dixi188
Content Count
58 -
Community Reputation
5 NeutralAbout dixi188
- Birthday 08/20/1953
Gender
Location
Dorset
Previous Fields
Occupation
Aircraft Engineer (retired)
Boat Name
Steelaway
Boat Location
South Oxford canal
942 profile views
dixi188 started following Barrus Shire 45 max revs, Home location painted on boat, Wood burners are potential killers scientists report. and 1 other
My boat has Sheffield on the side as that is where the first owner was from. The boat was built in Chesterfield. I do get people thinking I must be from Yorkshire rather than Dorset. The boat lives in Warwickshire, so should I paint that on the side?
dixi188 replied to Alan de Enfield's topic in General Boating
Why would you taste Ad Blue? -
Went up last year with a lot of water coming down, the week before the flood. To get the bottom lock open we did as Tracy D'arth says. open all four paddles until the pound above is a good few inches below the top of the gate then close the top paddles to empty the lock. A few years earlier some lads at the pub were jeering as we tried to open the bottom gate so I roped them in to help. Problem solved.
My 57ft. boat has a Barrus Shire 45. Max revs in gear is 2100 so it may over propped. When it was built the then owner had the prop changed to a coarser one as he said it needed too many revs to go at normal speed. Tick over is 800 rpm, Narrow/shallow canal I use about 1200 to 1300 rpm and 1400 on the deeper and wider canals. I have been flat out on the Thames going upstream on a wide straight bit above Reading. After about a minute I had three bow waves and was putting up quite a wash at the bank so I slowed down. I don't know how fast we were going, but I would guess ab
Do you keep your fenders down in canal locks?
dixi188 replied to Rambling Boater's topic in General Boating
I assume the reason a few people leave the fenders down is to try to stop the blacking on the rubbing strip from being scratched, If you don't want your boat scratched, leave it in the marina! It's called a rubbing strip for a reason. I was delayed on the Napton flight in early August due a wedged boat. Lock 10 I think. -
Last week I had someone ask the time. I replied "August"! (I don't wear a watch and there isn't a clock visible from the aft deck).
My view has always been "If you don't want to scratch the paint, don't leave the marina".
Fenders are for mooring only. Saw a boat stuck on Napton flight a few weeks ago when his small fenders jammed when leaving a lock. He had to cut them away.
Going down Napton last week, I got held up by someone who got stuck coming out of lock 10 or 11. They had left their quite small fenders out and jammed part way out of the lower gates. Couldn't go forwards or backwards. Ended up cutting the fenders away and rolling them out. It was a standard modern narrow boat so I guess 6ft 10 ins wide.
Had to drop the anchor on the Severn, somewhere below Worcester, a couple of years ago when the engine on the hire boat overheated. I was the assumed "expert" as I have my own boat. Another crew member threw the anchor into the water while I attended to the engine. After a while I noticed we were moving downstream. He had dropped the anchor until it touched the bottom and tied the warp off at that length so the anchor couldn't bite. Fortunately the river was low and after about 30 mins we were on our way again. An anchor has to lay on the bottom and if it has a good few me
A few years ago I was held up at Bedwyn due to the big stone that one of the lock gates attaches to coming loose. The CaRT guys worked all day to fix it and then it had to be left 24 hrs for the concrete to go off before it could be used. Maybe tomorrow.
Ah! Now I understand, had me foxed for a while. Inflammable Material? On a plane? Yes lots. up to 62.900 ltrs of jet fuel on the last aircraft I was Flight Engineer on. We used to carry a lot of "Dangerous Goods" that was prohibited on passenger aircraft. Radio Active isotopes for X-ray machines and cancer treatment was one of the most common items. Max 200 Rems. (load it down the back).
Yep. SLF (Self loading freight) I worked in aviation for 50 years and much preferred my 20+ years with cargo aircraft when I didn't have to deal with passengers.
A couple of years ago I was tootling at idle between locks on the Hatton flight so as not to disturb an angler. He called out for me to give it some revs to stir things up a bit. I usually slow down and stick to the centre of the cut on plain canal sections, but passing a competition can be a interesting as the rods are lifted at the last moment and dropped back in right behind me. Some say I should maintain normal speed. Also, aren't these long carbon rods cheating, as I thought part of the skill in fishing was casting to the perfect spot, not just dropping the hook in.
My sister and brother in law had a new build trad layout in the '90s. Nice boat but the steerer was isolated from the others on board and they had a buzzer for the steerer to communicate. 1 buzz for tea, two buzzes for coffee, three buzzes for lock coming up, etc. When we bought our boat 6 years ago we went for a reverse layout, cruiser stern as it is much more sociable. Also when I go off on my own, I can nip inside and make a brew or grab a coat quite easily. Just put it into neutral when there are no hazards or other boats coming and pop down the steps. Our engine (Barrus
