Rebotco
Rebotco last won the day on June 21 2012
Rebotco had the most liked content!
1 Follower
    Cheltenham
  • Occupation
    Retired
  • Boat Name
    NEPTUNE 2
  • Boat Location
    Kennett and Avon
8,882 profile views
Rebotco's Achievements
Rising Star
Rising Star (8/12)
319
  1. Not strictly correct - there have been electric charging facilities along the Mon and Brec for at least 20 years! Although this is a CRT canal, it may be the charging infra structure was installed by the electric boat hire companies.
  2. I gave up using a wet vac on my cruiser stern. It is designed to have a wet bilge, and and takes multiple empties with a vac. It does have an automatic bilge pump, but this still leaves about 2" of water. So now I also use a cheapie small bilge pump fixed to the end of a stick, with crocodile clips to temporarily attach to the domestic batteries. I also use a longish piece of hose, which will reach the far side of the towpath. So I just dip the pump into the bilge and it runs continuously, with no emptying of a vac., until I'm happy with the result. If there is a bit of oil as well, it doesn't much matter as its not going into the cut. I find this most useful for emptying the bulk of the engine tray especially, as this cannot be dealt with automatically.
  4. I did this over 20 years ago, and thoroughly enjoyed it. Probably the prettiest canal in the country IMHO. Certainly then, had to moor each night at one of the half dozen dedicated mooring sites. Never had a problem getting a spot then, though there may be more electric hire boats nowadays. By the end of each days cruising the speed was noticably slower and the engine power definitely reduced, which didn't help when you got grounded. So I would say a recharging mooring is essential each night. Things may be a bit different now, for better or worse, but from my experience I would thoroughly recommend it.
  5. Tell you what .......... Let Nick be right on Mon Tues Weds and Gibbo on Thurs Fri and Sat. .......................................................................... then we can all have Sundays off!!!
  6. little electric engraving tools are quite cheap.
  7. Perhaps technology has improved. Nevertheless, there remains a specific lifetime for all CO alarms, quite apart from the batteries.
  8. I think its worth remembering that the internal CO sensors only last up to 7 years anyway. So the whole unit really has to be replaced after 7 years. That's irrespective of the battery condition.
  9. The other consequence of being forced to oscillate between tickover and neutral is that the batteries are getting next to no charging.
  10. I find a particular problem with first time hirers who are told to go v. slow past moored boats. They over react to this and then find they have got very little steerage, which scares them - so they go even slower to avoid hitting othe boats, thus making life more difficult for themselves, and for all those stuck behind them. On the rare occasions I do manage to pass them, I try to explain why they are unable to control their boat properly, and on even rarer occasions, they appreciate the advice!
  11. Whatever "it" it was, it really shouldn't have got out on the passenger side - or left it without locking the door!
  12. If you texted the W3W location there would be no problem with hearing mistakes.
  13. Yes. He has created the whole situation. No one else.
  14. I do wonder if CRT has learned anything from this saga. This guy has dragged them on for over 10 years. CRT has rightly tried to get a peaceful resolution, but has then been far too slow to follow up with enforcement. Apart from all the aggro this guy has been allowed to cause others for all these years, the undue delay has not actually done him any favours. He may, or may not, be suffering from the problems he claims. But even if he is, he is now 10 years older and inevitably less able to cope with the situation he has perpetrated. He would have been far more able to cope with eviction 10 years ago than he is now. Its very difficult for CRT, but extreme leniency actually makes a bad situation worse, both for themselves, and the perpetrator. I hope they can learn to rebalance their priorities for the benefit of all concerned.
  15. Cyclists travelling at a sedate pace are not a problem and most welcome as far as I'm concerned. It's the brainless twerps who think the towpath is a race track who are the only problem. So it all boils down to speed. Notices, signs, advice etc are totally useless on the brain dead. They are never going to slow down voluntarily for anybody. They must be forcibly slowed down - its the only way. My solution is speed bumps - cheap and effective! These will not affect pedestrians, dog walkers, pram pushers, boaters or the sensible cyclists. But will definitely impede the the lunatic stick insects clad in lycra. For maximum impact these speed bumps should be angled towards the canal. Cheap, effective, and highly entertaining. Think I might patent that idea ......?
