Rebotco Posted March 31, 2012 Report Share Posted March 31, 2012 Sorry - bogs again! Not really etiquette - more practical. I have received conflicting advice about when to add the "blue" to the holding tank. Some say add a couple of litres after each pumpout. Others say add about a dessertspoon amount after each serious usage. Yet others say a varying combination of the two. What is the consensus on here? Link to comment Share on other sites More sharing options...
frangar Posted March 31, 2012 Report Share Posted March 31, 2012 Dont use blue at all and let nature do its thing......it might not work as well if you have used blue already tho without the tank well.... Cheers Gareth Link to comment Share on other sites More sharing options...
Robbo Posted March 31, 2012 Report Share Posted March 31, 2012 Don't use any at all. Flush your holding tank out to get rid of any blue and start using natural decomposition as it will smell a lot less and be alot greener, theres products that will encourage the bacterial like brewers yeast and others that members here will suggest. Good ventilation of the tank is also key. Link to comment Share on other sites More sharing options...
TUGBOAT Posted March 31, 2012 Report Share Posted March 31, 2012 We have a pump out with a 50 gal tank. we tried brewers yeast but it was a waste of time and it just smelt of fermented p-- we now use odourlos from midland swindlers and it works fine and very cheap to use but it does not break down the waste. hope this is of use to you John Link to comment Share on other sites More sharing options...
Guest Posted March 31, 2012 Report Share Posted March 31, 2012 Sorry - bogs again! Not really etiquette - more practical. I have received conflicting advice about when to add the "blue" to the holding tank. Some say add a couple of litres after each pumpout. Others say add about a dessertspoon amount after each serious usage. Yet others say a varying combination of the two. What is the consensus on here? When we had one - we were told never to use blue on here... luckily for us it no longer matters. We use blue in our cassette waste tank all the time. Link to comment Share on other sites More sharing options...
Robbo Posted March 31, 2012 Report Share Posted March 31, 2012 When we had one - we were told never to use blue on here... luckily for us it no longer matters. We use blue in our cassette waste tank all the time. You properly don't keep cassette's long enough for the natural process anyhow? 1 Link to comment Share on other sites More sharing options...
sueb Posted March 31, 2012 Report Share Posted March 31, 2012 Blue is the work of the devil. There is never a good reason for using it.sue Link to comment Share on other sites More sharing options...
Guest Posted March 31, 2012 Report Share Posted March 31, 2012 You properly don't keep cassette's long enough for the natural process anyhow? Thank god we don't.. Link to comment Share on other sites More sharing options...
Robbo Posted March 31, 2012 Report Share Posted March 31, 2012 Thank god we don't.. Reason why cassettes need chemicals with perfume, as there's no ventilation the natural way won't work (as quick). The natural way is better, but needs air. Link to comment Share on other sites More sharing options...
blackrose Posted March 31, 2012 Report Share Posted March 31, 2012 (edited) Reason why cassettes need chemicals with perfume, as there's no ventilation the natural way won't work (as quick). The natural way is better, but needs air. I don't use any chemicals with perfume in my cassette and it doesn't smell (at least not until I empty it!) I use Odorloss as well which is unperfumed. I've heard the venting theory several times before but I still don't really understand it. Surely the amount of ventilation that comes through a holding tank vent is negligable. All the vent really does is allow gasses coming off the waste, which are the products of anerobic degradation, to escape. Without the vent the internal pressure in the tank would gradually increase and be more likely to expel those gasses into the boat when the toilet is flushed. Edit: And the vent also allows the tank to be pumped out of course otherwise there'd be a vacuum. Edited March 31, 2012 by blackrose Link to comment Share on other sites More sharing options...
Guest Posted March 31, 2012 Report Share Posted March 31, 2012 Reason why cassettes need chemicals with perfume, as there's no ventilation the natural way won't work (as quick). The natural way is better, but needs air. Cheers Robbo...I understand the theory... Link to comment Share on other sites More sharing options...
Robbo Posted March 31, 2012 Report Share Posted March 31, 2012 (edited) I don't use any chemicals with perfume in my cassette and it doesn't smell (at least not until I empty it!) I use Odorloss as well which is unperfumed. I've heard the venting theory several times before but I still don't really understand it. Surely the amount of ventilation that comes through a holding tank vent is negligable. All the vent really does is allow gasses coming off the waste, which are the products of anerobic degradation, to escape. Without the vent the internal pressure in the tank would gradually increase and be more likely to expel those gasses into the boat when the toilet is flushed. If you starve the bacteria of oxygen you slow the process down, that's why it's key. Where not on about which system smells in normal use (as both shouldn't). Edited March 31, 2012 by Robbo Link to comment Share on other sites More sharing options...
blackrose Posted March 31, 2012 Report Share Posted March 31, 2012 If you starve the bacteria of oxygen you slow the process down, that's why it's key. Where not on about which system smells in normal use (as both shouldn't). But the vast majority of the bacteria are under the surface of the waste where they are starved of oxygen anyway (that's why they are anerobically metabolising). Unless you use an additive such as yeast or a product such as Odorloss the oxygen only gets to the surface of the waste in any tank - pump out or cassette. Link to comment Share on other sites More sharing options...
