 2014 We are already able to set a location under our profile, how is different and where is this feature accessed? There is a map.... Right, I've confused it by trying to enter my two boat locations! It can only handle, in current form, a single location. Although should be the last location added/updated. Daniel Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2014 Report Share Posted April 5, 2014 Right, I've confused it by trying to enter my two boat locations! It ignored the second place name I gave it... MTB Well I would say that is because you can only input one location. And the intended use is to show your personal location not the location of your boats(s)......but you knew this right? Link to comment Share on other sites More sharing options...
cloggy Posted April 5, 2014 Report Share Posted April 5, 2014 Fab idea Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2014 Report Share Posted April 5, 2014 There is a map.... Yes, see my edit, I,d actually sussed it thanks. Link to comment Share on other sites More sharing options...
Tesla Posted April 5, 2014 Author Report Share Posted April 5, 2014 Right, I've confused it by trying to enter my two boat locations! It ignored the second place name I gave it... MTB Now you're just showing off... Link to comment Share on other sites More sharing options...
Scholar Gypsy Posted April 5, 2014 Report Share Posted April 5, 2014 Very neat. When I entered "Braunston" it picked the one in Leicester, but "Braunston, Northants" did the trick! Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2014 Report Share Posted April 5, 2014 Be aware that if you enter a postcode it does as expected give a very precise location, it's very accurate. Link to comment Share on other sites More sharing options...
DHutch Posted April 5, 2014 Report Share Posted April 5, 2014 Be aware that if you enter a postcode it does as expected give a very precise location, it's very accurate. Yes, it uses the full detail you give it. If you want to use a postcode without detailing it down to your exact screen, use only the first half of the postcode. Daniel Link to comment Share on other sites More sharing options...
Burgiesburnin Posted April 5, 2014 Report Share Posted April 5, 2014 And it works for the former colonies as well. Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2014 Report Share Posted April 5, 2014 And it works for the former colonies as well. Indeed, I was trying to work out why the map was defaulting to encompass half the globe then it became obvious. Link to comment Share on other sites More sharing options...
DHutch Posted April 5, 2014 Report Share Posted April 5, 2014 Yeah, sorry about that... I'll be back on friday! Link to comment Share on other sites More sharing options...
Barry Posted April 5, 2014 Report Share Posted April 5, 2014 That's cool. I like playing with that map Link to comment Share on other sites More sharing options...
cheshire~rose Posted April 5, 2014 Report Share Posted April 5, 2014 Be aware that if you enter a postcode it does as expected give a very precise location, it's very accurate. But what is Postcode enters his postcode - does that make two locations and will it confuse it? Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2014 Report Share Posted April 5, 2014 What is mrs tawny owl up to in the states? Link to comment Share on other sites More sharing options...
Nightwatch Posted April 5, 2014 Report Share Posted April 5, 2014 If I say I'm at home, which I may be, but I may not be, someone will know know I'm not at the boat, if I'm at home. Martyn Link to comment Share on other sites More sharing options...
Paul's Nulife4-2 Posted April 5, 2014 Report Share Posted April 5, 2014 (edited) Hey Brilliant,I'm in However it's put me in the town center, not on the River. Shame we can't enter Chart or Map Reference !. Don't know the Post Code on the River, Eateries or the Sea. Still at least I'm closer to the shops ! Edited April 5, 2014 by Paul's Nulife4-2 Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2014 Report Share Posted April 5, 2014 Worth noting that if somebody you have added as a forum friend adds their location you get a notification... Link to comment Share on other sites More sharing options...
nicknorman Posted April 5, 2014 Report Share Posted April 5, 2014 Hey, that's really good! Link to comment Share on other sites More sharing options...
