Starcoaster Posted December 10, 2011 Report Share Posted December 10, 2011 Where does one buy non slip matting from? Not the kind you put on your roof to hold a flower pot on, the kind to put on your stern and/or gunwales to stop you going arse over tit when it's a bit icey. Links gratefully received! Cheaper the better. Link to comment Share on other sites More sharing options...
nipper Posted December 10, 2011 Report Share Posted December 10, 2011 I would just walk alone the towpath Starry, and pop into Midland Swindlers at Braunston. I think they have a selection there. Nipper Link to comment Share on other sites More sharing options...
Starcoaster Posted December 10, 2011 Author Report Share Posted December 10, 2011 Thanks, may have to do that as I want a couple of other things... Would prefer to order on line though if poss! Link to comment Share on other sites More sharing options...
classicstove Posted December 10, 2011 Report Share Posted December 10, 2011 Instead of a mat, why not try anti-slip paint Have a look in a chandlers for International nti Slip - its a lot better at keeping the grit in suspension than it usd to be Link to comment Share on other sites More sharing options...
Athy Posted December 10, 2011 Report Share Posted December 10, 2011 That paint has an advantage over the matting: it does not harbour dirt, leaves and general grunge in its holes or underneath it. Paint is easier to keep clean, just a frequent sloosh with water and an occasional more determined assault with something more abrasive. As you may have guessed, 'Trojan' has slip-resistant paint on her decks and roof! Link to comment Share on other sites More sharing options...
steelaway Posted December 10, 2011 Report Share Posted December 10, 2011 Where does one buy non slip matting from? Not the kind you put on your roof to hold a flower pot on, the kind to put on your stern and/or gunwales to stop you going arse over tit when it's a bit icey. Links gratefully received! Cheaper the better. Hi Have a look here ----My link This stuff seems dear but I have bought something similar in sheet form and cut it to size - glued down with with Evostick and lasts for years. Or this stuff ---- Non Slip Tape Alex Link to comment Share on other sites More sharing options...
ChrisPy Posted December 10, 2011 Report Share Posted December 10, 2011 I use interlocking open pattern rubber mats that can be found in Wickes, Homebase, etc. they are self draining and give excellent grip. Link to comment Share on other sites More sharing options...
jenlyn Posted December 10, 2011 Report Share Posted December 10, 2011 pot of paint and play sand from toys r us Link to comment Share on other sites More sharing options...
Athy Posted December 10, 2011 Report Share Posted December 10, 2011 I am pleased that the last word of the thread title has a double "t". Link to comment Share on other sites More sharing options...
jenlyn Posted December 10, 2011 Report Share Posted December 10, 2011 you could of course spray matty with carpet glue and put him out there, tho you might trip over him even if he was slip proof Link to comment Share on other sites More sharing options...
Cheshire cat Posted December 10, 2011 Report Share Posted December 10, 2011 The stick on stuff from the Chandlers isn't cheap. Cheap is buying a pot of paint. Paint the areas you want to be non stick, cover with sharp sand liberally. Leave 24 hours to dry. Sweep excess sand away and then paint again in correct colour. Works well but December isn't the right month to be doing it really. Link to comment Share on other sites More sharing options...
Bat & Frog Posted December 10, 2011 Report Share Posted December 10, 2011 http://www.screwfix.com/p/no-nonsense-anti-slip-tape-50mm-x-18m-black/57217 Link to comment Share on other sites More sharing options...
Rebotco Posted December 10, 2011 Report Share Posted December 10, 2011 http://www.screwfix.com/p/no-nonsense-anti-slip-tape-50mm-x-18m-black/57217 OK for indoors, but what about outdoors? Brian Link to comment Share on other sites More sharing options...
bottle Posted December 10, 2011 Report Share Posted December 10, 2011 Thanks, may have to do that as I want a couple of other things... Would prefer to order on line though if poss! You could always go by boat and practice a bit. Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 10, 2011 Report Share Posted December 10, 2011 OK for indoors, but what about outdoors? Brian I suggested this in another thread. I have not used the Screwfix stuff but bought a role of similar stuff from Betterware and stuck a length to the top of the Wheelie bin to weather test it and I can't get it off Link to comment Share on other sites More sharing options...
