Is it possible to use an angle grinder as a polisher?
I have an angle grinder and it looks as though I can fit a hook and loop backingplate to it. Would it be sensible to use this with the appropriate polishing pads? I've never used a polisher before so thought I'd ask ...
TIA
Paul.
TIA
Paul.
Too fast, and too aggressive, in my opinion. likely to throw polish out to the edge, and create heat on the surface.
1 hour ago, baldlimey said:
I have a friend who does professional car detailing and he does have an angle grinder in his aresenal for difficult jobs but he says it took many hours of practice (and mistakes) before he could use it without burning through the paint.
Ta, looks like I'll be polishing by hand :)
A variable speed sander polisher, with either a hook-loop backing pad or a screw on sponge mop are good for polishing.  Makita make a good one, but pricey,  Axminster used to have an own brand one that would be good enough for occasional DIY work.  Halfords do, or did, a 240 V orbital one, which was a real chocolate teapot.  The 12v ones are even worse.
N
N
Thanks. I already have a lot of DeWalt cordless gear so have been looking at this 18V XR Brushless 125mm Dual Action Polisher - Bare Unit - DCM848N-XJ | DEWALT United Kingdom no idea how good it is, but all my other DeWalt stuff is very good. Trouble is, it is expensive at around £200.
The web page doesn't tell us the crucial bit of info. Does the whole pad rotate or is the action the same as an orbital sander?
Is one better than the other? I'm guessing that a full rotation is probably better ...
3 hours ago, Slow and Steady said:
^ these look like angle grinders, but they are much bigger than the usual 4 1/2" ones most of us have. Really good but require skill to avoid burning the paint and polish will fly off in all directions and annoy your neighbours.
They are nothing like angle grinders. They rotate at about 150rpm instead of the 3,000rpm of a grinder.
15 hours ago, blackrose said:
I bought a cheap electric polisher for 15 quid about a year ago.. It's ok. I'll try to find a link.
Edit. I can't find it, but Argos does this one for £32.
https://www.argos.co.uk/product/1513974
Have something like the Argos one.  They are carp. All right for shining off wax on  a car where the paint is already shiny but not for dealing with dull paint.
The screwfix tool is like what you want, but that one seems a bit fast.  600 rpm will have polish everywhere.  Screwfix descriptions are not renowned for their accuracy of detail though, so it might be worth asking to see /try one if you have a local store.  150-200 rpm is what you want to achieve.
Then you need some sponge mops.  Blue or white (firm)  for cutting, pink (soft or very soft) for finishing.
N
4 minutes ago, Iain_S said:
The Screwfix one looks very like the Titan 4 1/2" angle grinder without the disc guard and a D handle rather than a side handle.
That is what I would expect, why retool (the expensive part of production) when the existing tooling but different gears would do the job as well.
 Share
