Florida has thousands, if not hundreds of thousands unable to return to their properties, or enter and start their systems again...
Edited by matty40s
4 hours ago, blackrose said:
Was anyone seriously thinking of installing electronic door locks on their boat?
I bet some have with a fob to unlock them to go with the cctv switch the heating on from home and look at the battery volts
22 hours ago, matty40s said:
Apparently the salt water inundated Teslas are self combusting too.
I've done a bit of investigation on this.  It seems that it's another EV myth.  A Little Book of EV Myths
N
55 minutes ago, matty40s said:
I would imagine there is a risk of fire if you switch on any electrical equipment that is soaking wet with salt water.
Where does the salt water come from in a hurricane, out of interest?
Around here in the UK the rain and flooding is broadly fresh water.
Edited by MtB
Wasn't there a Wheeler Dealers programme where they took a car engine sample of oil for analysis and found a high level of sodium which caused a stir. Nothing was found in terms of water leaking into the engine oil such as a blown gasket and it was put down to the fact that the car when not being used had been stored / parked outside in the open by the sea. Incidentally this was in the UK.
Something called a storm surge, where the extreme low pressure of a system hundreds of miles across allows the sea under it to rise.
As the storm approaches land, this surge moves inland like a continuous wave, sometimes sweeping all before it, so the new sea level can be 10-20 feet above its normal level.
Round here we have had 1 meter over the predicted tide hight, due to low pressure and on shore wind. It flooded the car park.
N
I think that you need to do much  more research on this topic Theo!
I would assume that its the fact that it is salt water, an electrolyte, that makes the battery short out.
Hopefully there were no Teslas in it?   :)
No, but there was a classic jag that got a wet floor pan.
The batteries are fully sealed and no water will get into them in a flood.
If they were not sealed they’d fill up with water just driving though rain.
On 29/09/2024 at 10:02, MtB said:
The police here have a "big red key" that opens most doors...
My mate used to enjoy weilding the universal key as he called it.
Which at least one did (according to the owner and a report I saw), and the makers refused a warrantee claim "because it had been driven through a flood". The owner denied this was the case. Maybe faulty assembly, but who knows the real cause. It certainly gives some credence to the fear that rain & floods can destroy EV batteries.