Ally Posted December 10, 2011 Report Share Posted December 10, 2011 I'm with Cheshire cat! Link to comment Share on other sites More sharing options...
Bat & Frog Posted December 10, 2011 Report Share Posted December 10, 2011 I suggested this in another thread. I have not used the Screwfix stuff but bought a role of similar stuff from Betterware and stuck a length to the top of the Wheelie bin to weather test it and I can't get it off I have used some square sections I got from this company, while great in the dry I'm not sure about wet as when its really bad I think it may lift a little. This is strange as when it dries out again it appears very solid. This has only happened when totally soaked and pooling water so not sure what is happening, it may be the actual material itself separating as firmly fixed down when checked. Other alternative is I am pissed when it rains ! Link to comment Share on other sites More sharing options...
Higgs Posted December 11, 2011 Report Share Posted December 11, 2011 Avoid the hard plastic clip-together pieces of matting. They have hard studs underneath and can bite into painted decks and spoil the surface. Link to comment Share on other sites More sharing options...
jelunga Posted December 11, 2011 Report Share Posted December 11, 2011 Bought some outside mats from Wilkinsons. About £1.50 each quite non slip on our wooden mooring finger. Link to comment Share on other sites More sharing options...
Starcoaster Posted December 12, 2011 Author Report Share Posted December 12, 2011 (edited) you could of course spray matty with carpet glue and put him out there, tho you might trip over him even if he was slip proof You're a strange one, you... For one, carpet glue wouldn't last very long outside, I shouldn't think. I don't want to piss about with sand and paint, I just want some plastic matting for now! I think the Wilkinsons idea might be the winner! Edited December 12, 2011 by Starcoaster Link to comment Share on other sites More sharing options...
bizzard Posted December 12, 2011 Report Share Posted December 12, 2011 Chicken wire stapled down i find is the best antislip for wooden gang plank jetties ect.Because it moves a bit under foot will help to break up ice too. Link to comment Share on other sites More sharing options...
jelunga Posted December 12, 2011 Report Share Posted December 12, 2011 (edited) Yeah, but difficult to staple to a metal deck though. PS. Plus the bloody chickens will escape Edited December 12, 2011 by jelunga Link to comment Share on other sites More sharing options...
Starcoaster Posted December 12, 2011 Author Report Share Posted December 12, 2011 My deck is wooden so thats not an issue! Thats what they have on the pontoons and it seems to work well. Link to comment Share on other sites More sharing options...
TimD Posted December 12, 2011 Report Share Posted December 12, 2011 I'm trying out a roll of nonslip tape bought from an old fashioned hardware shop. It's a bit like Gaffer tape but has a non slip "sand like" surface like you get on many gunwales/roofs. So far (after 2 weeks) it has worked well but I usually find that most tape/sticky pad adhesive things drop off after a while no matter how well you clean the surfaces. Link to comment Share on other sites More sharing options...
bizzard Posted December 12, 2011 Report Share Posted December 12, 2011 (edited) My deck is wooden so thats not an issue! Thats what they have on the pontoons and it seems to work well. You could easily make a cheap temporary little awning over the rear deck of your boat Star,by Lashing a pole from cabin top to tiller top like a tent ridge pole, Get a cheap tarp with eyelets,a white translucent one for extra light ''Google Bradshaws of Leeds'' all around to tie it down firmly. I know it makes it a bit awkward to get in and out but worth it as it will help keep your engine bay dry and usually one of the first places to rust and need replating are the swim tops on that type and age of boat which rust through by ingress of rain water as i doubt if your boat has deck board drain channels ''gutters''.Also gives you extra dryish storage for coal bags ect.And also when the wooden deck is all nice and dry you can paint the anti-slip on it even in the winter in the dry. Also your boat probably has the wooden steps down to the back door which tend to rot with rain water which would also be kept dry. Edited December 12, 2011 by bizzard Link to comment Share on other sites More sharing options...
