davidb
Last boat out of Liverpool
Last Thursday we were the last boat to use the Liverpool Link for the year, the locks are now all closed and lighting installations are being built over the canal at the Pierhead and around the Albert dock, etc.
We didn't even need to get off the boat in Stanley lock - three Vlockies and two Cart men in attendance, thanks very much.
We got as far as Hancock's swing bridge by 14:20 and found it locked off on a timer until 6pm due to the busy road it carries, so we were stuck there for the rest of the daylight - most frustrating!
However it gave me a chance to go for a walk up and over the A59 to look at the ancient 13th C  St Andrew's church in Maghull, a surprising find in such a built-up area.
Further on into Maghull I was intrigued by the elaborate spillway and the fact that it looked to be redundant due to the concrete and piling put into the canal on the water side of it.
David
Edited by davidb
move pictures
Share this post
But, leaving maintenance and repairs out of it, why can't the Link be open all year, provided boaters give sufficient notice.
Share this post
Cos theres a boating " Season " didnt you know!!!! Boats now have to be tied up in their caravan park never to be seen again until easter innitt.
Share this post
David
This is one of very few spillways built on the towpath side of the canal, as they are usually on the 'higher' side of the canal, possibly to reduce the chance of a major release of water should they fail. There is also no defined water course being crossed by the canal here, the nearest being a short distance in the Wigan/Leeds direction, as seen in the earlier, 1802,  of the two surveys of the area. The other survey is from 1827.
Note that there is no bridgekeepers house in the 1802 survey. These were built after the canal opened, Handcock's Bridge at Aintree being named after the first bridgekeeper. He was installed after the Earl of Derby complained after being held up by boatmen leaving the bridge open.
Share this post
I think they did keep it open last year ?  not sure someone local will know.
but agree can’t see why it can’t be used through the winter .
im not even sure why it needs to be one way working either. The usual reason given is sids ditch isnt wide enough for two boats to pass.
Sid of sids ditch fame helped work us through the Stanley flight in the summer.
Edited by jonathanA
Share this post
Thanks for the info, I didn't mention that location you mention is a fairly elaborate grating with a nice stone wall, presumably to keep the horses off it. You can hear running water down there, perhaps it is connected to the weir near the bridge?
Maybe, seeing as they started building the LL not far from here, they were very well financed and were building everything to the highest standards?
Share this post
If Sid's ditch is the channel along by a wall, there is loads of room for a 14'3" shortboat.
Share this post
Yep just like Morris men we are meant to hibernate, but we can get up in April, morris men have to wait till may 1st.
Share this post
But not enough for two to pass, the seaward side sloping far into the ditch. First time we passed along I managed to scrape the bottom by not paying attention.
Share this post
Ahh but I used to have morris dancers at my pub on Boxing day innitt!!
Share this post
It’s not that long, certainly not much different to some tunnels that are only one boat wide but have two way working...
could be fun hanging around on a very windy day but not  dangerous....
Share this post
Perhaps they close the link in the winter is because there aren't enough boat movements to justify staffing the link. Although if that is the case I don't know why they couldn't just reduce the number of days a week when it is open.
Share this post
As indeed they do with the Severn locks.
Share this post
Yes, there was access to Liverpool last Winter.  We went there in early March just because it was available.
Hardly any boats went in or out over winter, but the fact it was open wasn't well publicised.
Share this post
