Maudesmaster Posted February 15, 2022 Report Share Posted February 15, 2022 Hi pissed off with having to erect TV aerial every night trying to locate mast for best signal getting nagged at by bread knife because she missed her favourite program Then every morning having to take it down and stow it I am looking at this ballade super gain and am asking if it’s any good It looks ok and I can mount it on a pole in deep valleys but would be nice if I could just mount it on the roof and forget it being 70 and a danger to myself as we in doors keep telling it would be ideal thank you in advance Rich Link to comment Share on other sites More sharing options...
DaveR Posted February 15, 2022 Report Share Posted February 15, 2022 We have one of these on Legacy. It is mounted on a telescopic mast but it is not always needed to extend the aerial pole. Only have to retune if you move from one reception area to another but for our TV that is done before the kettle has boiled. MOONRAKER DTV-1000 T.V AERIAL 1 1 Link to comment Share on other sites More sharing options...
OldGoat Posted February 15, 2022 Report Share Posted February 15, 2022 Bitter experience has shown me that most / all of these fancy looking antennae only really work well in strong signal areas (and IIRC others have posted comments here and on other forums). What I have found that works are 'log periodic2 units. These are folat and thus can be easily stored. However, you do need a pole on which to mount it and some form of deck fixing (I use my anchor mounting - No climbing on roof). 1 Link to comment Share on other sites More sharing options...
Rob-M Posted February 15, 2022 Report Share Posted February 15, 2022 This is one of the reasons I changed to use streaming services, no fiddling with aerials it satellite dishes. Generally the internet connection is fine and if not watch on catch up another night. Using one of the hdmi sticks, I use a Now TV stick as I already pay for Now TV, and smarty internet unlimited when I am on the boat. If you want to give it a try get a free SIM and free month using my referral code https://i.smarty.co.uk/ptE8nf. 1 Link to comment Share on other sites More sharing options...
Puffling Posted February 15, 2022 Report Share Posted February 15, 2022 I'd argue in favour of streaming as well, or sometimes, er, Bit torrent to avoid the bundled advertising. An advantage of Smarty if you sign up in the next month or so is that the 50GB package is 200GB for the same price. You can watch a lot of telly on that much bandwidth. And get a month free with my link if you don't use Rob's: https://i.smarty.co.uk/CbXkgOx 1 Link to comment Share on other sites More sharing options...
Tony Brooks Posted February 15, 2022 Report Share Posted February 15, 2022 I don't understand the problem with a log periodic TV aerial. Admittedly I had a cruiser stern with a gas box. I used a cup and a Munsen ring to hold an extendable pole (modified painters pole) plus an app on the laptop that showed me where the likely transmitters are on an OS map. Even in sheeting rain it only took less than 5 minutes to get it up and align. The only place I failed to get at least some TV channels was way up the Caldon. The pole fitted clipped under the gunnel while the aerial hung from a bit of broom handle screwed to the hull lining by the back steps. Link to comment Share on other sites More sharing options...
jonathanA Posted February 16, 2022 Report Share Posted February 16, 2022 (edited) I tried various clever antennae some powered by 12 or 5v up the cable and a free sat setup but bought a cheaper log periodic something like this https://cpc.farnell.com/triax/108185/aerial-mini-log-20-ele-tx20l-lte/dp/AP03068 Not sure the one I have was as expensive as that but similar. It just works... and isn't very big or bulky. most times I don't bother taking it down and her indoors can usually carry on watching whatever banal daytime TV is on as we cruise. Its only on a short 12" pole clamped to the roof. I would add that decent cable and connectors are really important Edited February 16, 2022 by jonathanA Add Link to comment Share on other sites More sharing options...
OldGoat Posted February 17, 2022 Report Share Posted February 17, 2022 12 hours ago, jonathanA said: I tried various clever antennae some powered by 12 or 5v up the cable and a free sat setup but bought a cheaper log periodic something like this https://cpc.farnell.com/triax/108185/aerial-mini-log-20-ele-tx20l-lte/dp/AP03068 Not sure the one I have was as expensive as that but similar. It just works... and isn't very big or bulky. most times I don't bother taking it down and her indoors can usually carry on watching whatever banal daytime TV is on as we cruise. Its only on a short 12" pole clamped to the roof. I would add that decent cable and connectors are really important They're all much of a muchness - Farnet have a minimum order fir free delivery - but as you need an amplifier as well you might qualify. If you move around a lot, then a signal strength meter / indicator is useful - better that twiddling the areial around until you get a picture. Farnel again have good prices. Link to comment Share on other sites More sharing options...
