Captain Fizz Posted January 5, 2014 Report Share Posted January 5, 2014 If a mobile tank cleaning and fuel polishing service were available at a sensible price, who would consider using it? It is a service which I have been considering for some time and would appreciate some feedback. Link to comment Share on other sites More sharing options...
peterboat Posted January 5, 2014 Report Share Posted January 5, 2014 To be honest more than likely although I do have a turnover of fuel all year round as my wispergen runs on the main tank or front tank and tunover of fuel is one way to keeping the bug at bay Peter Link to comment Share on other sites More sharing options...
Quinafloat Posted January 5, 2014 Report Share Posted January 5, 2014 Personally I would be more interested if it was static. I would be quite happy to cruise to it and it should, in theory, make it cheaper as you would have less travelling time. It could also then be combined with other services such as anti freeze replacement and any other "do it every few years" type services if that is of interest to you. Link to comment Share on other sites More sharing options...
Grace and Favour Posted January 5, 2014 Report Share Posted January 5, 2014 If a mobile tank cleaning and fuel polishing service were available at a sensible price, who would consider using it? It is a service which I have been considering for some time and would appreciate some feedback. You may also like to ask the question of all the boatyards/marinas/hire companies in your proposed area - you may well find that you'll get most of your business from them Link to comment Share on other sites More sharing options...
Mike Tee Posted January 5, 2014 Report Share Posted January 5, 2014 A friend of mine just had his done by a mobile service, cost I think around £100. They got a large amount of crud out of the tank, and spent quite a while pumping the fuel round to make sure it was fully 'polished' (their word for filtered!). I'm considering getting mine done in the spring as the boat is over 20 years old, and I'm sure the tank has never been cleaned. I don't do a lot of winter cruising so the fuel does sit for long periods. At about £100 I think it is worth it after 20+ years just for peace of mind. Link to comment Share on other sites More sharing options...
junior Posted January 5, 2014 Report Share Posted January 5, 2014 I'm not fussed about fuel polishing as a preventative measure, I'll take my chances. But I'd snap your arm off and pay you a lot of money if you can clean out my fuel tanks! If a mobile tank cleaning Can I ask how you'd be cleaning the tank? Link to comment Share on other sites More sharing options...
Captain Fizz Posted January 5, 2014 Author Report Share Posted January 5, 2014 Junior, if the tank is heavily contaminated with debris, I use a compressed air lance to lift the debris into suspension and then filter the resulting mix enough times to clear it. Link to comment Share on other sites More sharing options...
Chop! Posted January 5, 2014 Report Share Posted January 5, 2014 (edited) If a mobile tank cleaning and fuel polishing service were available at a sensible price, who would consider using it? It is a service which I have been considering for some time and would appreciate some feedback. We broke down numerous times, suffering a nasty case of diesel bug/ crap in the tank, lift pump and filters, after several strip downs, filters and bleedings we took CRC's advise and used a diesel polishing service that they said we would be "Pleasantly surprised, as it would only cost around £100" We had about 75 litres left in the tank, it did cost £100 plus an additional £90 for polishing filters. The boat carried on breaking down after that and we ended up disconnecting the fuel tank and running from 5 gallon containers. It would have been a lot cheaper and better to pump the diesel out and throw it away. We have now cut a hole in the top of our diesel tank and fitted an inspection cover, we will empty the tank, jet wash it and clean it out at regular intervals from now on. Sorry if this is not what you want to hear. Edited January 5, 2014 by Chop! Link to comment Share on other sites More sharing options...
Captain Fizz Posted January 6, 2014 Author Report Share Posted January 6, 2014 Hi Chop, Yes, you do have to assess the condition of the fuel and tank. There will be times when the condition of a tank may be so bad that normal filtering will not be cost effective. I always take at least two samples before starting, one from halfway down the tank and the other from the bottom. If there is a lot of water/sludge at the bottom, I pump that out to waste first. £90 for filters does seem excessive, do you know how many were used? Link to comment Share on other sites More sharing options...
CygnusV Posted January 6, 2014 Report Share Posted January 6, 2014 (edited) We had a serious problem 2 years ago in our twin (interconnected) X32 gallon 60 year old tanks. The tank cleaning guys that did the job took around 5 hours and removed a load of water and cr*p. Shortly after having this done we had the BSC man (Nigel, a member here) come visit and I asked him about the Perkins water filter I'd had for some time. He said it was fine to install it outside the engine room, so I did. We are regularly draining a half inch of water out of it. At least we can see the water in the filter and it isn't getting into the injector pump.... Result! Just seen Captain Fizzes post about the cost of the filters - They are massive things so I'm not that surprised at the cost Edited January 6, 2014 by CygnusV Link to comment Share on other sites More sharing options...
