Hi there,
I have an old Inlander fridge onboard and the other day I noticed I couldn’t close the doors fully.  Upon inspection, the freezer compartment was very frosty and icy and the red light was flashing twice.  I decided to turn it off at the mains but now the fridge won’t go back on when I switch it back on at the mains. I changed the fuse to see if that was the culprit but the fuse is fine. Any ideas or is it time to invest in a modern fridge?
I thought Inlanders were 12/24V DC so where do the mains come into it unless you have a mains to 12V DC converter driving it. If so that might be the problem, so try it straight from the battery.
20 minutes ago, wandering said:
I’m connected to shoreline, if that makes a difference.  Sorry, when I say mains I mean the on/off plug for the fridge in my engine room.
A series of two flashes and then a longer off is, according to Danfoss, shows the controller thinks the electrical load on the fan terminal is too high. I have doubts that an Inlander uses a fan, unless you or a previous owner has added one to blow cool air over the evaporator.
3 hours ago, wandering said:
Hi there,
Defrost the icebox fully, not forgetting the top!  If you have one of those steam generators, then it's not a slow job, just needs plenty of cloths to soak up the old ice.
Then it will probably work.
Bod
If you don't have access to a steam generator, the next best thing is an old cylinder vacuum cleaner that blows as well as sucks.  The air blown out is warm due to having been used to cool the motor, and has enough pressure to blast water out of crevices.
Bod
Since turning the fridge off, the ice melted. My issue is now the fridge won’t turn back on as before.
Yes, my belief is the fridge was working harder than normal because the door wasn’t shutting properly for a day or two. When I turned it off, the ice melted away but now the fridge won’t go back on.
36 minutes ago, PeterF said:
Time to get your multimeter out and check if there is power at the fridge to eliminate that as a problem.
Given the status LED is giving pairs of flashes, we know there is power. Whether it is 12Vdc is woerth verifying though.
But given the meaning of the pairs of flashes, the chances of fixing it seem slim.
But is it?
Are the LEDs still flashing @wandering
34 minutes ago, Tracy D'arth said:
That double flash can also occur when the supply voltage is low. Does it work with the engine running?
Or more specifically, does the 'two flash' error report disappear when the engine is running? (Faster than tickover.)
This easy test saves the OP going out and trying to buy a DVM on a Sunday.
The boat is on shore power apparently so the question might be is the battery charger working correctly. Was something else disturbed in the engine room when the "on/off plug" for the fridge was operated?
I solved the problem, folks. My incompetence knows no bounds: I forgot I set the fridge's temperature dial (it was hidden behind some sausages) to 0. I just turned it now and the fridge came back to life. Gonna go cook those sausages now...
Edited by wandering
Need to get some chipolatas in future. 👍
Excellent news, thanks for the update!
I think we can safely blame the sausages.
  • Haha 2
Probably formed impenetrable walls
