Yet on Bm1Funny readings thread.
Who wrote?
One connection and one connection only to the battery - the shunt. All other wires, yes all of them, yes even that one, and the starter negative... yes all of them, go to the other side of the shunt.
I'm confused? Or ...........
Here's a shot of me Norton Commando on back of boat at Honey St.
Not clear under Pram Hood but easy to roll on & off.
Rear hatch is offset. Boat is 11'5" beam .
http://www.jim-shead.com/waterways/mwp.php?wpage=Inland-Waterways-of-England.htm
Click on waterway interested in
Towards bottom of page lock & craft dimensions
https://www.iims.org.uk/the-dangers-of-overplating/
Looked at this thread a few minutes ago on LF then came here. Same subject matter.
edit; Then look in boat building section and see already there. Sorry peeps!
Right then.
Tank height is probably 18-24".
This would give a head of less than1psi with water.
Diesel is at circa 0.7-0.8 Sg. So pressure head even less.
If gas is used instead of liquid then leak is more likely to show up.
So drain tank.
Clean up and get dry.
Turn off engine fuel isolations.
Cap seal with tape or even a plastic bag round threads.
Via vent apply air pressure. Seal around tube.
A small tyre compressor will suffice. Even human lungs[non smokers] can deliver near 2psi. [dizziness permitting]
Remember that the volume of air needs to be compressed so this will take a fair time.
2-3psi will show leak. Either bubbles if below water line or soapy water on hull if above. [snoop]
This is a slow, controlled way to leak test.
Once leak found carry on with rest of tank as there may be more than 1 hole.
Once you know where leak is then you can make an informed decision on repair.
I have repaired many motorcycle tanks by Argon filling as an inert and the welded up quite happily.[tig]
1. If oil in EU is old or low the symptoms you are describing can occur. Watch genny & see if red oil [level] light flickers.
2. You are 12V & not 24V?
From BSSWEBSITE
Lee Cudmore-Ray
Winkfield Row
About 25 miles away
Mobile:
07807820390
Email:
boatsafetyexam@yahoo.co.uk
Membership of
professional bodies
Operates in:
Berkshire | Buckinghamshire | Hampshire | Kent | Oxfordshire | Swansea | Wiltshire
https://evopower.co.uk/9-petrol-generators
Not tried or tested meself but a budget range with a UK contact.[makes all the difference if it does play up!?]
I use one similar to this
https://www.amazon.co.uk/Aluminium-FOLDING-LOADING-Motorcycles-Loading/dp/B00KRDNXCM/ref=sr_1_5?ie=UTF8&qid=1488019609&sr=8-5&keywords=loading+ramps
Had for several years with no issues
Or this?
https://www.amazon.co.uk/PawHut-Folding-Bifold-Portable-183Lx36Wx5Tcm/dp/B0184Y2R4U/ref=sr_1_52?ie=UTF8&qid=1488022997&sr=8-52&keywords=loading+ramps
Pull the plugs.
In gear & rock back 'n forth gently.
Believe it or not coke [cola] down the bores can clear rust off the rings.
The rocking usually gives a bit of movement.
Also check sump level.
May have petrol in?
This will hydraulock the engine.
http://solarwindturbinebatteries.co.uk/
I found them quick and helpful.
Bought 12 cells a few years ago.
A couple of days delivery time.
Needed some links made up of a different length when installing around existing frames in engine bay and they arrived next day.
Watering kit available as well.
Look like these?
http://solarwindturbinebatteries.co.uk/products-page/new-cells-ipzsepzshpsz-2v-cells/5-pzs-et700-2-volt-861ah-c100-838ah-c20-770ah-c10-700ah-c5-duplicate/
