MtB Posted September 29, 2016 Report Share Posted September 29, 2016 As some of you know, I have a 24v domestic battery bank, and I've been looking around for a hefty 24v charger. The very best 30A charger (in fact the only 30A 24v charger) I can find is the Sterling Pro Ultra at £600-ish, which seems a lot. Given I don't think I need all the facilities in the Sterling I was idly browsing ebay and it appears there are cheapish forklift chargers around and about. This one for example: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=122153765214 24V 60A charger for £80 starting price. Anyone know if a forklift charger might be suitable for fast charging my domestic batteries? And what the characteristics are of a forklift charger and batteries? After all, they ARE traction batteries and a forklift charger might be just the ticket! Link to comment Share on other sites More sharing options...
cereal tiller Posted September 29, 2016 Report Share Posted September 29, 2016 As some of you know, I have a 24v domestic battery bank, and I've been looking around for a hefty 24v charger. The very best 30A charger (in fact the only 30A 24v charger) I can find is the Sterling Pro Ultra at £600-ish, which seems a lot. Given I don't think I need all the facilities in the Sterling I was idly browsing ebay and it appears there are cheapish forklift chargers around and about. This one for example: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=122153765214 24V 60A charger for £80 starting price. Anyone know if a forklift charger might be suitable for fast charging my domestic batteries? And what the characteristics are of a forklift charger and batteries? After all, they ARE traction batteries and a forklift charger might be just the ticket! That one is likely Transformer type and will not perform at all well with a small Generator. Also states that it is 3 phase CT Link to comment Share on other sites More sharing options...
MtB Posted September 29, 2016 Author Report Share Posted September 29, 2016 That one is likely Transformer type and will not perform at all well with a small Generator. Also states that it is 3 phase CT Thanks, I missed the three phase bit. In what way will a transformer charger 'not perform well' with a generator? As far as I can see a full wave rectified transformer charger is perfect! Link to comment Share on other sites More sharing options...
PeterG Posted September 29, 2016 Report Share Posted September 29, 2016 From memory these tend to be very bulky, run on 3 phase and not marine standard so may be suspect to damp. Also dont remember them as a fast charger although they did charge some large battery banks with a lot of cells to keep topped up. Link to comment Share on other sites More sharing options...
GUMPY Posted September 29, 2016 Report Share Posted September 29, 2016 (edited) This https://www.portablepowertech.com/product/premium-30a-24v-battery-charger/ Is what I used on my 24v system to charge from both mains and genset Actually it was the previous model but mych the same Edited September 29, 2016 by Loddon Link to comment Share on other sites More sharing options...
Bazza954 Posted September 29, 2016 Report Share Posted September 29, 2016 Hi Mike, have a look here http://solarwindturbinebatteries.co.uk/products-page/forklift-battery-chargers/ maybe what your looking for bazza Link to comment Share on other sites More sharing options...
magnetman Posted September 29, 2016 Report Share Posted September 29, 2016 This https://www.portablepowertech.com/product/premium-30a-24v-battery-charger/ Is what I used on my 24v system to charge from both mains and genset Actually it was the previous model but mych the same Looks good. My boat is on 12v. I run a truecharge 20i when on shorepower. Main engine or 12v diesel generator for when off grid. I also have a 24v 12a SPE charger for an electric day boat. The SPE was bought 2nd hand on ebay. Its a good unit with dip switches which can be used to set it up for different battery types, charge rate etc. Nice green led display. I think they do bigger units as well but possibly a bit expensive http://www.spechargers.com/prodotto/high-frequency-battery-chargers/cbhf-series/cbhf1-v2-en/?lang=en Link to comment Share on other sites More sharing options...