IanD Posted February 17, 2022 Report Share Posted February 17, 2022 (edited) I hate to recommend this site/shop -- some people will know why 😉 -- but there's a lot of really useful advice here... https://www.aerialsandtv.com/knowledge/aerials/aerials-for-caravans-and-boats https://www.aerialsandtv.com/knowledge/aerials/log-periodic-aerials https://www.aerialsandtv.com/knowledge/cable-connectors-and-leads/the-three-main-types-of-coax-cable#low-loss-coax-cable Edited February 17, 2022 by IanD 1 Link to comment Share on other sites More sharing options...
Richard10002 Posted February 17, 2022 Report Share Posted February 17, 2022 8 minutes ago, IanD said: I hate to recommend this site/shop -- some people will know why 😉 -- but there's a lot of really useful advice here... https://www.aerialsandtv.com/knowledge/aerials/aerials-for-caravans-and-boats https://www.aerialsandtv.com/knowledge/aerials/log-periodic-aerials https://www.aerialsandtv.com/knowledge/cable-connectors-and-leads/the-three-main-types-of-coax-cable#low-loss-coax-cable Read the advice, then buy a log periodic from Toolstation. 4 Link to comment Share on other sites More sharing options...
jonathanA Posted February 17, 2022 Report Share Posted February 17, 2022 4 hours ago, OldGoat said: They're all much of a muchness - Farnet have a minimum order fir free delivery - but as you need an amplifier as well you might qualify. If you move around a lot, then a signal strength meter / indicator is useful - better that twiddling the areial around until you get a picture. Farnel again have good prices. They are but , I don't use an amplifier, that was the whole point of buying a log periodic - so I didn't need another box and another power supply. I do have various signal strength meters but don't bother with them anymore. my tip is to look at the aerials on any nearby buildings and point mine the same way... Link to comment Share on other sites More sharing options...
GUMPY Posted February 17, 2022 Report Share Posted February 17, 2022 1 hour ago, jonathanA said: I do have various signal strength meters but don't bother with them anymore. my tip is to look at the aerials on any nearby buildings and point mine the same way... If you have an android phone a very simple way of finding where to point the antenna is to use Freepoint 2 https://play.google.com/store/apps/details?id=com.roepy.freepoint2 It's a good app and we'll worth the miniscule fee. It will give you directions based on GPS location or postcode. I've been using it since the original Freepoint version. Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2022 Report Share Posted February 17, 2022 3 hours ago, Richard10002 said: Read the advice, then buy a log periodic from Toolstation. To be fair to him I got our boat log periodic from him a few years ago and it arrived looking like a banana. Rang him and he dispatched a replacement one no argument without waiting for me to return the old one. I wouldnt spend a bean with him now though. Knowing what I now know about the guy. There are plenty of places to get them from including screwfix and ebay. We have a local place that sells em too. Link to comment Share on other sites More sharing options...
Tony Brooks Posted February 17, 2022 Report Share Posted February 17, 2022 Although I probably paid more that I could I was very happy with the caravan log periodic aerial that looks like fish bones. The elements are pieces of radiused flat aluminum and the "joining up its" were inside a plastic casing. far more distic casing. far more dfficul to catch your clothing on than the wire bar jobs when stored inside the bpatfficul to catch your clothing on than the wire bar jobs when stored inside the boat Link to comment Share on other sites More sharing options...
IanD Posted February 17, 2022 Report Share Posted February 17, 2022 12 minutes ago, Tony Brooks said: Although I probably paid more that I could I was very happy with the caravan log periodic aerial that looks like fish bones. The elements are pieces of radiused flat aluminum and the "joining up its" were inside a plastic casing. far more distic casing. far more dfficul to catch your clothing on than the wire bar jobs when stored inside the bpatfficul to catch your clothing on than the wire bar jobs when stored inside the boat Do you mean one like the "Status 550" (completely inside plastic casing, adjustable from inside boat, includes amplifier/signal/polarisation finder -- but costs £170!!!) or "Image 420" (£35, reflectors stick outside central plastic case)? https://www.aerialsandtv.com/knowledge/aerials/log-periodic-aerials https://www.amazon.co.uk/Status-Short-Mast-Directional-Antenna/dp/B007VLTMGE https://www.amazon.co.uk/Digital-Directional-Antenna-Caravans-Motorhomes-White/dp/B002XS9X0A Both have lower gain than the recommended (repairable) short log-periodic, but are also a bit smaller and maybe easier to mount. Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2022 Report Share Posted February 17, 2022 32 minutes ago, Tony Brooks said: Although I probably paid more that I could I was very happy with the caravan log periodic aerial that looks like fish bones. The elements are pieces of radiused flat aluminum and the "joining up its" were inside a plastic casing. far more distic casing. far more dfficul to catch your clothing on than the wire bar jobs when stored inside the bpatfficul to catch your clothing on than the wire bar jobs when stored inside the boat Ours doesnt have external components but it is basically a compact log periodic enclosed in a plastic case. It works brilliantly but in a caravan its permanently fixed and you extend it and rotate it from inside our wardrobe. We rarely if ever struggle to get a picture. Link to comment Share on other sites More sharing options...