Ange Posted March 31, 2012 Report Share Posted March 31, 2012 We chuck blue in after we've pumped out and every time it starts to smell bad. Link to comment Share on other sites More sharing options...
Grace and Favour Posted March 31, 2012 Report Share Posted March 31, 2012 We chuck blue in after we've pumped out and every time it starts to smell bad. Blue's not good - (It's Formaldehyde !) - -use Odorlos - or a similar bio-thingummy- - much better Link to comment Share on other sites More sharing options...
Ange Posted April 1, 2012 Report Share Posted April 1, 2012 Blue's not good - (It's Formaldehyde !) - -use Odorlos - or a similar bio-thingummy- - much better I have no idea what formaldehyde is! We've got a lot of blue to use up before we even think about any bio thingies. Link to comment Share on other sites More sharing options...
NB Lola Posted April 1, 2012 Report Share Posted April 1, 2012 Totally agree On the enzyme bio stuff, we now use it and it's much better, fewer smells than when using blue and it's environmentally friendly. Much, much better than blue Link to comment Share on other sites More sharing options...
Theo Posted April 1, 2012 Report Share Posted April 1, 2012 I don't use any chemicals with perfume in my cassette and it doesn't smell (at least not until I empty it!) I use Odorloss as well which is unperfumed. I've heard the venting theory several times before but I still don't really understand it. Surely the amount of ventilation that comes through a holding tank vent is negligable. All the vent really does is allow gasses coming off the waste, which are the products of anerobic degradation, to escape. Without the vent the internal pressure in the tank would gradually increase and be more likely to expel those gasses into the boat when the toilet is flushed. Edit: And the vent also allows the tank to be pumped out of course otherwise there'd be a vacuum. EcoMagic, IIRC, supplies oxygen to assist aerobic decomposition. I would much prefer, on aesthetic and ecological grounds, to have the poos decompose rather than be preserved by bacteria killing chemicals which then have to be dealt with at the sewage farm. We use Portapotti. No problems Nick Link to comment Share on other sites More sharing options...
JerryP Posted April 1, 2012 Report Share Posted April 1, 2012 I have no idea what formaldehyde is! We've got a lot of blue to use up before we even think about any bio thingies http://en.wikipedia.org/wiki/Formaldehyde Link to comment Share on other sites More sharing options...
bargemast Posted April 1, 2012 Report Share Posted April 1, 2012 That Blue looks like very unhealthy and nasty stuff, it should be made illegal to sell and use. Peter. Link to comment Share on other sites More sharing options...
Bobbybass Posted April 1, 2012 Report Share Posted April 1, 2012 (edited) don't fancy playing about with yeasts and bio stuff and getting 'balances' etc. I like blue..I add a touch just before pump out so that it goes down the sides and kills as the tank empties. I use about 0.5 litre when its empty..mixed with equal amount of water...and I add a small amount at the end of each week. Have never noticed any smells at all. Works for me..thats good enough. Edited April 1, 2012 by Bobbybass Link to comment Share on other sites More sharing options...
Chris Pink Posted April 1, 2012 Report Share Posted April 1, 2012 Reason why cassettes need chemicals with perfume, as there's no ventilation the natural way won't work (as quick). The natural way is better, but needs air. The trick is to leave the trap open a little. Link to comment Share on other sites More sharing options...
Roxy Posted April 1, 2012 Report Share Posted April 1, 2012 When we had one - we were told never to use blue on here... luckily for us it no longer matters. We use blue in our cassette waste tank all the time. Happy to use blue in my cassette too, smells lovely but then again no number 2's allowed, plus! free to empty bonus!!...if someone needs a number 2 theres plenty of BW's bogs and pubs to go in along the way or if desperate dig a hole side of bank and crap in it- saves on water too!! Link to comment Share on other sites More sharing options...
Victor Vectis Posted April 1, 2012 Report Share Posted April 1, 2012 Edit: And the vent also allows the tank to be pumped out of course otherwise there'd be a vacuum. It also acts as a useful overflow when the ma in law is on board. ! SAM In Brum Link to comment Share on other sites More sharing options...
blackrose Posted April 1, 2012 Report Share Posted April 1, 2012 (edited) EcoMagic, IIRC, supplies oxygen to assist aerobic decomposition. I would much prefer, on aesthetic and ecological grounds, to have the poos decompose rather than be preserved by bacteria killing chemicals which then have to be dealt with at the sewage farm. We use Portapotti. No problems Nick Exactly, so you don't use perfumed additives in your cassette either. don't fancy playing about with yeasts and bio stuff and getting 'balances' etc. You don't need to play about with the bio stuff or get 'balances', you just add the bio stuff the same as you do with blue. But if you like blue then carry on... Edited April 1, 2012 by blackrose Link to comment Share on other sites More sharing options...