Arthur Brown Posted September 29, 2016 Report Share Posted September 29, 2016 Fork lift charger is good. BUT they usually take 3phase input which is hard on most boats. Some are fully automatic some are rather simple and rely on being turned off after some time. What size of generator do you have? Multiply V x A and double that for a rough estimate of power consumed then get the next size of generator. https://www.machinemart.co.uk/p/bc410e-battery-charger-engine-starter/Not silly money eats a lot of electricity but will push power in as fast as the batteries will take it. NOT auto -remember to turn it off! Link to comment Share on other sites More sharing options...
RLWP Posted September 29, 2016 Report Share Posted September 29, 2016 they usually take 3 phase input How do they do that then? Convert 3 phase AC into 24V DC Richard Link to comment Share on other sites More sharing options...
adrianh Posted September 29, 2016 Report Share Posted September 29, 2016 (edited) Conversion is with a 3 phase transformer 400 volts to approx 20 volts then a 3 phase rectifier to give you 24 volts DC approx at quite a high current for a low mains draw - also a standard piece of kit for industrial control panels working at the low voltage controls. I see plenty of small single phase battery chargers in industry used for charging the pedestrian controlled electric trucks and hand stackers, however they are generally on a 16 or 32 amp supply. On small truck/lifter they seem to be using 24 volt from 2 heavy batteries, so you could try talking to local forklift rental companies to see if they have anything for disposal. A few listed on Ebay also. Edited September 29, 2016 by adrianh Link to comment Share on other sites More sharing options...
gazza Posted September 29, 2016 Report Share Posted September 29, 2016 (edited) There are loads of 24-72v single phase charges available. God knows I've shifted plenty of them about at our place over the last 15.5 years. The drawbck with the old stuff is it's transformer based and very heavy and bulky. I have a redundant 24v charger at work, I will measure it up tomorrow to give you an idea of size. It runs off a 13a plug top. Can't remember specs but will get that tomorrow too. Look for electric pallet trucks or scissor lifts for something around the right size and voltage. If you are ever in the Corby/Thrapston area and fancy a donation to the RNLI you can have it if it's suitable and you can find a space big enough to accommodate it Edited September 29, 2016 by gazza Link to comment Share on other sites More sharing options...
RLWP Posted September 29, 2016 Report Share Posted September 29, 2016 Conversion is with a 3 phase transformer 400 volts to approx 20 volts then a 3 phase rectifier to give you 24 volts DC approx at quite a high current for a low mains draw - also a standard piece of kit for industrial control panels working at the low voltage controls. Neat! I guess having three phases, even with a very basic diode pack type rectifier you get a relatively constant 24V Richard Link to comment Share on other sites More sharing options...
Arthur Brown Posted September 29, 2016 Report Share Posted September 29, 2016 How do they do that then? Convert 3 phase AC into 24V DC Richard Three phases six diodes (usually potted) and DC just comes out. Three phase kit usually helps to stop it being "borrowed" because few folk have three phase at home. Link to comment Share on other sites More sharing options...
WotEver Posted September 30, 2016 Report Share Posted September 30, 2016 The other drawback with most (all?) fork lift truck chargers is that they state "keep away from damp" writ large in the instructions. Not great for a boat. Link to comment Share on other sites More sharing options...
Neil Smith Posted September 30, 2016 Report Share Posted September 30, 2016 That sounds like a good offer from gazza, you could build a housing for it on your mooring if no room on boat. Neil Link to comment Share on other sites More sharing options...
gazza Posted September 30, 2016 Report Share Posted September 30, 2016 (edited) Right, it's a 2002 Hoppecke unit.Weight = a roughly calibrated gaz lift of 20? Ish KGS500 wide x 265 high x 300 deep.Input = 230v AC/9aOutput = 24v DC/50APicture to follow. Edited September 30, 2016 by gazza Link to comment Share on other sites More sharing options...
gazza Posted October 1, 2016 Report Share Posted October 1, 2016 I take it the radio silence from MtB means he's not interested? Link to comment Share on other sites More sharing options...
