Hi all, I need to drain my fuel pump on a BMC 1.5 as I need to apply thread lock on the ideal pin that has a slight leak, any help would be greatly appreciated.
The thing is the filter and 1 vent has already been purchased and the vent seems to be a fixed top not a screw out so nature how you would use in as a flush out, can't you use the pompous to flush out?
Thanks Robbo,
To be honest it's not for my boat it's for somebody that had the work started and fitter walked off the job, I have no real experience in theses, so any help is much appreciated...
I'm fitting a waste water tank and going to sight the pump out point on the gunnel should I fit the vent also on the gunnel or side....
Thanks in advance
Hi all,
I've got a BSS cert up in March, in need of a gas safe person local to London that's used to BSS certs to install hob and cooker and check Boiler. Any Ideas.
Thanks in advance
Markymark
When the pilot light is first on there's power coming from the gen but as soon as the OL light comes on power fails, this is even when there's nothing connected...
Hi I was wondering if anybody knows anything about these generators, mine fires up ok the pilot comes on for a short period then the overload light comes on fluctuating on and off.
Cheers
Markymark
