Does anybody know what make/model of stove this is please? I can't find any makers plate or writing on it anywhere. Thanks!
Looks like one of these:
https://www.woodwarmstoves.co.uk/stoves/foxfire-4kw/
may be nasty but not cheap from this site
Here are some that don't have the second loop. You could stich them to the curtain.
https://www.etsy.com/uk/listing/895977078/curtain-blind-upholstery-rings-hollow?ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=small+vintage+brass+curtain+rings&ref=sr_gallery-1-24&frs=1&variation0=1662455723
CRT have a web page showing where to buy these
https://canalrivertrust.org.uk/enjoy-the-waterways/boating/boating-services/where-to-buy-keys-cards-and-more
It looks like the nearest place to Macclesfield is the CRT Stoke on Trent office at Red Bull. It's possible that boatyards also sell these but I don't know if they do or where
Have a look here:
https://www.cordsncables.co.uk/acatalog/SILICONE__Rubber_Cable_-_Single_Core_1_x_.5___1_x_.75_Silicone_Insulated_Heat_Resistant_180_Dec._C_Cable.html
It looks like they will sell either 10m of 2m dependent on cable.
When I was faced with putting a Squirrel stove through a side hatch I found it best to place a work bench inside so that the stove could be placed onto this from the outside. Just had to lift it off then.
IWA say it's been used in Lister powered gen sets:
#GPS Marine services largely operates Dispenser to supply its own tideway fleet of tugs and workboats. They have been using HVO across the board without problems in a wide range of propulsion units and ancillary engines, including Lister-powered generator sets. The CEO, John Spencer, is also a member of the IWA HVO sub-group.
IWA have commissioned a structural survey:
https://waterways.org.uk/campaigns/listing/aberdulais-aqueduct
https://waterways.org.uk/about-us/news/a-plan-to-save-aberdulais-aqueduct
Yes indeed. I had to turn my stat up to the max to get the pump to run during the recent spell of hot weather. And of course there is the switch on the standard alde room stat that needs to be slid to on.
This is not typical. You might want to see if there is air in the calorifier coil fed from the alde. You should get piping hot water, if you have the boiler set above minimum.
I would advise some decent battery monitoring kit to ensure that you are not depleting the batteries by relying on the solar implicitly.
Have you tried turning off the radiators and firing up the alde? They are usually pretty good at heating the calorifier and would not use gas to the same extent as the radiators. That would be dependent on how the sstem is plumbed. Many people use the alde as the back up water heater.
I don't know how much solar you are getting or your power needs but I don't think you will get away with not running the engine at all if you are going to keep healthy batteries.
There are lots of companies who specialise in supplying replacement doors for existing cabinets. Try googling replacement kitchen doors. I had some made to order a few years ago for the house. They were wrapped MDF but you ought to find something in wood.
I believe that some cookers need 230v to run a fan which cools down the fascia when the oven or grill is used but If you are just changing the hob this won't apply.
You could think about fitting a small inverter if you want the ignition to work.