MtB Posted October 1, 2016 Author Report Share Posted October 1, 2016 I take it the radio silence from MtB means he's not interested? Sorry no, only just returned to this thread and noticed your kind offer, many thanks! Have to go out now, will reply properly later... Link to comment Share on other sites More sharing options...
MtB Posted October 1, 2016 Author Report Share Posted October 1, 2016 Right, it's a 2002 Hoppecke unit. Weight = a roughly calibrated gaz lift of 20? Ish KGS 500 wide x 265 high x 300 deep. Input = 230v AC/9a Output = 24v DC/50A Picture to follow. IMG_20160930_081731598.jpg Ok back now. Cor blimey these things are BIG aren't they! Thank you for measuring up and posting the photo. I just about have space for it, but it is gonna take up a fair bit of the back cabin space I have set aside to put the four Trojans I am planning to buy. Right, some thinking from the hip: I notice the charging symbol is a square wave. I'm wondering if this means it is actually 50A peak but only half-wave rectified, which means it will only be actually charging 50% of the time it is on. So it may not charge any quicker than the 30A 'normal sized' charger posted up earlier by that nice Mr Loddon. My next thought is coupled with a low power factor, probably in the region of 50% too, my 1600W genny is likely to be guzzling quite a lot of petrol to feed it. I suspect I'm not the first person to think of using a forklift charger and these are probably the reasons why no-one else does it either. Finally Thrapston is a fair trip up from here in Wiltshire to collect it and lug it back to the boat only to possibly find it isn't really suitable, so on balance I'm inclined to say no thanks to your kind offer unless I find myself coming up your way anyway, and you still have it. Your offer is much appreciated though and thank you again. Hopefully this thread advances the forum knowledge on the subject of battery chargers ever so slightly, too! Currently, I'm feeling inclined to stump up the money for the Sterling charger or the Portable Power Technology Ltd one linked to by Loddon, although the latter doesn't actually state its power factor. Link to comment Share on other sites More sharing options...
GUMPY Posted October 1, 2016 Report Share Posted October 1, 2016 (edited) If you change your mind I can transport Thrapston to Datchet....... ETA if you click on link to charger then under the specification tab you can download manual and data sheet. Both give efficiency as >=85% and PF as 1 at full load. Edited October 1, 2016 by Loddon Link to comment Share on other sites More sharing options...
gazza Posted October 1, 2016 Report Share Posted October 1, 2016 Ok back now. Cor blimey these things are BIG aren't they! Thank you for measuring up and posting the photo. I just about have space for it, but it is gonna take up a fair bit of the back cabin space I have set aside to put the four Trojans I am planning to buy. Right, some thinking from the hip: I notice the charging symbol is a square wave. I'm wondering if this means it is actually 50A peak but only half-wave rectified, which means it will only be actually charging 50% of the time it is on. So it may not charge any quicker than the 30A 'normal sized' charger posted up earlier by that nice Mr Loddon. My next thought is coupled with a low power factor, probably in the region of 50% too, my 1600W genny is likely to be guzzling quite a lot of petrol to feed it. I suspect I'm not the first person to think of using a forklift charger and these are probably the reasons why no-one else does it either. Finally Thrapston is a fair trip up from here in Wiltshire to collect it and lug it back to the boat only to possibly find it isn't really suitable, so on balance I'm inclined to say no thanks to your kind offer unless I find myself coming up your way anyway, and you still have it. Your offer is much appreciated though and thank you again. Hopefully this thread advances the forum knowledge on the subject of battery chargers ever so slightly, too! Currently, I'm feeling inclined to stump up the money for the Sterling charger or the Portable Power Technology Ltd one linked to by Loddon, although the latter doesn't actually state its power factor. No problem, if you do fancy a crack at it and Loddon can help it's yours. I won't be throwing it out any time soon! I'll put a picture of the newer units we have now, way smaller and a little bit less juice hungry. Link to comment Share on other sites More sharing options...