Tony Brooks Posted February 17, 2022 Report Share Posted February 17, 2022 (edited) This one . I found it far better than the two amplified omnidirectional one I trued, a flying saucer and a squirrel cage. I used the amp that came with the squirrel cage for this aerial until I wanted a two output one. Edited February 17, 2022 by Tony Brooks Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2022 Report Share Posted February 17, 2022 2 minutes ago, Tony Brooks said: This one . I found it far better than the two amplified omnidirectional one I trued, a flying saucer and a squirrel cage. I used the amp that came with the squirrel cage for this aerial until I wanted a two output one. Ours is similar but fully enclosed and has the advantage it pulls in DAB radio too. Link to comment Share on other sites More sharing options...
Tony Brooks Posted February 17, 2022 Report Share Posted February 17, 2022 Just now, The Happy Nomad said: Ours is similar but fully enclosed and has the advantage it pulls in DAB radio too. I like things separate so had a dedicated DAB radio aeral Link to comment Share on other sites More sharing options...
OldGoat Posted February 17, 2022 Report Share Posted February 17, 2022 I'm sure the LPs nsurrouded in fabcy plastic work as well as the inexpensive varieties - Digital TV Aerial Kit 20 Element HD Freeview outdoor loft antenna 4G with cable (this is the title of one offered on ebay for under a tenner. You pays yer money... An amplifier may well not be needed by everybody - howver I've no idea where everybody is AND the amount of power that they draw is miniscule - less than 100 milliamps IIRC. Another must / highly reccommended is to use satellite type connectors and cable (NOT the TV type). Easily available by post and both stand the rigours of boating. Link to comment Share on other sites More sharing options...
IanD Posted February 17, 2022 Report Share Posted February 17, 2022 (edited) 20 minutes ago, Tony Brooks said: This one . I found it far better than the two amplified omnidirectional one I trued, a flying saucer and a squirrel cage. I used the amp that came with the squirrel cage for this aerial until I wanted a two output one. The only problem with that -- going by the photo -- is that it can only pick up horizontally polarised signals, which is what all the main TV transmitters use. Repeater transmitters which are used to fill in reception gaps -- especially in rural areas -- use vertical polarisation, which means rotating the aerial so the "fins" are vertical. If this can't be done, you won't get good reception where repeaters are used. https://www.aerialsandtv.com/knowledge/aerials#TV-aerial-polarisation-horizontal-and-vertical Edited February 17, 2022 by IanD Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2022 Report Share Posted February 17, 2022 3 minutes ago, IanD said: The only problem with that -- going by the photo -- is that it can only pick up horizontally polarised signals, which is what all the main TV transmitters use. Repeater transmitters which are used to fill in reception gaps -- especially in rural areas -- use vertical polarisation, which means rotating the aerial so the "fins" are vertical. If this can't be done, you won't get good reception where repeaters are used. https://www.aerialsandtv.com/knowledge/aerials#TV-aerial-polarisation-horizontal-and-vertical You can turn them through 90 degrees, and im also pretty sure Tony knows about aerial polorisation. Link to comment Share on other sites More sharing options...
IanD Posted February 17, 2022 Report Share Posted February 17, 2022 (edited) 2 minutes ago, The Happy Nomad said: You can turn them through 90 degrees, and im also pretty sure Tony knows about aerial polorisation. I'm sure he does, but the one he posted the picture of doesn't look like it can be rotated, the clamp looks fixed... 😞 Mind you, even with the wrong polarisation it's still probably better than an omnidirectional flying saucer/squirrel cage aerials since it's got about 10dB more gain when correctly oriented... 🙂 Edited February 17, 2022 by IanD Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2022 Report Share Posted February 17, 2022 Just now, IanD said: I'm sure he does, but the one he posted the picture of doesn't look like it can be rotated, the clamp looks fixed... It isnt. Link to comment Share on other sites More sharing options...
IanD Posted February 17, 2022 Report Share Posted February 17, 2022 3 minutes ago, The Happy Nomad said: It isnt. In which case, that's fine 🙂 -- unless it's a cheap knock-off copy (lots of these around) of the Image 420 which can't rotate, which is what it looks like... 😞 Link to comment Share on other sites More sharing options...