Mike Tee Posted January 6, 2014 Report Share Posted January 6, 2014 I'm not fussed about fuel polishing as a preventative measure, I'll take my chances. But I'd snap your arm off and pay you a lot of money if you can clean out my fuel tanks! Thats what they do when 'polishing' Link to comment Share on other sites More sharing options...
Captain Fizz Posted January 6, 2014 Author Report Share Posted January 6, 2014 I would be interested to know what people would consider a reasonable charge for cleaning a fuel tank. Link to comment Share on other sites More sharing options...
Willber G Posted January 7, 2014 Report Share Posted January 7, 2014 I would be interested to know what people would consider a reasonable charge for cleaning a fuel tank. How long would it take and how difficult a DIY job is it? Link to comment Share on other sites More sharing options...
GeoffS Posted January 7, 2014 Report Share Posted January 7, 2014 I used an oil extractor pump and successfully got several litres of water and crud from the bottom of a 15 year old tank. Link to comment Share on other sites More sharing options...
junior Posted January 7, 2014 Report Share Posted January 7, 2014 Thats what they do when 'polishing' Are you sure? I've been told several times that fuel polishing is just the fuel not the tanks, and if I want my tanks cleaning out I need to cut a hole in the top of them for access. Link to comment Share on other sites More sharing options...
Captain Fizz Posted January 7, 2014 Author Report Share Posted January 7, 2014 OK, Here is the method that I use. First I test the contents of the tank by drawing samples from the bottom of the tank and halfway up. Depending on what is found will drive what happens next. If there are signs of diesel bug, I add biocide to the tank which kills the growth and strips the slime from the sides. This is left for 24 hours. If the tank contains a lot of water, I pump this out without filtering and store for disposal. I then introduce a flexible lance and jet the bottom of the tank to lift any debris/slime into suspension. The fuel/debris mix is then passed through the filter plant at least twice to clean it, removing any remaining water at the same time. If the condition of the tank is very dirty, I recommend pumping out most of the fuel before agitating the remainder and pumping it to waste. This saves the expense of using too many filters. The net result is clean fuel and a clean tank without having to cut holes in the tank. Link to comment Share on other sites More sharing options...
Mike Tee Posted January 7, 2014 Report Share Posted January 7, 2014 Are you sure? I've been told several times that fuel polishing is just the fuel not the tanks, and if I want my tanks cleaning out I need to cut a hole in the top of them for access. Thats what my mate had done. As Fizz says (in detail post #16), basically they stir up all the crud into the tanks contents, suck it all out and filter it. He had other engine work done at the same time, but was told it was around the £100 mark for that in particular. To answer Fizz's question, £100 seems reasonable. Link to comment Share on other sites More sharing options...
Willber G Posted January 7, 2014 Report Share Posted January 7, 2014 I agree £100 seems reasonable and I would be interested in having it done. Link to comment Share on other sites More sharing options...
pearley Posted January 7, 2014 Report Share Posted January 7, 2014 So how far is Fizz prepared to travel? Link to comment Share on other sites More sharing options...
ditchcrawler Posted January 7, 2014 Report Share Posted January 7, 2014 I was just reading this blog http://contentedsouls.blogspot.co.uk/2013/10/diesel-bugfuel-contamination.html Link to comment Share on other sites More sharing options...
junior Posted January 7, 2014 Report Share Posted January 7, 2014 I would pay £100 to have my tanks cleaned. Link to comment Share on other sites More sharing options...
Willber G Posted January 8, 2014 Report Share Posted January 8, 2014 Hey, Fizz, have you given up on this thread? Link to comment Share on other sites More sharing options...
Captain Fizz Posted January 8, 2014 Author Report Share Posted January 8, 2014 Not at all old chap. I am currently finalising some details re a permanent location for operation and working out pricing for a mobile service. Hoping to have further news early next week. I also hope to carry a system on the boat. Link to comment Share on other sites More sharing options...
Willber G Posted January 8, 2014 Report Share Posted January 8, 2014 Sounds good, seems like a few people will be interested. Link to comment Share on other sites More sharing options...
mango Posted January 9, 2014 Report Share Posted January 9, 2014 A fuel tank should have a sloping base so that any water and debris can be drained off periodically from the lowest point. The fuel filler and vent should be designed and sited to prevent ingress of water. I have seen a boat where water shot out of the rudder bearing when in reverse, and straight onto the fuel tank vent. Water separators might help to prevent water getting into the fuel pump and injectors, but if there is enough water in the tank for it to reach the separator, there is probably a lot more at the bottom of the tank, with severe risk of diesel bug. There would be no need for fuel polishing if boats were better designed and fuel tanks maintained properly. Link to comment Share on other sites More sharing options...
