Tracy D'arth
Now its a paddle not the heel post.
Notices from C&RT are getting crazier,  If the lock is losing water too quickly (?)  why will it be OK when the ground paddle is fixed?
Notice Alert
Birmingham & Fazeley Canal
Location: Lock 10, Curdworth, Birmingham & Fazeley Canal
Starts At: Lock 10, Curdworth
Ends At: Lock 10, Curdworth
Up Stream Winding Hole: Winding Hole, Curdworth Top Lock
Down Stream Winding Hole: Winding Hole, Curdworth Bottom Lock
Tuesday 21 July 2020 08:00 until Tuesday 21 July 2020 13:00
Type: Navigation Closure
Reason: Repair
Original message:
The Lock is closed for repairs on 21st July from 8am to 1pm. The Lock is losing water quickly but once the ground paddle is fixed, the lock will be fully operational again. Sorry for any inconvenience and thank you for your patience.
TD'
Share this post
3 minutes ago, magpie patrick said:
Presumably the gates at the other end also leak
Exactly, but they regard that as being fully operational!  What standard do they apply?
Share this post
Poor ones unfortunately.
Share this post
The Curdworth flight has ground paddles at both ends of the locks, e.g. https://www.geograph.org.uk/photo/3672660 . A fault with one of the paddles at the bottom gate end would allow the lock to drain, possibly causing a problem with completely filling the lock.
Share this post
That's what I would think so fixing the paddle will sort the leak out stopping the lock from draining, simples.
Edited by Rob-M
Autocorrect
Share this post
Excellent.  Good old C&RT.
Can we find out which paddle was leaking?
TD'
Share this post
Well here we go again, in the middle of the "boating season " too.
Notice Alert
Middlewich Branch (Shrop Union Canal)
Location: Lock 1 (Wardle Lock), on the Middlewich Branch
Starts At: Lock 1, Wardle Lock
Ends At: Lock 1, Wardle Lock
Sunday 2 August 2020 until further notice
Reason: Repair
Original message:
Navigation is currently closed at Lock 1 (Wardle Lock) on the Middlewich Branch due to damaged paddles.
Our team will be on site to investigate as soon as possible.
An update will be issued on Monday 3 August.
You can view this notice and its map online here:
https://canalrivertrust.org.uk/notice/18036/lock-1-wardle-lock-on-the-middlewich-branch
You can find all notices at the url below:
https://canalrivertrust.org.uk/notices
There was a boat yesterday, in front of Swallow, that was reported as ramming the lock gate whilst going down, perhaps this is why?
The branch has been busy this week I'm told.
Share this post
Notice Alert
Reason: Repair
Original message:
More likely a top ground paddle. Only one was working a few weeks ago...guessing the other one failed
Share this post
Would  not have been like this if Maureen was still around......................................................
Share this post
We said exactly the same!
Share this post
When she was there the lock filled at a reasonable rate, probably one paddle then would be faster than both of them full open now.
Share this post
Both top paddles on Wardle lock were cut back many years ago. Its an overlong grading lock for tolls and many not full length boats get dragged forward when going up. The nearside one especially was shortened. You can see folk racking them up and come to a sudden unexpected stop!
This made the lock safer, but slightly slower filling.
There was a bad accident there years ago, a boat hammered into the top gate and a woman went overboard off the bow. A younger Maureen pulled her out from under the boat, she knew where she would be.
Any problems on this lock were fixed PDQ or Maureen nagged the living daylights out of the lengthsman.
Share this post
